SOURCE: dishwasher soap door repair
Remove door front panel to gain access to rear of dispenser (inside door)...then you have access to some linkages to which the trigger clips. You will see which to unclip. Spring is just clipped into position and dispenser door snapped back in! Good luck! Oshie
SOURCE: Dishwasher soap dispenser sticks
Mine dishwasher (a Maytag) did this also. At first it was becoming stuck because of the soap. My repair guy cleaned it and I switched to liquid soap and it worked great another 2 years then did it again. That time it was just wore out and had to be replaced. I was told it was no longer available but we found it here http://www.repairclinic.com/and our repair guy installed it. He was amazed because he had even called everywhere.
SOURCE: soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
A wax motor controls the opening of the lid. Also a seal that fits around the latch lever may be deteriorating and obstructing the function of the lever. Follow the link below for images and part numbers with cost.
Item# 1405...$20.30
Item# 1434...$ 3.95
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
