Question about Hitachi Televison & Video
No picture hitachi ultravision 60'
Black screen
  • hmandscooby Jan 19, 2009
    tv turns on, but no sound or picture. Have checked everything. Any ideas?
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: hitachi 60 inch ultravision
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
ctf1800
  • 4402 Answers
SOURCE: Hitachi ultravision 60" LCD with red glow in center
convergance problem
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 14, 2007
ya it is the color heater or somthing like that... mine costed 950 to fix... big bucks
Posted on Feb 14, 2008
SOURCE: problem in Hitachi 53UWX10BA
Im having the same problem,, Color red shows and double letters
Posted on Nov 09, 2008
  • 1382 Answers
SOURCE: i have sound but no picture on my hitachi ultravision digital tv
When you use the remote control can you see the on-screen menus, volume or any stuff? if yes, then you may be lucky and have a cable problem. Can you try with another source (DVD, VHS) if you see video with them then you still can be lucky.Check the cables and the hdtv cable box. If you answered NO to any of the previous then its a TV problem and you can't fix it by yourself..
Posted on Aug 27, 2009
Green bulb-or lamp on ultravision hitachi 57uwx20b does not work how much to replace?
On a projection television you will have to replace all three(red,blue,green) projection guns in a matched set, the reason is if you replace just the green gun, your picture will be over saturated with green light making your picture look green,because the new gun will be alot brighter than the red and blue guns.
With that said, repair will cost approx.$400+, I've heard up to$600. Good luck !
Jan 09, 2010 | Hitachi 53UDX10B 53" Rear Projection...
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Sound, no picture, no display, just a black screen
its a Hitachi DLP
it has a lamp that illuminates the screen
it has most likely failed in your owners manuel it should be more specific and you can order a lamp and replace it your self
and you can order a lamp off of line or call hitachi
Oct 26, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
HITACHI ULTRAVISION 60" COLOR NOT IN SINC
Look for the board that has 2 big black ics with STK printed on them.
Dec 09, 2008 | Televison & Video
Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
No picture or just one line across screen on hitachi ultravision rearproj.
Could be a loose connection on the printed circuit board in the Vertical deflection circuit.
You would have to have a qualified technician to repair this problem.
A intermittent connection in the circuit described can cause a horizonal line across the screen.
You have to be careful and not leave the TV on for a period of time with a bright line, as it can actually burn a line on the CRT screens, which is permanent.
Mar 24, 2008 | Televison & Video
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Black block shape at bottom right corner
Can you post a picture of the issue? Maybe the mirror got damaged or there is
Apr 19, 2007 | Hitachi 60V500 60" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
