Roland colour camm pc60 printing / cutting contours
Does anyone no how to contour round letters/shapes that i have just printed on my roland colour camm pc60 ?
thanks
  • 679 Answers
Yes, if you have a photo editing program, like googles free Picassa. You can change the text all kinds of ways from the basics to the shadow directions. There are all sorts of fonts and colors, look in your programs, the chances are that you have a photo editing program. Most of them if not all, have the features to allow experimenting. I just did a similar thing on an old document where I scrolled until finding the almost perfect text, and then was able to fade it and change the shape and texture to look like the original text. Good luck
Posted on Dec 15, 2008
Bidirectional printing
check your ink@find if something stuck in it in the back or under it
Dec 18, 2011 | Office Equipment & Supplies
All four colors wont print roland sp300v
you print head is dry out. Normally, it happened on Magenta and Cyan colors.
Apr 09, 2010 | Office Equipment & Supplies
Roland PC60 - flashing lights - why?
This happens occasionally with myself if I am printing a large number of labels which is taking a while and decide to cut off some already printed labels from a previous job off from the roll before the current label job has finished. It then feeds the roll back past the edge sensor on the front, gets confused and flashes the lights. I don't unfortunately know how or if the printer can be restarted from this point. If I do i'll post here or if you manage to fix it please let me know. It has something to do with me cutting the roll and the roll passing the front edge sensor.
Jan 26, 2010 | Office Equipment & Supplies
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
Multiple vacuum leaks
your local library will have this information on your car and they will copy or print out the diagrams and more for you
Mar 01, 2009 | 1997 Ford Contour
Jagged edges and misregistration
What printer is it ? Some older ones need manual calibration, where patterns are printed, then you tell the system which is the best one. Newer ones can self calibrate, but still need it done. Go into your printers menu and see if you can find something on calibration or allignment.
Jul 18, 2017 | Konica Minolta bizhub 350 All-In-One Laser...
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Roland pc 60 color camm
look on www.rolanddg.co.uk and they might just help. i have just got a pc60 and the test print/cut is'nt working so i'm not a happy bunney. Andy @ YesIDoOwnTheRoad.com
Mar 31, 2008 | Computers & Internet
CANON PIXMA MP 460: PRINTING PHOTO- COLOUR PROBLEM.
change the print cartridge for color if yhat doesn't fix it get a new print head. Bob
Mar 28, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Computers & Internet Logo
266 people viewed this question
David Payne
David Payne
