Question about Compaq Presario 5000 PC Desktop
Windows will not start
After turning on the computer, the screen "Checking File System On C Drive" runs, then reboots and reruns again
    President:
  • 2,992 Answers
You might have either a bad hard drive or a corrupted Windows installation (which could be due to a bad hard drive). You can try starting Windows in safe mode (press the F8 key when the Compaq logo comes up after you turn the power on, and pick Safe Mode from the list of startup options) if it will let you. Then try scanning the disk for errors.
You can also try using the Windows recovery console (assuming you have XP) to repair your installation. Boot the computer from the Window operating system CD (Compaq systems came with one; if you don't have one you can probably borrow one from somebody). After setup loads everything it needs you pick the "R" option to try repairing Windows. The "chkdsk /r" command sometimes is able to correct problems so that Windows can start again.
If necessary you can try restoring the original software, and replacing the hard drive if the disk problems continue.
Posted on Nov 23, 2008
Error code 0142 message error code 2000-0142
My computer did boot up to the desktop, but was completely unresponsive from there when trying to open anything. I ran a system diagnostics and got this error with the status byte of 70. I rebooted into Safe Mode and was then able to open files. I backed up my stuff to a flash drive and then ran Error-Checking in the HD Properties which runs the CHKDSK function the next time the computer is rebooted. That found 2 bad file clusters and repaired them. One was a file called Windows.edb, which does the hard drive search indexing for Windows and was most likely my problem with the lockups. The other was a Napinsp.dll file. After these were fixed and the computer was rebooted, everything worked normally.
This HD is only 9 months old, but if this happens again, I'll replace it again.
Apr 21, 2012 | Dell Inspiron 6400 Notebook
Yahoo messenger error "this application has failed to start because the application configuration is incorrect"
Can you get the Chkdsk to run in the general Windows interface by following these instructions?
Try running ChkDsk to check your drive for errors. Right-click your Drive icon/ Properties/ Tools/ Error Checking. Try it first by not checking either box (this will run it in a Read-only mode) to see if it flags any hard drive or file problems. If it does, restart it by ticking both boxes, and rerun it to allow it to attempt to fix any found problems.
Does your Command Prompt work from Safe Mode or from a Clean Boot?
Advanced startup options (including safe mode)
http://windows.microsoft.com/en-US/windows7/Advanced-startup-options-including-safe-mode
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/default.aspx/kb/929135
Does it work if you test with another user, you may have to create one to test with?
Is System Restore and the System File Checker able to fix anything?
How to repair the operating system and how to restore the operating system configuration to an earlier point in time in Windows Vista (or 7)
http://support.microsoft.com/kb/936212/#appliesto
How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows Vista or on Windows 7
http://support.microsoft.com/kb/929833
How to analyze the log file entries that the Microsoft Windows Resource Checker (SFC.exe) program generates in Windows Vista
http://support.microsoft.com/kb/928228#appliesto
Have you tested for Malware? I see lots of recommendations here for programs like -
Malwarebytes' Anti-Malware
http://www.malwarebytes.org/products/malwarebytes_free
SuperAntispyware
http://superantispyware.com/
Source: http://answers.microsoft.com/en-us/windows/forum/windows_vista-windows_programs/yahoo-messinger-wont-start-it-says-the-application/a4f50587-af18-44c8-9157-5157e465a191
Dec 31, 2011 | Yahoo Messenger
Have acer aspire one, when started got screen saying file missing or corrupt window root system 32 hal.dll, nothing else cannot bring up safe mode do not have windows xp cd, in nursing home cannot afford...
I am going to start with the assumption you have already tried to reboot, then next choices from there go kinda like this...
Run windows XP restore from command prompt. (From safe ,mode type C:\windows\system32\restore\rstrui.exe and press Enter. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Replace the boot.ini file (run msconfig) This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Right click on c: drive, click on properties, then tools, click on the error checking button, the put a checkmark in each box, Click start and it may say it needs to run on next reboot click OK the reboot. The physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Run a repair install of the operating system. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Nov 29, 2010 | Computers & Internet
When I shut down windows xp it restarts I stopped auto restart and got a blue screen with this disciption on it Stop: c000021a [Fatal system error] 0x00000000 (0x00000000 0x00000000). any idea
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
Sep 27, 2010 | Microsoft Windows XP Home Edition
Hello, I have had my Acer Aspire One netbook since January and it worked fine until now. It tries to boot but then I get this screen: > Checking file system on C: The type of file system is FAT32. One...
First of all, boot from a windows cd and proceed forward until you reach the format options, and check out if there's any problem with the c: drive or not. Sometimes this happens when the drive is corrupted. If it's ok then run windows repair setup and restore it again. In case this ins't possible, (if you have multiple partition on the system), i would suggest you to install additional windows on another drive/partition, boot from it and check if c: drive is ok or not.
If unfortunately the drive is corrupted, there's no other option for you to boot without formating c: drive, but you can run a quick format and recover the files (if there are important files saved on your system[C; drive]).
I would wish to know after all these.
Good luck.
Thanks for using FixYa.
Jun 21, 2010 | Acer Aspire One Netbook 8.9" Notebook
Blue screen of Death ?
These are the steps that you need to take, and the instructions on how to do it:
1. Reboot into Safemode
2. Run a virus and spyware scanner
3. Defrag
4. Scandisk
5. Registry error repairing
6.Reboot into regular mode windows
Here is how to do it:
Reboot yor machine while holding the F8 key right as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
Windows will start in safe mode. Run an AVG virus scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and only checkmark the top box 'fix file system errors', then click ok, the computer will then tell you it will scan upon next reboot., Now click the DEFRAG NOW button. the choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to reinstall Windows and see if that works.
PRINT THESE INSTRUCTIONS AND KEEP A COPY NEAR YOUR SYSTEM FOR FUTURE PROBLEMS. THIS SERIES OF STEPS CAN FIX MANY PROBLEMS
Good luck.
James.
------PLEASE RATE THIS ADVICE WITH 4 THUMBS UP!!!-----
Apr 25, 2010 | Dell Inspiron E1505 Notebook
I just get the compaq screen when i turn on the computer. I cant access anything at all. How do i fix this?
3. Defrag
4. Scandisk
Windows will start in safe mode. Run an AVG virus scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and only checkmark the top box 'fix file system errors', then click ok, the computer will then tell you it will scan upon next reboot., Now click the DEFRAG NOW button. the choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to reinstall Windows and see if that works. If reinstalling windows doesn't fix it, it is definitely a hardware problem.
Good luck.
James.
Apr 25, 2010 | Compaq Evo N610C Notebook
Computer froze shut down by power button now will not start os lets me choose repair or start normally both tried just goes black screen then reboots over and over
Turn the computer on.
Press F8, repeatedly, until you see a start-up menu.
Choose "safe mode".
If it boots, open All Programs.
Open Accessories.
Open System Tools.
Open System Restore.
Select a date/time when your computer _was_ working correct, and go "back" to that checkpoint.
If that does not help, and it boots, use the Windows XP/Vista/7 "File and Settings Transfer Wizard" to create one file, holding all your E-mail, contacts, and music files.
Copy that file to an external disk-drive.
Then, take a deep breath, and reinstall Windows.
Reinstall MS Office.
Reinstall your anti-virus software.
Reinstall Adobe Reader.
Reinstall your other program.
Finally, reload from the external disk-drive.
Apr 02, 2010 | Acer Aspire 5720 Notebook
Error code:BIOHD-8
Rebooting forever is either memory fault or the HDD have corrupt system files. From the BIOHD-8, it sounds like HDD issue. Try download "HDD Regenerator 1.51" CD ISO, burn to DC and scan to whole Harddrive. This nice software is designed to recover corrupt/bad sectors. I had a friends PC falls into this case. 1 bad sector was found and recovered within 2GB from start where most Windows system files are stored. Then reboot and windows do a chkdsk automatically, and resolved!
Apr 16, 2009 | HP Computers & Internet
Checking file system on C: The type of the file system is NTFS. I turn on my hp pavillion ze4400 and get a blue screen with this message: One of your disks needs to be checked for consistency. You may...
You got a bad disk
Get an external hard drive.
Reboot and Cancel the disk check for you to log-in to Windows.
Back-up all important data.
Once data is safe, open My Computer and right-click on you C: drive then choose Properties.
Click on the Tools tab and click the Error Checking button then select all options and follow on-screen instructions.
Nov 12, 2008 | HP Computers & Internet
Compaq Presario 5000 PC Desktop Logo
63 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
