Question about Gateway Computers & Internet
I am trying to find memory for my pc - Gateway Computers & Internet
  • bboyd24 Dec 03, 2008
    memory for gateway5200xl
  • 226 Answers
There have been a lot of different types of memory over the years. Please supply your make and model of PC or if it's a built PC then your motherboard make and model.
Posted on Nov 19, 2008
  • Eugene Tetlow
    Eugene Tetlow Dec 03, 2008
    Minimum of 512 MB PC3200 DDR (400 MHz) RAM
    Four Sockets on Motherboard (184 pin)
    Expandable to 4 GB
Memory card not working
try to put in card reader and connect to PC,if PC recognize your memory card try to take backup of your file in card using icare card pro software..then format the memory card... even PC also not recognize your memory card is dead...
May 14, 2012 | BenQ-Siemens Benq E71 Mobile Phone Cell...
X205-SLI1 17" Notebook PC PC Notebook 3 beep
Memory problem:
Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 23, 2011 | Toshiba Satellite X205-SLI1 Notebook
I used this memory stick on my old PC at home and it was wrking okay. When i put it into the usb port it showed up ad removable E. Now I have upgraded my pc to a laptop it doesent recognise the stick....
I assume when you say "memory stick" that you mean a USB memory stick rather than a Sony memory stick.
You should try it in another USB port (if ther is one on your laptop). If that doesn't work, then try it in another PC - if it doesn't work in another PC either, then it is likely that the memory device is at fault, otherwise. If it works fine on another PC, then it is likely that it is the USB port on your new laptop that is at fault in some manner.
If you have another USB device you can use (anything will do - a mouse, webcam, etc), try it in the port you tried the memory stick in. If nothing happens, then in all likeleyhood, the USB port is at fault. If the other device works, then it is probably the USB memory device that is faulty.
If the device works in another PC, try reformatting it as FAT file system on that PC, and see if you can then see it in your new laptop.
Oct 21, 2010 | Office Equipment & Supplies
My hp 5750 beeps 4 times what seems to be the problem??? thank u
This means that your memory is bad or not installed correctly. Open your pc up and remove all memory from the mother board, then dust it, place the memory back in and it should work. If you still have this problem, leave only 1 memory stick in and try starting up your pc, if your pc starts up then the other memory stick is bad and you will need to replace it, if your pc still does not start, remove the 1st memory stick and put the 2nd memory stick in its place and try booting once again. If this still does not fix it, then the memory slots might be bad, try putting the memory sticks in different memory slots and each time try booting your pc. If this does not work, try buying new ram, worst case scenario you will have to replace the motherboard. Or just replace the computer if both memory slots are bad on the motherboard, and i mean IF. Good luck!
Sep 02, 2010 | Computers & Internet
HP/Compaq P4 2.8 GHz Desktop PC alarm is going off. my computer won't start up and there is a 'light bulb' icon that is flashing red
This is a Beep code for Memory Failure or System board failure. Mostly this should be due to RAM ( System Memory ) failure. Try reseating the Memory.
There will be two Memory modules in the system, try booting with only memory module and if it works. the swapping of memory does not help, the system board must be faulty.
May 11, 2010 | HP Compaq dc7100 Ultra-slim PC Desktop
Can't open my nokia memory card on PC, I am not getting removable
install nokia pc suite. it will help you to open memory card with ease access.
Sep 26, 2009 | Computers & Internet
I cant boot up my computer(memory address line failure)
This is clearly a problem with the memory. You can try two things:
1) Remove and reseat the memory sticks (with the unit unplugged)
2) Swap the boards around. Windows is not very tolerant of errors in the lower portion of memory. Swapping around the boards will change the relationship of physical memory addresses to virtual addresses. At the very least, the memory swap may help to determine which memory stick is defective.
Please keep us posted.
Aug 20, 2009 | Dell OptiPlex GX110 PC Desktop
Won't boot..getting 2 short beep codes..have tried memory that i know is good.
Its the problem with the memory only. the memory u get from dell will noit suite ur pc. try changing the same type and speed memory
Apr 20, 2009 | Dell Vostro 200 PC Desktop
Memory reads 128 mb vs 512 mb when new memory installed
Reseat the memory and try rebooting the pc,If it still shows 128mb then take out the 128mb memory and leave in the new one.If the PC does not boot or gives you beep codes then the new memory is faulty.
Dec 18, 2008 | Gateway GT5220 PC Desktop
Hi..i have a problem with the memory.
Some times phone memory data has support files in memory card and vice versa. Your 6233 have just 6MB phone memory. Try to transfer the phone memory data to memory card or PC. Check which made your memory full. Check whether you have Blue tooth data in inbox. if your Phone memory is full you cannot perform some phone application. try to erase some un neccessary data in phone mode itself withourt connecting to Pc suite applications. after data removal try to connect with Pc suite. Now you may transfer your phone data. if problem still persists contact authorised service personnel. All the best !
Nov 11, 2007 | Nokia 6233 Cellular Phone
Computers & Internet Logo
20 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
