Computers & Internet Logo
Posted on Nov 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Roxio easy cd & dvd creator will not install on windows vista
Anonymous
Level 3:
President:
  • Master 2,992 Answers
  • Posted on Nov 20, 2008
Anonymous
Master
Level 3:
President:
Answers
2992
Questions
Helped
1092992
Points
9665
That's very true of a lot of software. You need to buy a later version that is Vista compatible. If you purchased your program from Roxio, they might offer some kind of upgrade price. There are also several free open-source CD/DVD burner programs available for download that you could look into. A Google search will help you locate some possibilities.
7helpful
Is Roxio 9 compatibility with windows 7?
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Pc installed burner is not recognized by roxio easy cd & dvd creator 6
Hi there
Try to go to Roxio Support here :
https://selfserve.roxio.com/%28S%28heybe055ok2x3k45vykq4045%29%29/Login.aspx
I am sure they can help
IF NOT then return here
Hope that helps
Have a nice day
Please rate my anwer
2helpful
2answers
When installing Roxio Easy CD & DVD Burning in Vista message pops up saying the software is incompatible.
Yes, Roxio Easy CD is not compatible with Windows Vista. You either need to remove windows Vista and install Windows XP, or purchase the newest, latest copy of Roxio.
1helpful
Will not load on windows vista not compatable
Previous versions of Roxio or Sonic branded software that are not listed below as Vista compatible may run into compatibility issues. The following Roxio applications that work with Windows Vista are:
Easy Media Creator 9 and above
WinOnCD 9 and above
Easy CD & DVD Burning ("Vista Compatible" labeled boxes only)
RecordNow 9 and above
MyDVD 9 and above
You will have to upgrade the software to an vista compatible version:
http://kb.roxio.com/search.aspx?URL=/content/kb/General%20Information/000004GN&PARAMS=
Roxio Easy Media Creator 7.5 Platinum and Vista
What have you tried to install the software. I have found that many software CD's or DVD's need to simply be opened by right-clicking on the drive's icon and selecting the 'Explore' option. When the disc icons are shown, select the Setup.exe or Autorun.exe and the software will install. If after installing the software doesn't run, try running it in compatibillity mode for Windows XP.
1helpful
2answers
Have Roxio 7 and want to install it on Windows Vista
Easy Media Creator 7 is not supported on Vista. Easy Media Creator 9 and above are only supported. Anything lower may be able to go onto Vista, but Tech Support is not going to be able to assist you if you have problems.
2helpful
Cannot Initialize API
1. Try to launch Creator Classic to see if it can repair the engine files. a. Double click on the "Roxio Easy Media Creator Home" icon. b. Click "Creator Classic" under the "Applications" section. c. The Windows installer should launch and ask you to insert your installation disc
Try this and see how it works, if it does not, contact me and give me more details
2answers
Driver
Download and install adobe reader for manual, if needed
use Get Adobe Reader button on this page
http://www.adobe.com
Manual link (two choose based on directions)
http://www.bushnell.com/customer_service/manuals/binoculars.cfm
There may be no driver required for vista for the USB access to the camera.
However one of the manuals indicate Roxio may provide updates for photosuite. No assurances there are that either link to provided software is applicable to your version however generally updaters will not update the incorrect software. There is also no notation that these are or are not Vista Compatible.
This Vista support link may help
http://kb.roxio.com/content/kb/General%20Information/000004GN
This Update is PhotoSuite Version Specific, you will need to find the version of PhotoSuite installed on your system before selecting the update.
To find the version of PhotoSuite that you have installed first open PhotoSuite and then Go To "Help" and then to "About Roxio PhotoSuite", once the About box opens you will find the version at the bottom center.
If you have version 5.1.2529.0 or higher this update is not needed.
Updates the PhotoSuite components of Easy CD & DVD Creator 6 PhotoSuite version 5.0.1366.0 only.
Note: The latest Easy CD & DVD Creator Engine update should have already been installed.
(This update will take 5 to 20 minutes to install, there is no progress bar, so you should not interrupt it.)
Download
Updates the PhotoSuite components of Easy CD & DVD Creator 6 PhotoSuite version 5.0.1419.0 only.
Download
Update PhotoSuite 7 Platinum to 7.0.430.0 (English Only)
Important Note:
This updater is intended only for the stand alone version of Roxio PhotoSuite 7 Platinum. If your version of PhotoSuite 7 was included with Easy Media Creator 7 then please (use those listed above) for the correct updater.
Download
2answers
Roxio
do you have a CD\DVD burner installed hardware?
Grand Canyon Tech
Grand Canyon Tech
