Question about Panasonic Workio DP-3530 Copier
Panasonic workio DP-3530 error code E01-20
On the display screen, there is an error code E01-20. What does this mean and is it something I can fix or do I need to get a technician in to service the copier.
    Sergeant:
  • 284 Answers
E1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
Posted on Nov 20, 2008
How to clear memory on panasonic workio 3530
Service mode F9/ram initialize/all job clear
Apr 30, 2014 | Panasonic Workio DP-3530 Copier
Error code 03-25 -- is that something to do with the drum?
Hi, it does not have to do with the drum but with the drum drive. Most likely its the drum drive gear. It is located right behind the fly wheel in the back of the machine. Once you remove the fly wheel, the drive gear is visible for inspection. Hope this helps.
Jul 20, 2011 | Panasonic Workio DP-3530 Copier
How can I get a meter reading from my Panasonic Workio 3530?
Open the front door, meter will be in the lower right hand corner.
Jun 09, 2011 | Panasonic Workio DP-3530 Copier
Panasonic DP-3530 I need a driver for it
You can download the latestdriver from Panasonic Support at the following link
http://panasonic.net/pcc/support/mfp/dp-6030/index.html
Sep 24, 2009 | Panasonic Workio DP-3530 Copier
FAX card
http://www.abetco.com/pdf/Panasonic/3530.pdf
Check the Yellow Pages for a Panasonic Dealer near you.
Sep 08, 2009 | Panasonic Workio DP-3530 Copier
Where is the waste toner container???
Remove right rear cover. Bottle sits along back of machine. These are rated for 240k and are replaced at your Preventaive Maintenance service.
Aug 06, 2009 | Panasonic Workio DP-3530 Copier
Where's the fuser unit on a Panasonic DP 3000
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
May 16, 2009 | Panasonic Workio DP-3530 Copier
Panasonic DP 3530 printer keeps saying Machine error E03-40
E3-40 is the copy density sensor on the drum unit. Toner is probably dropping from the drum unit onto it. You have to remove the drum to access the sensor.
Apr 13, 2009 | Panasonic Workio DP-3530 Copier
ERROR E1-22
uve a problem with ur laser unit im affraid needs to be replaced
Jan 16, 2009 | Panasonic Workio DP-3530 Copier
Error code J93 on a Panasonic Workio DP 3530
it means the paper remains in the ADF [top part of the machine] . sounds like a stuck or bad sensor
Oct 02, 2008 | Panasonic Office Equipment & Supplies
Panasonic Workio DP-3530 Copier Logo
1,038 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
