Question about Dell Inspiron 630M Notebook
Usb hub hi. i have problem with my usb controllers , softwere for usb i cant finded and its not working any hub , please i need driver for universal hub cotrollers . tancks.
tancks 4 u but just i need driver 4 universal serial bus controllers . if u can help me about this please
Posted on Nov 20, 2008
Need windows 8.1 driver for SXUPTTP
It is compatible:
Try opening device manager (Windows Key + X then select device manager from the dropdown) Find your device: Look under "unknown devices" or "universal serial bus controllers", right click and select update driver software.
Nov 07, 2013 | Belkin Components F5L009 5 Port Network...
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
Usb port hub does not recognize external hard drive
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
hope this helps
Jul 05, 2012 | Rocketfish 4Port HiSpeed USB Hub
Why am i having usb problems?
Hi ,
It seems that there is an issue with the usb hub driver so what you can do is click on start-- right click computer --click on manage--device manager .Once the page opens up go to universal serial bus controllers and then uninstall anything that says usb hub by right clicking on it and then uninstall.
If this does not work then the BIOS needs to be updated and that is by going to the Hp website that is .
Oct 06, 2010 | Computers & Internet
My usb port was not use? windows 7 cant detech my flashdisk?
this may happen if USB drivers are not there in your system.. go online and just install driver for USB ok..
May 20, 2010 | Microsoft Windows 7 Ultimate for PC
7950 gx2 cant enable sli mood (single card)
Disable plug & play from BIOS. Now re-install the game and the required driver. From Control Panel--systems--Device Manager, check the properties of the Graphics card drivers and check if there is any clash of resources, if so then allot it manually. Hope this works....sodeep
Mar 30, 2009 | Gigabyte GV-3D1-7950-RH GeForceĀ® 7950 GX2,...
Device will work faster on USB 2.0 pop-up message occurs when USB Device is plugged in
That means that the USB drive that you have on your computer is either on the USB 1.1 driver and you have to update it or your computers USB is not capable of USB 2.0 speed. First thing you need to do is find out the model number and brand of your motherboard. Then go to the manufacturers website then look at the manual for the board to find out if you have USB 1.1 or USB 2.0. If you have USB 2.0 then download the latest drivers for your board. If you only have USB 1.1 then your only options is to buy a USB 2.0 to PCI card that will give you USB 2.0 or just stay with the USB 1.1
Oct 26, 2008 | Microsoft Windows XP Professional With...
Mar 04, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
I am confused that my laptop is damaged
First of all, we are NOT hackers. Don't know where you got that idea, but I myself find it rather repulsive. The problem may lie in the fact your computer may be mapping your USB PenDrive the same as another drive on your computer, making it inaccessable. Now, I requested more information so that I could better assist, but you failed to provide what I asked for. To find out if your computer is dual-mapping a drive letter, you need to access Control Panels -> Adminstrative Tools -> Computer Management, and select the Disk Management at the bottom. You should be able to find the PenDrive in the Bottom Right pane, right click it, select 'Chage Drive Letter' and select an unused drive letter (perhaps M:). If that is the problem, that right there will fix it for you.
Try not to insult people next time.
Mar 03, 2008 | Acer Aspire 5630 Notebook
USB Ports
one way would be to download and install latest device drivers from the net. it should help.. if you are using win XP, there is likely a BIOS or Windows configuration problem. On some computers there is a configuration option in the BIOS that asks whether an IRQ should be assigned to USB. Although the option's actual wording varies among BIOS manufacturers, you must enable this option by setting it to either On or Yes (depending on your BIOS manufacturer and BIOS version). Otherwise no USB devices will work on XP. A problem with Windows XP’s USB Controller configuration can also prevent any USB devices from working. To determine whether the USB controllers are working properly, open Device Manager and expand the Universal Serial Bus Controllers node. Beneath this node, you should see a USB Universal Host Controller and a USB Root Hub. Depending on your PC, there will either be a USB Universal Host Controller and a USB Root Hub listed for each of your computer’s USB ports or a USB Universal Host Controller and USB Root Hub for multiple ports
Jan 20, 2008 | Gateway GT5432 Refurbished AMD Desktop...
Dell Inspiron 630M Notebook Logo
110 people viewed this question
Alun Cox
