Question about Panasonic Microwave Ovens
Door latches will not close onmy Panasonic Dimensions 4 Microwave NNCT766MBPQ.They appear loose as if a spring has broken.
  • Panasonic Master
  • 9,098 Answers
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order Panasonic parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 24, 2008
I have a Panasonic T945SFX where the 'male' door latch was fine but the 'female' receiver was not catching after about 18 months of use.
Looking at the female receiver mechanism, it did not seem to be secure or flush to the frame.
Bought a TORX T20 security bit (Star shape with hole in middle)
-1/4" Hex for power or hand interchangeable bit drivers.
- Packaging: Tamper-Proof T20 TORX STK 86779 from BestWayTool DeerPark NY barcode 0 80497 86779 9
from Ace $1.89 + tax.
and was able to easily remove the 5 rear cover screws and two right side Philips screws, slid the cover back toward the rear about an inch and lifted it off the rest of the frame & oven.
Upon removing the cover I could see the plastic female receiver/interlock mechanism is attached with two philips screws to the stamped-metal frame on just one side.
Very obviously the stamped metal was bent away from the latch opening on the frame -- it was no longer at a 90 degree angle. This had occurred over time with repeated closures of the door.
The following was done with rubber gloves, I did not want to accidentally touch a capacitor -- I did that once on my 1979 ancient Amana Radar Range -- wow was that a surprise!
I made the right choice to remove the two screws and slide the latch mechanism up and then slightly away from the stamped metal -- an inch or two -- versus just trying to push the mechanism back into place.
I then was able to very easily -- thumb and finger -- bend the stamped metal back into a 90 degree angle, reseat the plastic female receiver/interlock mechanism sliding down to ensure the plastic retainer hooked over the metal near the top screw, and reinstalling the two screws to 'secure' the mechanism to the stamped metal.
I reinstalled the cover starting by placing the cover back about an inch from the front of the frame, and carefully holding/squeezing the sides flush against the frame and sliding the cover forward the last inch to ensure the 3 sided cover with multiple 'catches' per side were engaged with the frame, and then secured with the 7 screws: 5 security Torx in rear, 2 phillips on side.
Posted on Dec 27, 2012
My Panasonic microwave nn-t945sfx. Door is hard to shut and is not latching correctly. I inspected the spring and latch and it appears to be working correctly. I noticed the two holes where the latch
Common problem. Apply a small dab of lithium grease to the tips of the door hooks. You might also have to adt. the door latch switch assembly inside the oven as it could be bent out of shape from the hard to close door.
Nov 19, 2014 | Panasonic Microwave Ovens
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
How to fix a door latch of Samsung SMH9207ST microwave?
The small tab on the latch broke so the spring was loose. Took my drill and drilled a small hole in the main body, ran a small wire tie thru it and hooked the spring to the wire tie. Works great and more durable than the orginal dinky hook.
Dec 10, 2011 | Microwave Ovens
My Kitchenaid khms155lss-2 has a problem latching completely. Once finally latched the microwave would start and then stop during the cooking time because the door became unlatched. I have to stand by the...
Ok.Agreed,latch is not cracked or worn out.But check the grip of latch.Open the door.The hold the latch in your hand and see,if its loose or tight.It should be tight.Press the latch towards down and move it left/right slowly --- slowly.And inspect the latch.It will move,there will be a moment but the position of the latch in the door frame should be tight.If you feel that latch is got very loose,then the door frame needs to be disassembled and latch assembly has to be repositioned and fitted.In most of the cases this latch breaks/cracks and it needs replacement.But in your case,its different,you mentioned that if you keep your oven door pressed then latch remains closed..So if latch is broken/cracked it will not get closed properly.So as per that i think,you will have to check the opposite side of the door frame,where this latch gets into.On that side,there is a interlock type part.Which holds this latch.That part is operated by spring.If in-case that interlock type part or the spring,any of this is got loose then latch will get released after few minutes.--------------- But first as regular troubleshooting,you inspect the latch.Do you feel its loose or getting very easily moved,then open the door frame and check the latch.----------- For that you will required door disassembly diagram:--- Click the link,see part number 3 is door latch.-------- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0505176-00002.png -------------- If the latch is properly positioned and intact then ,you will need to disassemble the opposite side cabinet to check the internal part,which hold the latch.For that you will require complete disassembly:---Click this link for complete disassembly:-- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-KHMS155LSS2/0593/0123370?pathTaken=&prst=0&shdMod=KHMS155LSS2 -------------- The door latch itself or other parts holding the door latch,none of the part is costly then $10.The cost of part is under $10.---------It just require you to figure out,either is cracked /broken part or just loose misaligned part.-------- This will help.Thanks.Helpmech.
Feb 10, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
NEFF H5430NOGB Integrated oven - door won't close, the ;hooks on the door itself seem to have gone loose so they ill not clikc inot place when trying ot close, door just flops open.Amy ideas???
I had this problem. The spring inside the door which pushes the the latches down had broken (plastic peg had broken off).
I managed to fix it by attaching the broken end of the spring to the door frame using a small nylon cable tie using the small hole in the plastic fingers which was already there. Note you need to remove the inside door surround.
See the following link to remove the plastic cover on the door
http://www.fixya.com/support/t1267577-replace_front_glass_door_neff_microwave
I had an interim solution which was to tie some thin string to the latch and feed it under the door and pull on the string when closing the door (when it should be latching.
It was
Dec 06, 2010 | Neff H5430 Convection Microwave Oven
Dimension 4 microwave nn a725m door will not close
You can order Panasonic parts here. You can find an authorized Panasonic servicer here.
Sep 08, 2008 | Panasonic Microwave Ovens
Door does not latch close on the Panasonic Microwave Oven Model No. NN T444SF
Aug 26, 2008 | Panasonic Microwave Ovens
Microwave door won't close
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 24, 2008 | Microwave Ovens
Panasonic inverter door won't shut, light stays on.
Thanks for the tips - here is what I did (my wife calls me the Canadian McGuyver!) After taking off the plastic frame (using instructions in Solutions noted above) I used the metal part of a key ring and hooked one end to the spring and looped it around the thick finger/protrusion at the bottom. _197.jpg
Jan 28, 2008 | Microwave Ovens
Microwave Ovens Logo
369 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
