Question about Dell WL6000 Computer Speakers
Crackleing for the last couple of months the speakers are crackleing really bad even when the pc is turned off and the speakers are left plugged in. It seems to be coming from the centre one under the moniter, I've had them for just over 1 year. Are they mendable or do I go out and invest on a BOSE set up, I only use them for listening to music so a 5.1 is a bit unnessasery
  • 2 more comments
  • Anonymous Nov 22, 2008
    I have the same problem. Turning the speakers off ofr a time seems to help but the problem always returns.
  • dmacfie Dec 17, 2008
    I am also getting a crackling (static) sound coming through my speakers and/or my headphones. Can someone help?
  • Anonymous Mar 22, 2009
    Same problem
  • Anonymous Mar 23, 2009
    I have exactly the same problem, turning on/off resolves occasionally. They have been working fine for over 12 months now. I can see several other posts on various sites but no solutions :(
No its not EMI.- I have them too and mine are little over a year old. Have noticed the faint smell of electricial burning. Checked the sub and the amp/pwr supply in there must be slowly breaking down. I cant turn my speakers up past 25 percent volume and the crackling/hum gets very bad, We should all be looking for replacement at this point.
Posted on Aug 17, 2009
Emi...other noise emitting devices in nearby?..dsl connection? without the filters?...neighbor got a new home wifi setup?...
Posted on Mar 31, 2009
Hi I can only hear what is being said on one of
Check your battery pack. Swap with the other known good radio and see if the problem clears up. If so, you have a bad or not fully charged battery. Static or crackling can be a sign of a bad or poorly charged battery.
Also, you may have a mic or speaker issue. Check for debris or something covering the holes over the mic and/or speaker.
Lastly, you may have a speaker problem. Try using an earpiece or headset with the radio to see if the problem does not exist in the audio device. If so, you have a bad speaker. (Be certain your radio is turned off when plugging or unplugging any audio device. )
Best regards.
Sep 23, 2013 | Motorola Radio Communications
Why do my right speaker inputs cause fuzzy sound?
HI KYLE...
I think I have experienced this problem before with my Sony stereo set. It could be a sign that your receiver's amplifier is giving out. Best that you can do is bring it over to an audio repair shop for a checkup. If my suspicion is right, you're gonna have to replace it with a new one. Don't worry, amplifier chips are not that expensive.
And lastly, when any part or component is replaced, be sure to ask the technician to give it to you. You can keep it for your reference.
BOB (June 23rd '12 3:20am)
Jun 14, 2012 | Sherwood RX-4109 Stereo Receiver Black
Ive hooked up all the wires from the dash to the player, it turns on an everything works except the four stock speakers, everything seems to be hooked up correctly an everyonce in a while ull hear a...
A couple of things to think about. If the radio is new, then the speakers may be bad. If the radio is not new and purchased from someone else, the radio may be bad. You are making sure the volume is turned up right? You did use a harness when hooking the radio up right? That is something I strongly recommend.
Happy Hunting
Aug 13, 2011 | Car Audio & Video
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
Crackling seems to be coming from central speaker
in mu experience its a problem with voltage of your speaker.
did you tried before touching the speakers hard...
because the magnetic in the central of the speaker may damaged.
Aug 26, 2009 | Dell WL6000 Computer Speakers
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Dell WL6000 Computer Speakers Logo
1,009 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
