Question about Sanyo DRW-500 DVD Recorder
Replace the dvd-rw drive in a sanyo drw500 with new betterproduct
The current dvdrw drive is an (NEC/ND-1100A) .
Will an (LG/GSA4120B) work in it's place ?
If not what dvd burner with better spes.and same physical spes. (external case / metal housing) that will fit case measurements as follows: 1 3/4 x 5 3/4 x 7 3/4 .
Again this for a (SANYO DVD RECORDER.DRW500) End product I am trying to improve the system quality
Thank you for your time, and looking forward to hearing from one of the experts.
sincerely
Mark from MIddletown Indiana
  • adsvictoria Apr 20, 2009
    Has anyone actually replaced the drive in this unit? Mine worked perfectly for about four years, but now almost all of the DVDs I record contain Cyclic Redundancy Check (CRC) errors. I have cleaned the lens, but this does not help. I have not yet opened the case, but thought I would ask if anyone has successfully replaced the drive.
    New Friend:
  • 99 Answers
IF u are only talking abt the Drive only then yes u can get a better one now.
From what u had stated I prsume tht it is in an external bay which has USB or firewire compatibilty , Right?
If this is the case, then U can get a better drive for this, any tyoe will do as long as it is a DVD RW drive.
The one u have currently is a very old one which has very limited capability like recording to DVD-ROM cd's, it can only write DVD+ROM types....
Now u can find Drives which supports + / - type dvd discs and ROM's and also RAM Drives.
Just do a google search or I can state what I uses. I Use
1 - Sony DVD RW DRU-845S
2. TDK DVDRW 1616N
These are the best in it's region when they were released, I believe there are better ones now.
Cheers
Rifaa
Posted on Nov 19, 2008
Jumper setting in cpu
Not sure what the CPU has to do with anything! The following might help with CD/DVD drive jumper settings:
http://www.computershopper.com/storage/howto/installing-a-new-dvd-burner4
Jan 03, 2014 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
It no longer burns discs
Try cleaning it with alcohol on a Q-Tip clean the eye that is located in the drive it will be on a slider . If that doesn't work the replace the drive they do go bad after extended use you can Find one at New Egg for less then 25.dollars
Sep 17, 2011 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Will not read any dvd
make sure the CD or DVD media you isnert is compatible for read/write opeartions
this DVD/RW is 12x40 trasnfer (rate read) and 4x16 write +RW
what format or speed CD media are you inserting ? go to this link to give you a better look at the specs of this NEC product you have
http://support.necam.com/optical/specs/nd-1100a.pdf
if this helped you , please rate me
Nov 03, 2010 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
My dvd rw can't read dvd cd but they can read a cd only
try to go to registry editor and delete upper/ Lower filter. It should resolve the issue
Mar 24, 2010 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
What is the jumper setting as slave?
All drives are different, you have to look on your drive for the pin config
Nov 07, 2009 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
XP can't find ND-1100A drive
Thanks for coming to FixYa, The problem you have is either a well documented software problem or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Jul 11, 2009 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Sanyo DRW-500 Home DVd Player/Recorder
my drw-500 wont read any disc why its say NO DISC please help
Jul 23, 2008 | Sanyo DRW-500 DVD Recorder
NEC DVD+RW ND-1100A
This is a single layer drive only. Usually dual layer drives have DL in the form factor so possibly a
NEC DVD+RW DL?
http://www.adamant.com/itemInfo.asp?GotoID=ITEM&PrdAbr=CDVN-3540A&menu=PARTS
Oct 24, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Nec dvd + rw nd-1100a
first try a audio CD see if ti reads that fine. then inset a data CD and see if you can see all the files on it. Try a few data and audio CD's. If it has trouble with any of these your drive has gone to the great garbage dump in the sky.
Jun 28, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Sanyo DRW-500 DVD Recorder Logo
282 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
