Question about Cell Phones
Jawbone 2 wont charge
Just took it out of the box checked all connections cant get the LED to come on indicating its charging now what.
  • Anonymous Feb 28, 2009
    no light no nothing. Placed in charger and nothing. even bought car charger and another charger because first one was returned. Nothing
  • Anonymous Apr 19, 2009
    same problem
Can you return it to the store?
Posted on Nov 12, 2009
Jawbone up wont charge
It may be the problem of the charger or the battery, please check them. If the battery is unable to charge or keep charge then replace it.
If the charger is unable to supply sufficient charge or no charge then replace it with a new one.
Jan 13, 2014 | Young Micro Ultra Slim Hard Shell...
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
Jawbone 2 won't charge
I'bve got the same problem with using the apapter plugged into the wall but the headset still charges if the apapter is not used and the usb connector is plugged into my PC.
Try it.
Apr 07, 2010 | Motorola Cell Phones
My Droid won't discover the Jawbone headset in scan mode. Any ideas?
do you have both units in scan (discover or pairing) mode? both units have to be set to pair for the connection to take place. Make sure the jawbone is fully charged up as well.
Apr 03, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Does the LG HBM-210 have to be on to charge
According to the instructions provided by the operator manual...
"Connect the charger to the charging port.
- When the charger is connected, with the power on or off,
the Headset will turn off automatically, and cannot be used.
While charging, the LED indicator will show a solid blue light.
- The buttons will not function while the device is charging.
- It takes 2 hours to fully charge the Headset.
- When charging is complete, the LED indicator will turn off.
Jan 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
Jan 26, 2009 | Palm Treo 755p Smartphone
Jawbone bluetooth does not charge
My jawbone was not charging at all, but then I looked at the prongs on the charger and I saw that one of them was shorter than the others, so I got a pair of small needle nose pliers and gently pulled on it. It returned to its normal length and I plugged it up. It is now charging normally.
Jawbone should design a better charging system.
Dec 14, 2008 | Cell Phones
Iphone and headset
Is this the first time you're pairing iPhone and jawbone or it's been working before?
If this is the first time,
1. Go to settings-general-bluetooth and turn on the bluetooth on your iPhone 2. Press and hold the button above the LED light until the LED light flashes Red and White 3. Go to your iPhone and click on Jawbone and it should connect.
If it's been working before:
1. Make sure Jawbone is fully charged. 2. Press and hold the button below the LED until white light blinks 3. Go to iPhone make sure bluetooth is on press Jawbone to connect
If this procedure fails try the to follow the First Time Pairing Instruction
Hope this works for you.
Nov 21, 2007 | Apple iPhone Smartphone
Battery Charge - First Use
My experience was similar to yours. The LED turned green after about only 2 hours. Because I didn't want to stay up until midnight to start playing with my Axim, I took it out of the cradle after the 2 hours and everything was fine. Besides, having downloaded and read the user's guide 2 days before receving my Axim, I knew that a green LED meant it was ready to go. 3 days later, everything is still fine and seems normal. A year ago, I received a Palm with similar initial charging requirements, and it also didn't take as long as the directions said it would.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Cell Phones Logo
702 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
