Question about Dell OW7658 (J4624SK8115RT7D50) Keyboard
Keyboard is too sensitive - getting multiple characters
Hello: The keyboard is too sensitive. When striking a key, the character will often repeat (occcasionally twice). As a result, my spell-check is working overtime, and don't even bring up the problems the 10-digit key pad causes with entries made on spreadsheets. Can the sensitivity be adjusted so that one strike equals one character? Thanks.
  • CPOS Dec 18, 2008
    My HP Compaq nc2400 laptop has the same problem. It is so sensitive that just a wave of your finger across the top (without pushing it down) will result in multiple spaces. Does anyone have a solution? Thanks for your help.
I too have encountered this problem. It was the q key on a dell latitude d530. After reading a post on an osxforum describing a software issue i attempted to fix the problem by adjusting the sensitivity of the keyboard. This did nothing. Next i attempted to determine if there was a physical issue. I popped the key off and discovered nothing. I also popped out the white plastic 'scissors' that the key fixes too and still discovered nothing. I looked under the rubber... nothing. compared it to another key... nothing. All in all I could find nothing abnormal about this key other than the fact that it was super sensitive. so I began to experiment. I put a piece of paper under the rubber. This made the sensitivity just about perfect so I left the little bit of paper in place, reassembled, and have had no further problems. This is ghetto i know but it worked for me...
Posted on Aug 16, 2009
  • ghermann3 Dec 03, 2010
    This solved my problem, though I curled a little piece of tape (to make it double-sided) and stuck it under the rubber. Thank you, freddy.
Go to control panel, then keyboard, under the speed tab, adjust repeat delay to long and the repeat rate to slow. This will not "fix" the problem entirely but will help a lot. The only problem is that this will affect holding down the arrow keys to scroll through a sentence or up or down a page when word processing (but I think this may be the lesser of two evils).
Posted on Sep 05, 2009
If you are using Linux, this can be a HAL related problem (strange but true). Turn of the Hardware Abstraction Layer and check if it helps.
Posted on Apr 15, 2009
How do I turn off the blue keys on my acer keyboard? I do not have a fn key
Solution 1 - Permanent OFF (windows 7)
Go to Start menu > Devices and Printers
Right click on HP Wireless Keyboard and Mouse Kit (yours may have slightly different name)
Left click on Region and Language
Left click on Change Keyboards button
Under General tab go to > Default Input Language section > select English (Canada)-US
Under General tab, now go to > Installed Services section > Keyboard heading > click on item for Canadian French then click the Remove button on the right,
Repeat step 6 to remove line item Canadian Multilingual Standard
Click Apply button at the bottom of window, then click OK button to get out of the window, click OK to get out of final window
Close your Devices and Printers window and you are done FOREVER with the unwanted characters! :smileyhappy:
Solution 2 - Temporary toggle between special/normal characters
If it's like mine, the default keyboard setting requires you to do the following:
press hold left ctrl+shift, then tap right shift key, this should toggle between the special characters and back to the normal characters when steps are repeated.
Mar 17, 2015 | Acer Computers & Internet
How to fix sticky keys
You must increase the leadtime before Windows considers your keeping a key pressed down means you want to repeat it.
Open Keyboard Properties by clicking the Start button , and then clicking Control Panel. In the search box, type keyboard, and then click Keyboard.
Under Character repeat, move the Repeat delay slider to the right to increase how long you must hold down a key before the keyboard character repeats, and then click OK.
Jul 24, 2014 | HP Pavilion Computers & Internet
Keyboard
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
Feb 04, 2013 | Vizio Silver 15.6" Thin Light CT15-A2...
Keyboard typing multiple letters/ numbers when pressing certain keys.
Feb 03, 2013 | Computers & Internet
My keyboard typing multiple letters
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard\'s repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
If fails
Gather your supplies. There are commercial kits available, but a can of compressed air, a lint-free cloth or wipes, mild dishwashing liquid, and a vacuum cleaner with a soft brush are all you really need for a basic cleaning. After turning off your computer and unplugging your keyboard, gently shake the keyboard upside down over some newspaper to dislodge loose crumbs and particles. Use the can of compressed air to blow a stream of air between the keys. Repeat Step 2. Dampen a lint-free cloth with a diluted solution of dishwashing liquid and water to wipe down the keys. Use the vacuum cleaner brush attachment to suck away any remaining dirt or debris. If you have a membrane-type keyboard (it doesn\'t have a spring under each key) and the keys are truly grungy, you can remove the keys with a small screwdriver and use cotton swabs and 90% isopropyl alcohol to get it sparkling clean
If you are still feeling industrious, next you can tackle cleaning your mouse Of course, if cleaning your keyboard seems a truly undesirable task, you can always buy one for around $20.
Hope this helps.
Dec 31, 2012 | HP Computers & Internet
How to use accents when writing in Spanish in a Dell Precision m4500 laptop?
On Windows XP
  1. Log On
  2. Click the Start button
  3. Click on Control Panel
  4. Click Regional and Language Options - a new window will pop up
  5. Click the Languages tab
  6. Click on the Details button
  7. Click the Add button - a new window will pop up
  8. Select United States-International (keyboard layout menu)
  9. Click OK
  10. Click Apply
  11. Read the instructions for "Using the U.S. - International Keyboard" below.
Note: You will now have a keyboard icon on the taskbar (usually on the right side). To switch between keyboard layouts click the keyboard icon on the task bar and choose which layout you want to use. Changing the keyboard layout will only affect the log on profile used. No other users will be affected.
Windows Vista
  1. Start-->Control Panel-->Clock, Language, Region-->Change Keyboards
  2. New Window: Click the Change Keyboards button
  3. New Window: Click the Add button
  4. Select United States-International keyboard
  5. Click OK
  6. From drop down menu (Default Input Language) select United States International
Using the U.S. - International Keyboard If you followed the above directions carefully, your keyboard will now react slightly differently than it did before. First of all, notice that if you strike the single apostrophe (') key, nothing happens. To type the single apostrophe now, you must strike the single apostrophe key and then strike the space bar. When you strike the spacebar, the apostrophe will appear.
The next thing to note is that the quotes (") key behaves the same way as the apostrophe key. You must first strike the quotes key and then strike the space bar in order to create the (") symbol. These two minor inconveniences are more than made up for by the ease with which you can now type the special characters.
To type the special characters, two keystrokes are required. To type the ?, you need only strike the apostrophe key and then the letter a. The other characters are just as easy:
  • ? = ' + a
  • ? = ' + e
  • ? = ' + i
  • ? = ' + o
  • ? = ' + u
  • ? = ~ + n
  • ? = " + u
To type the special punctuation characters, you need to hold down on the Alt key while you strike the appropriate punctuation mark. On some keyboards, only one of the two Alt keys will work for this.
  • ¡ = Alt (hold down) + !
  • ¿ = Alt (hold down) + ?
Using Cryptic Codes If, for some reason, you don't want to change your keyboard, you can always type in the troublesome cryptic codes. Using this arcane system, the following codes apply:
  • ? = Alt + 0225
  • ? = Alt + 0233
  • ? = Alt + 0237
  • ? = Alt + 0243
  • ? = Alt + 0250
  • ? = Alt + 0241
  • ? = Alt + 0252
  • ¡ = Alt + 0161
  • ¿ Alt + 0191
When using this utterly out-dated system, there are two important things to remember. First, when you type in the numbers, some keyboards require that you use the "numeric keypad" located to the side, rather than the numbers along the top. Second, on some keyboards, only one of the two Alt keys will work for this.
May 02, 2011 | Computers & Internet
Every key stroke gives me double characters
Possibly your keyboard settings are too sensitive. Go to your Control Panel and click on Keyboard. There you can adjust your settings to decrease the sensitivity of the keys.
Feb 10, 2010 | Logitech 967437-0403 Keyboard
Keyboard keystrokes causing multiple characters
ACER repair facility in Texas is very good, Are you still under warranty?
Apr 10, 2009 | Acer Aspire 5720 Notebook
My keyboard
yaa bcoz you have made your Numlock On thats why keyboard gives you these characters. You can see a led 'on' on your keyboard near Num Lock.
To make it off press and hold Fn kye (left side bottom row of the keboard) and press Num Lock kye (Top row right side). It will make your Num Lock on/off.
Thanks
Iqbal
Apr 12, 2008 | IBM ThinkPad T30 2366 Notebook
Dell OW7658 (J4624SK8115RT7D50) Keyboard Logo
1,171 people viewed this question
Alun Cox
