Question about GoVideo Televison & Video
VR4940, I CAN PLAY A DVD FROM MY RECORDER. BUT WHEN I TRY TO BURN A NEW DVD THE RECORDER REJECTS THE BLANK AND SAYS "UNKNOWN DISC. CHECK DISC AGAIN"
  • georgie320 Nov 23, 2008
    I TRYED SONY, I AM HAVING THE SAME RESULTS
  • georgie320 Nov 27, 2008
    do know what the nero installation is. thank you
    New Friend:
  • 99 Answers
Try Diffferent media's.
Like different manufacturer's ( ummm!! Sony , philips TDK or verbatim etc
If U did this then U'r optical device is faulty
Cheers
Rifaa
Posted on Nov 19, 2008
  • Rifaa-ath Razei
    Rifaa-ath Razei Nov 25, 2008
    Did try renewing your nero installation
  • Rifaa-ath Razei
    Rifaa-ath Razei Nov 28, 2008
    oops sorry! for a sec I mistook for a CPU's.
    I checked u'r drive on amazon and it seems it uses a standard DVD RW drive as used in PC's, I think U can take it out from the recorder and Install it in a PC and check the drive for problem using nero. Or u can ge t new DVD RW ( a latest one ) check ffor the jumper settings and put in the recorder and it will fix ur problem
Recorded GoVideo DVD-R will NOT play in any other DVD player
most dvd players have a region code and you must know what code yours is in, oryou can't play any dvd's, try and find your dvd code,by the way you can only change the code ,think it is 5 times , then it will stay in that code and cannot be changed.
Oct 10, 2012 | GoVideo VR4940 DVD Player/VCR
Trying to copy VHS to Disc-Says"Unknown disc"
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Apr 08, 2011 | GoVideo Go Video VR3840 DVD Recorder/VCR
DVDs I burn will not play on other players. Players reject disc
Check that the burner is finalizing the discs. This can be set in Roxio or in the optical drive properties. In Windows 7, right click on the optical drive, choose Properties, then the Recording tab. Then the Global settings lets you choose to finalize the disc on eject. Try a different brand of DVD+R and check that the other players support DVD+R discs. (I know some DVD players only support DVD-R.)
I hope this helps.
Apr 15, 2010 | Roxio Easy CD & DVD Burning
Samsung DVD recorder will play but not record blank discs
Had mine into the repair shop. Junk it, processor is toast. Not worth the money to fix. The guy said he wouldn't even touch it.
Jan 19, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
DVD unable to play tv recorded items
If you can see recording on the flip side..it is either a disc patch fix (software) obtained thru Go Video..or find another go video recorder to finalize it..you might try unplugging the unit for a minute or two..and try it again...
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
VR4940 Go Video DVD/VCR Recorder
Hey you can try takin the top off and blowin it out ,,thats worked for a few of mine ,, also you can use a air compresser ,,,,hope to help
Oct 05, 2008 | GoVideo VR4940 DVD Player/VCR
Cd not reading
This happens sometime when the drop
down menu in the recording program is
not set correctly for the dvd recorder it
may be set for another recording device
or the dvd player. If this in not the case
try removelng the dvd recorder in device
manager and leting it reinstall
Nov 21, 2007 | Philips DVDR630VR DVD Recorder/VCR
LG RH177 DVD recorder
same here but cant find a place to buy a new dvd drive any one help me
Oct 18, 2007 | LG RH177 DVD Recorder/HDD Recorder
DVD Recorder/Player won't accept DVDs
I think your Laser Lens or drive needs to be cleaned
Sep 18, 2007 | GoVideo Go Video VR3840 DVD Recorder/VCR
Televison & Video Logo
96 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
