Question about Hobart N50 Stand Mixer
How to completely dismantle a Hobart N50 or KitchenAid Model G
If (typeof YAHOO == "undefined") { var YAHOO = {};}YAHOO.Shortcuts = YAHOO.Shortcuts || {};YAHOO.Shortcuts.hasSensitiveText = false;YAHOO.Shortcuts.sensitivityType = [];YAHOO.Shortcuts.doUlt = false;YAHOO.Shortcuts.location = "us";YAHOO.Shortcuts.document_id = 0;YAHOO.Shortcuts.document_type = "";YAHOO.Shortcuts.document_title = "fixya request";YAHOO.Shortcuts.document_publish_date = "";YAHOO.Shortcuts.document_author = "d.manista@sbcglobal.net";YAHOO.Shortcuts.document_url = "";YAHOO.Shortcuts.document_tags = "";YAHOO.Shortcuts.document_language = "english";YAHOO.Shortcuts.annotationSet = {"lw_1227127808_0": {"text": "KitchenAid","extended": 0,"startchar": 185,"endchar": 194,"start": 185,"end": 194,"extendedFrom": "","predictedCategory": "","predictionProbability": "0","weight": 0.454825,"relScore": 5.45324,"type": ["shortcuts:/us/tag/other/wiki"],"category": ["WIKI"],"wikiId": "KitchenAid","relatedWikiIds": [],"relatedEntities": [],"showOnClick": [],"context": "a Hobart tech for a long time. i have a KitchenAid Model G which was made by Hobart and is identical","metaData": {"visible": "true"} },"lw_1227127808_1": {"text": "KitchenAid mixers","extended": 0,"startchar": 515,"endchar": 531,"start": 515,"end": 531,"extendedFrom": "","predictedCategory": "","predictionProbability": "0","weight": 0.592064,"relScore": 7.39748,"type": ["shortcuts:/us/instance/other/product"],"category": ["THING"],"wikiId": "","relatedWikiIds": [],"relatedEntities": [],"showOnClick": [],"context": "come off the shaft like it does for current model KitchenAid mixers. is the planetary assembly just stuck on the shaft for","metaData": {"visible": "true"} }};YAHOO.Shortcuts.headerID = "94b0d6ef87785c89e213771d53e2cfb7";i have a KitchenAid Model G which was made by Hobart and is identical to an old N50. this one is about 1938 vintage. it needs cleaning up and new grease. How do i take apart the planetary assembly and get into the gear area? I took the grease ring off and removed the shaft pin but the planetary assembly does not want to come off the shaft and i dont know if it is stuck on there or if something else needs to be loosened or removed. any advice or directtion to repair information?
  • 2 more comments
  • tinkerer dan Nov 19, 2008
    i dont know what all that garbage is above but here is the meat of my request for help again.
  • Tom Lokey Jan 30, 2009
    I also have a G model, when I took off the switch plate, somehow the alignment got out of place. Now I can't get the gear lever to line up correctly. The machine also makes a growling noise when it is turned on. Any suggestions?
  • John Carder
    John Carder Oct 05, 2013
    Did you ever figure it out? I have used my grandmother's Model G for fifteen or twenty years, and I would like to give it a once over.
  • John Carder
    How did you remove the grease ring? There is what looks like a molded divot on one side that I'm guessing is a snap to hold it on.
  • 135 Answers
If you only want to service the unit and not open the case, you can add grease through the gear shifter plate opening once you remove it. if you have a grease gun with a flex nozzle that's a bonus.
If not it is a messy job. Keep lots of paper towels at hand and use a narrow spatula to get the grease inside. Get as much in as you possibly can.
To remove planetary, with pin removed, spray a bit of wd-40 or other penetrating oil into where the pin came out of let it penetrate for a few minutes. Plan-A Take two screwdrivers and gently try to pry the planetary away from the body of the mixer. Plan-B Add a bit more lubricant to the shaft pin area and install a beater, then try prying with one screwdriver while putting downward pressure on the beater, alternate prying on both sides of planetary. Excessive force at the planetary top can/will crack it as it is a molded piece of metal. If you found this solution helpfull, please rate it. Good luck.
ricardok45
Posted on Jan 09, 2009
  • 49 Answers
They do get stuck. sometimes the pin shears and it gets run with it sheared and gulls the shaft and planetary housing up .
Posted on Dec 29, 2008
  • Due51 Dec 25, 2010
    For the life of me, I could not pry the planetary off, despite using two flat-head screwdrivers. So, I installed the whisk, took a handheld soldering torch and heated the center of the metal molded piece (the planetary), then used a flat prybar wedged under the body of the mixer and over the top lip of the whisk. With a couple whacks with a hammer, it finally dropped down.
    By the way, the brass end of what appears to be the center shaft which this planetary rotates, is in fact, just a brass fitting and not the end of the shaft itself. I thought I could wedge the screwdrivers between the planetary and housing, then hit the shaft end with a mini ball pin hammer. Bad idea. All I did was dent the fitting. No structural damage, but maybe I can save someone from making the same mistake.
Hobart N50 Service Manual
Ebay sometimes has used hobart manuals. maybe check Amazon.com?
There is no other source for hobart manuals other than the internet.
Sep 09, 2009 | Hobart N50 Stand Mixer
I have a Hobart N50 and am in need of a SS bowl. The bowl pins are 8 7/8" apart. Do they make a replacement bowl for this? I've seen the ones that have 9" bowl pins. Thanks, Ron
can buy hobart bowls from lots of places, or use the correctly shaped kitchenaid ones, both fit.. i like the lip and thickness of the hobart bowls, bought mine from globe equip.. do u still have the service manual, if so i would be real intrested in it, please
Jun 14, 2009 | Hobart N50 Stand Mixer
In need of a Hobart N50 spiral hook
Hi. Goto globeequipment.com they have an ED hook for your N50.
If this solution has assisted you, please rate it. ricardok45
Apr 06, 2009 | Hobart N50 Stand Mixer
Looking for older Hobart logo for N50 mixer 1965
you would have to have it made not available
Jan 03, 2009 | Hobart N50 Stand Mixer
More info re: n50 hobart mixer
Judy. Hobart was sold to Illinois Tool Works (ITW) several years ago. The Kitchenaid product line was sold to Whirlpool Corp. several years ago too.
The new N-50 mixers have a motor that is designed by Hobart, but no longer built by Hobart. Last year Hobart began out-sourcing approx. 12-15% of their componnents to Asia. Their parts catalog does not show anything but metal gears. I suspect the new motors have been built in Asia. Wattage is not the output of the motor, but how much power it takes to run the motor and is no indication of how much power goes into your mixing bowl. The true measure of mixing power is horsepower. The N-50 motors are rated at 1/6 HP. Wattage claims by mixer manufacturers is a complete snowjob, and they all do it. Consumers have no protection as a result of this policy. It is a marketing ploy to make you believe that this indicates output power. Shame on all of them! Most componnents of the new N-50's are still manufactured in the USA.
I see that you've done some homework on Kitchenaid Mixers. I wish I had before I bought mine. Yes, they have a plastic transmission housing, and yes, they fail under strong loads demanded by bread dough and stiff cookie dough mixtures (my HD Professional 450 watts failed 5 months out of warranty, after only 30 uses making bread). Go to the www.consumeraffairs.com website and search for Kitchenaid mixer problems and reviews and brace yourself for a shock.
My mixer failed on Oct. 28th. and I had to fight tooth and nail with Kitchenaid to get them to re-imburse me for the cost of the parts that were destroyed by the housing failure. Here we are in 2009 and I'm still waiting for one more part. Kitchenaid parts take at least a month to arrive (in my experience).
I didn't do the research on mixers until mine failed. Since then I've purchased an older Hobart N-50 (with a motor BUILT by Hobart), and this is what I recommend you do, as it will save you much grief down the road. Mine was manufactured in 1990 and only needed. re-greasing to make it like new.
You can find them often on eBay but will have to buy without trying them. Try to find one that is newer rather than older, as a rebuild will get very expensive. I got mine from a Rest. Equip. Wholesaler and was able to try it out in all gears. The previous post (solution) was correct in saying that you should look for one that has a black knob on the shifter handle, this will be a newer one as opposed to an ancient one with an all metal shift lever and potentially worn out innards. If you find one, take it to Hobart, or a Hobart tech can come to you (check service rate) have the unit cleaned, inspected and re-greased. Sit back and take comfort in the fact that these mixers were built like a tank, and will probably outlast you.
Most of all. Good luck, and happy hunting. ricardok45
Dec 28, 2008 | Hobart N50 Stand Mixer
Hobart N50 / KitchenAid Model G: how do i remove planetary?
you need to remove all the back screws then if it doesnt come tap it with arubber mallet it may be seized on
Nov 19, 2008 | Hobart N50 Stand Mixer
Hobart N50 repair books
parts books are available at hobartservice.com for free and you might be able to find service manuals on ebay
Oct 22, 2008 | Hobart N50 Stand Mixer
Mystery part to a 1950 Hobart N50 Mixer; serial number 997185
Go to www.hobartservice.com, register, then go to select "food machines" in the Product Group, then "mixers"and look for the Discontinued Products, then find the N-50 mixer drawings, they are all there, even the old ones. Look through the "exploded" drawings for your extra parts. It seems to me that the tech who put this together should know if they belong to this mixer or not. Does he work for Hobart? Or is he a repair person who states that he knows how to repair Hobart products. If he does'n't work for Hobart, these parts may have been on his bench BEFORE he looked at your mixer. A true Hobart Tech has access to specs on ALL models and the ability to access the Service Manuals. If you find this solution helpfull, please rate it. ricardok45
Aug 20, 2008 | Hobart N50 Stand Mixer
Noisy Hobart N50 Mixer
First, there is a double set screw (one on top of the other - if they are both there) towards the back of the planetary.
Remove the first screw, it should have a normal tip, not pointy. Run the mixer in 1st and adjust the screw, first out then in. Then repeat in 3rd. You should clearly hear a difference.
If not, you probably need to repack the grease in the transmission. The proper grease is called "Darina II". It's expensive ~ $35 per mixer.
Apr 13, 2008 | Hobart N50 Stand Mixer
Hobart n50
I need the serial #,ml or spec # and the exact model #.Ill help you out.I can tell you right now from your description is the tumbler assembly is worn.
Mar 29, 2008 | Hobart N50 Stand Mixer
Hobart N50 Stand Mixer Logo
2,261 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
