You mobile unlock code is mention below as you IMEI number, if you are not success then try the below instruction to unlock mobile.
IMEI Number
356812029244892 Unlock Code: 7462056640
Warning : Do not enter any wrong unlock
codes on your Nokia 1600 mobile phones. If you enter over a certain
amount of wrong unlock codes on your Nokia 1600 mobile phone, your phone
may get permanently locked and sometimes become unusable. 1 - Switch on your Nokia 1600 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 1600.
3 - Compose #pw+CODE+1#.
4 - The Nokia 1600 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 1600 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 1600
Thanks
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery. Then I’ll give you the Master code to reset your Security code.
On a lot of Nokia phones, you can format by typing *#7780#. Make
sure battery is above 75%. This will reset your phone to factory
settings. Not sure if it works for 1600, but you can try...
Either your sim card is not seated correctly, the contacts are dirty, the sim card is dead, the copper contacts in the phone do not reach the sim card or the electronics in the phone are faulty.
try to change a new battery'
or maybe the sim card driver is unsoldered' or need to replace.
here is the pics.
skilled technician can do.
u r problem is related with flash ic , if ur software usf 4 showing firdt boot error send me all informatio on email id [email protected] cause it is not only software problem but also hardware problem
if u send me all info in ur ufs 4 window i can tell u what u need to do
