Question about Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Remote signal not detected.
Regarding the IR detector: is it all that difficult to replace in this TV?
  • dshahweb Mar 06, 2009
    I cannot remotely operate this combo anymore. Have original remote with new batteries and tried a sony universal remote with toshiba TVs recommended codes but NO help...what's the best way to get this working?
  • 934 Answers
Yes, more-so than in a conventional crt based unit without all the extras... You'll need to disconnect many more wires and attachments to get the main board removed then it's about the same job to de-solder the detector and solder a new one in... If you need, take pictures from several different positions in case you stumble getting it back together and can't figure out were a set of wires go to or something. I would order the Ir sensor before you start the job, p/n# 72796410 maybe from Vance Baldwin...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Posted on Nov 20, 2008
My tv wont work with the remote i can turn on by hand but remote wont do anything it has new batterys and the red light goes on
TV brand?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
LG:
1) Test the remote:
2) If the remote checked out OK, then look at the back of the TV for the "REMOTE INPUT", use a mini-phone plug and insert the plug into the remote input jack in and out a couple times to clean the switch contacts that select between the front IR receiver of the TV or the rear panel IR input jacks.
Oct 30, 2011 | Televison & Video
Non functioning batteries ok just stopped no liquid involved not dropped
www.remotes.com
LG:
1) Test the remote:
Aug 23, 2011 | Televison & Video
The remote control of my 26" LCD Tv does not wprk any more, so I need to either fix it or replace it, how and mhere. Santiago Fregoso 323 564-0675 ...
You need to find out if it is the remote or the IR receiver in the TV is bad.
www.remotes.com
Jul 14, 2011 | Element Electronics 26 in. LCD TV
Thought remote was broke, so bought a new one, still cannot use remote for tv & it is the remote for this model
What is the make and model number of this TV? LG TV?
www.remotes.com
LG:
1) Test the remote:
Jun 03, 2011 | Televison & Video
Cant control tv from remote
Lets find out first if it is the remote controller or the remote IR receiver in the TV problem.
New batteries?
www.remotes.com
Mar 24, 2011 | Vizio 42 in. LCD TV
I think the infrared reciever in the TV isn't picking up the remotes signal It won't go on standby or put sound up or down etc I have a Thomson TV/DVD 17 inch .
Make sure that the remote is working by pointing your remote to a IR sensor or use the phone camera to detect -- open the phone camera/digital camera and show the remote with button pressed on to the camera as it will be displayed if IR works.
If so then the IR detector in the TV must be taken out , checked and replaced. You can measure the incident voltage on the IR sensor in the TV if present but not sensing it is faulty but if working without any action then the processor is also a suspect.
Mar 17, 2011 | Thomson Televison & Video
My receiver doesn't receive any signal from the remote control
First of all check your remote with a IR tester. You can use your phone camera with the remote pointed to it for IR detection. This will confirm the remote. Now make sure that there is no loose components in the remote that have come off the board and changed the frequency. If so remove and re-solder.
Now check the IR detector in the receiver, use a multimeter to check the voltage on the IR detection as the remote is used. If there is no voltage check and change the IR, if not the signal track must be traced to the processor.- suspect the processor.
Jan 03, 2011 | Kenwood RCR0907 Remote Control
Infared won't work unless room is brightly lit
Just to provide clarification regarding the IR remote control- unfortunately its the opposite. A brightly lit room can negatively affect the infrared signal the remote uses to transmit the signal from the remote to the receiver- additionally interference may also be caused by fluorescent lighting. Another recommendation regarding IR signal interference is to; power everything off but leave the receiver & your TV on. Then proceed by powering one component on at a time, then testing the remote after each component has successfully been turned on. This process will also help you determine if a component may be causing the interference. Hope this helps! -Kirstie DISH Network
Nov 01, 2010 | DISH Network IR Remote Control
Remote is not working but tv is working manually
Open the remote controller and clean well .Make sure the crystal oscillator and controller IC is having goos soldering but you can resolder on them. make sure the battery terminals also are good, solder all suspected joints. Place the battery and check the battery and detect a voltage rise when you press any key- an IR detector can be useful connected to a multimeter.- If so fit back and test. If you can open the tv and check the IR detection in the TV you can confirm if the signals are coming in or not. However in some cases there will be detection but the frequency would have varied due to the crystal or controller Ic being out of value. Hope you check this out. Good day
Aug 12, 2010 | Samsung TV Remote Control
1934 model recieving
cthy_prry,
The IR detector is in your TV set. It is the device that picks up or captures the IR signal from your remote control and turns it into an electrical signal that the TV via a processor interprets as a function or command to have the TV perform in a certain way as turning on, channel up or down, volume up or down, etc.
IR means Infrared
I hope this answers your question.
Thank you,
Shuttle83
Aug 19, 2008 | Orion1934 19" TV
Toshiba MW24FM1 24 in. TV/VCR/DVD Combo Logo
218 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
