Paper jam m?essage on HP c4485 with no paper jammed
Any idea's
  • crwilson5000 Jan 02, 2009
    My c4485 Photosmart HP printer says it is out of paper when it is not. I can't use it now.
AdamEntity
  • 14 Answers
SOURCE: Paper Jam Error on HP 2015
For whatever reason the printer internal programming became corrupt showing that there is a paper jam. After checking the paper path and a quick can of air sprayed into the tracks, I proceeded to attempt a Cold Reset.
1) Remove the paper tray.
2) Remove toner cartridge.
3) Unplug USB.
3) While plugged in to power, turn off the printer, hold down the 'GO' button and power it back on. Continue to hold for more than 5 seconds but less than 15.
4) Reinstall the tray (be sure to check the paper level indicator is operating when you add paper to the tray. The lever should move up as it fills with paper)
Reconnect the USB cable (make sure you are using a thick USB cable and not a cheap thin one, very important. Make sure the printer is not plugged into a backup batter either) Never plug a printer into backup power.
I noticed that the computer did not recognize the device when connected which prompted me to contact HP support.
HP Support is shipping out Item # CE517AB - Font/DIMM Program for me to install in the printer to most likely reinstall the firmware.
I will post back if this works to flash the firmware or just waste some time.
Posted on Aug 06, 2008
RPFinney
  • 385 Answers
SOURCE: HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Posted on Apr 16, 2009
  • 72 Answers
SOURCE: HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Posted on Jul 22, 2009
sgoswami
  • 114 Answers
SOURCE: Paper jam on HP officejet 6500
Try This :
Connect the printer directly to the wall outlet ; not through any Power strip
Then Unplug the Power cable from the back of the printer
Keep on tapping the power cable for next 30 seconds
Plug in back the power cable;
Open the rear access door and you will get to see some rollers
Clean the rollers with a Lint free cloth Moistened with some distilled water
Try to do a copy if still it doesn works
With one hand press and hold down the (#) and the (6) button and with the other hand plug in back the power cable ; it will do a Semifull reset on the printer; This will take some time ; Follow the instruction on the screen;
If still it doesn't work then you need to contact HP ;
The toll free no. for HP would be : 1-800-474-6836
They will replace the printer for you free of cost (No Charge if the printer is in warranty i.e within 1 yr of purchase)
Still you may check the link below for further issues:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01312792&lc=en&dlc=en&cc=us&lang=en&product=3795406
Regards Soumajit
Posted on Sep 21, 2009
  • 4 Answers
SOURCE: paper jam and toner message - no paper jam and new toner
Had the same problem Look into www.fixyourownorinter.com
Took the Formatter card out, BAKE for 8 minutes at 350F, let it cool, put it back in and VOILA! Put the card fase up and make sure (with screws) it does not touch the pan you used to bake it.
Good luck
Posted on Oct 27, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
Why can't I fix a false paper jam on my HP printer?
First, rechargeable cartridges are the bane of many HP models. I have never been fortunate enough to find one that works (and I have worked on many printers and computers over the years).
Second, I recommend that you double check and get some canned air to blow out the carriage and anywhere else you can reach without dis-assembly. Many times there is an extremely small piece of paper or even lint that will cause the paper jam signal to be sent and disable an otherwise perfectly fine printer.
Jul 24, 2014 | HP EPPSC4485PHOTOTRAYAS PhotoSmart C4485...
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
Reset paper jam error HP P1120w
i have a hp p1102w laser jet, it's about a year old. Hp want 130 replace it, I only paid 100 for it. I have a blinking red light. It tell me paper jam, I can find no Paper that would make the jam. After two day we looked at it again, when we turned it back on it said out of ink. I knew that was no true, because I had just put new ink in it. Now it's back to paper jam. What do I do? Does anyone have any ideas?
Jun 02, 2012 | HP LaserJet Pro P1102W Printer
Hp cp2025 paper jam message, no paper jammed, even when restarted gives message
try lubricate the paper lefter from down the printer - you must lubricate the two sides
Mar 07, 2012 | HEWLETT-PACKARD HEWLETT PACKARD HP COLOR...
HP Photosmart C4180 All in One It's come up with a paper jam warning. " Claer paper jam, then press OK" I've been right through every thing, front and back as per the ops manula and can't find...
HP's All-In-One printers are notorious for their paper jams, and they are usually caused by small bits of paper left in the paper path - and these can be hard to find. HP has come up with these special instructions for clearing the paper jams. Please click on the following link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=no&docname=c00651302&dlc=en
Be patient while following these instructions and it might also be helpful to have a small flashlight to help you inspect the cartridges and internal workings.
Good luck. If you found this useful, please leave feedback.
Thanks,
Dec 02, 2008 | HP Office Equipment & Supplies
HP Photosmart 2610 - Paper Jam
I cleared the paper jam but i am still getting a paper jam message. I checked thoroughly and dont see any pieces of paper anywhere. I press ok and still get paper jam message. I turned the priner off and on serveral times and that did not work. Same message. I am feeling very frustrated. Its been a week today. Help!
Sep 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
391 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
