Question about Canon imageRUNNER 2870 Copier
Where to load staples
We have a Canon Imagerunner 2870 at work and I do not know where to load staples or what type of staples this machine uses.
  • Ian  Auret
    Ian Auret May 11, 2010
    Do you know the finnisher model nr,installed in your machine
  • 318 Answers
If you have a internal finnisher,you open the front cover of the finnisher,remove the stapler cartrigde with it's green handel.Remove the paper cover of the previous cartridge.Insert the new staplers in the possition of the arrows.Remove red plastic.Reinsert cartridge back into machine.
Posted on Nov 21, 2008
  • Canon Expert
  • 1,326 Answers
The staples are load from the back side of the finisher. To get to the staples look under where the paer comes out. There is a gray handel the you can pull towards you and it unlocks the finisher. You will have to open the toner bottle door and the open the door right above it. Onces you open the doors, pull the handel gently toward you and the finisher should pull out. Open it till it stops and look toward the top right side of the unit toward the rear of the unit and you will see a GREEN handel, that is where thye staples go, just pull on the handel gently and it will come out. Then refill it like the manual or the stapler box shows you. Good Luck
WHEN MAKING A FIRST COPY OF ANY DOCUMENT THE FOLLOWING ERROR APPEARS e000024-0001
Canon imageRUNNER 2870 Copier Error code e000024 ...
www.fixya.com > ... > Canon > Canon imageRUNNER 2870 Copier
... error code e000024-0001 E000024-001 is a problem with the developing assembly it's usually either a faulty toner sensor sometimes just toner stuck to it just ...
Sep 09, 2015 | Canon ImageRunner 3570 | IR3570 |
May canon ir 2870 eror code below E000732-0010
sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Oct 25, 2012 | Canon imageRUNNER 2870 Copier
I inserted staples into stapler cartrdige wrong way for Canon copy machine(imagerunner runner 3245). I figured out how to open it up by unclicking 4 tabs at the bottom. I was able to take out staples and...
This belongs on the lower plate of the cartridge. It hangs down and indicates when the staples are out. Take the cartridge apart again and look at the bottom plate. There should be a slot and another slot perpendicular to the bigger slot. This is where the two tabs of the black piece pivot on. If I remember correctly there is a rectangular shaped part of the arm and I think it faces up. The arm should hang down a little bit. Then put all the parts back together. Load the staples. Good luck.
May 04, 2011 | Canon imageRUNNER 2870 Copier
How do you change a staple cartridge in a canon imagerunner 2870?
first open upper front cover.
then pull handle on left corner of front side, the sorter unit will come out. see behind side of sorter unit u'll find a small green handle to detach the staples cartridge, replace the staples cartridge and insert unit into stapler. push back sorter unit an close the upper front door. end
Dec 20, 2010 | Canon imageRUNNER 2870 Copier
Need help with using the staple feature on my cannon imagerunner 2870. The staple button is not highlighted to be used, but the copier is full of Staples
Do you have on display message like: " limited mode" or similar?
If yes there is some problem with staple finisher. In most case with up and down movement sensor, or copies dont come out sorted, instead goes everywheare on delivery deck...If Im not mistakaen error is E 542 or 724.
You can try under user mode - copy sett.- there must be an option to turn off limited mode. Then restart machine, if something is wrong you will get error code message.
Jun 24, 2010 | Canon Office Equipment & Supplies
Need instructions to load staples in Canon imagerunner 2270
pull the finisher out
you will see the staple in the end of it
pull up the staple cartridge using the green handle
then insert the new one
Apr 06, 2010 | Canon imageRUNNER 2270 Copier
How to load staples in canon imagerunner 3300 copier
Does your copier have the finisher or saddle to have staples? There should be instructions in the user manuals for replacing staples. If you don't have the user manuals, I'd ask Canon to purchase replacement copies or look on the web.
Nov 23, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Cannon Image writer 2870 -trying to retrieve a confirmation log for the past week (todays date 5/22/09)
At machine you can select 'monitor'from the bottom of the screen and select the log for copy or print. If you have network access to the machine you can use the RUI, it's much clearer. Just type in the IP address of your machine and the RUI interface will be displayed. You'll find print, scan and copy logs easy to find there and print.
May 22, 2009 | Canon imageRUNNER 2870 Copier
Load Staples in a Canon ImageRunner 2200
First step, have staple cartridge on hand, type J1 for the iR2200.
Open the front cover of the finisher, which is the door directly below the control panel, which opens from left to right.
There's a handle to grab on the front right corner where the paper comes out, pull it out all the way.
This will expose that module's back right corner where the green staple holder handle is.
With thumb and forefinger, reach in, take hold and lift up and pull out the staple case by its green tab.
You'll see "push" on the sides of the staple case, squeeze thumb and forefinger, one on each "push" sign, and the top will spring up, which is the clear plastic case through which you can see a large spring. Pull out the staple cartridge from the back, under the green tab.
Put the new cartridge in with the orange seal tape hanging out the back.
Press down on the spring-loaded case until it clicks into place again.
Remove the orange seal tab by pulling straight back, then down, not at an angle, as you don't want it to break, just to come off.
Holding it by the green tab, lower the staple case back into the finisher until it settles snugly into place.
Hope that helps!
Feb 09, 2009 | Canon imageRUNNER 2870 Copier
Canon imageRUNNER 2870 Copier Logo
761 people viewed this question
old marine
old marine
Corne Viljoen
