Question about Universal Remote Control MRF-260 Barrier-Free Addressable RF Base Station Remote Control
Not sure why I can't get my MRF-260 to operate with my components
I just purchased the MRF-260 base station which is compatible with my MX-850 remote and to control 4 components (receiver, cable, dvd and tv). I have set it up according to the directions and for testing RF signal it works just fine. I have no interference with my other components and the status like flickers when i press the components keys on my remote. However, i cannot get it to function appropriately when i close my entertainment rack (to hide my components) which leads me to believe im not picking up the RF or IR signal. I attached the emitters thinking that would resolve the issue and even so when I push the remote key to cable for instance, I see the base station light up and then the emitter light that's in front of my component but it wont change the channel or turn that device off or on. I believe I have the programming correct in on my MX-850 setting up each component from line 1-4 and then having both the base station and remote set to ID#1. I have tried to change my programming to be RF only per each device but then when i do that I can't change any component even with the remote facing each component. any suggestions
3 Suggested Answers
TVtechmaniac
  • 140 Answers
SOURCE: how do i change the settings on the lcd screen and how do i program my direct tv?
Here is the link to the owners manual:
http://www.universalremote.com/resources/pdfs/MX-850OwnerManual.pdf
Posted on Oct 14, 2007
jhinsincity
  • 616 Answers
SOURCE: I have a direct tv
I believe DirectTV has excellent customer service reps that would be delighted to help you!
Posted on Jul 24, 2011
Not communicating with base station
Check the infrared emission from the remote control. You can check with with a cellphone with camera option. If you wish to know how to check and repair a remote control, check this link. Always check the remote control with new batteries installed. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 11, 2013 | Universal Remote Control MX-600 LCD Remote...
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
Program mx-6000
Check this link to download the user manual to your remote control. It has all details.
Feb 25, 2013 | Televison & Video
I had to get a new TV HD receiver. How do I get it programmed to my MX-850 remote? It will not turn my TV receiver on when I push the on button. I have to manually turn on the receiver.
What kind of receiver did you get? DirecTV, Dish, or something else? This remote comes with software and cables you can connect to your computer. Once you install it, and connect the device, you can program it to connect with your specific electronic components. You may need your existing/original remotes to help get everything set up, but usually that is a one-time process.
Oct 10, 2011 | Universal Remote Control MX-850 LCD Remote...
I have a direct tv remote how do i program it to the MRF-260
Jul 24, 2011 | Universal Remote Control MRF-260...
New devices not listed in the mx-850 software
You need to do an update from your version by clicking HELP from the application's menu bar, then select LIVE UPDATE.
...of course, you need internet access.
Jun 26, 2009 | Universal Remote Control MX-850 LCD Remote...
Universal Remote Control MRF-260 Barrier-Free Addressable RF Base Station Remote Control Logo
135 people viewed this question
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
