Question about Tricity Bendix AW1400W Front Load Washer
My tricity bendix washing machine flashing and beeping end light
My tricity bendix washing machine has just started to make a beeping noise and the end light is flashing repeatedly, it seems that the machine won't spin during the cycle, it will wash then rinse then the light and beeping noise will start. can anyone help me with what this may be? Cheers Anth
  • 9 more comments
  • Anonymous Mar 15, 2014
    washing machine not spinning properly it starts to spin but does not build up speed it trys but does not get a full cycle my machine is a tricity bendix wdr 1040w
  • Anonymous Mar 17, 2014
    during all wash cycles
  • Anonymous Mar 19, 2014
    Washing machine was squeaking last week in the first bit of the washing cycle(when agitating). Just heard it beeping non stop... It's full of water, won't agitate, but lights on panel are all lit up. Smells hot like something has burnt out, or friction from something.. Took out clothes, managed to get it to rinse out water, it tries to spin but just makes a weird noise.
    It
    Machine seems to be rinsing repeatedly in same cycle and isn't spinning properly
  • Anonymous Mar 20, 2014
    The key symbol is beeping and flashing when I try to turn the washing machine on. The door is firmly closed at the time.
  • Anonymous Mar 22, 2014
    Need to replace the belt
    Removing the back
  • Anonymous Mar 24, 2014
    Beeps after wash, will not advance.
    It does spin in the spin cycle but not in normal just beeps
    water leaking from underneath washer
  • Anonymous Mar 27, 2014
    why do clothes smell after being in tricity bendix dryer
  • Anonymous Mar 29, 2014
    on button orange light on usually green light comes and goes to end button
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1002W
my washing machine is making funny noise before it starts and today it will not start at all just the funny noise
Oct 18, 2008 | Tricity Bendix AW1000W Front Load Washer
Motor won't spin, with flashing "End" light and 3 beeps
this should be a blocked pump or waste pipe or pressure switch ( round grey disk with small pipe off the drum)
Aug 15, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Jan 22, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1001w
is the door locking if not replace it.
Nov 23, 2007 | Tricity Bendix AW1000W Front Load Washer
Machine stopped mid cycle - door light illuminated
this appears to me that you have had one problem and created another, based on what you say i guess the original fault was the pump or a blockage in the outlet system, now you have dismantled the door catch and made that a fault, if possible replace the door catch with one that is known to work, then retest to get back to original fault its a bit like "my telly doesn't wok it must be the on off switch" there's much more than the switch to anything, hope i have helped, if so rate me please
Sep 18, 2007 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
not only check filter but when filter out check for foreign objects fouling pump impellor. (bra wires are the favourite) if pump impellor not visible, then put onto drain and listen for a low humming noise in vicinity of pump. this confirms that pump is powered but jammed. all you can do after that is to check continuity of pump and check there is power to pump when on drain - assumes you have a multimeter
May 03, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1400W Front Load Washer Logo
2,066 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
