Question about Sony Audio Players & Recorders
Sony str-av850a receiver back channel (b) not working
Hi my name is Mike and my back channel quit on me while listening to music.Is there a fuse for that channel?Thanks for your time.
Mike.
SOURCE: Sony STR DG 510 receiver manual
Hey there, found it on the sony site...
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=STRDG510
Hope that helps.
Posted on Oct 19, 2007
  • 15 Answers
SOURCE: Sony STR-DE945 5.1 Channels Receiver
Hi, Happened across this forum looking for some remote info. Had a similar problem with my 945...main speaker outputs started to click off & on, no rhyme or reason. Found that the solder joints on the speaker output relays were cold (poor soldering). Actually happend twice, two different relays. Took me a while to find it, reflowed the solder, that solved the problem, over two years ago now. Are you able to dig into the receiver? Do you have a (good) soldering iron and some solder? If not take it to elec. shop and tell them to look for cold joints on the relays.
Posted on May 11, 2007
  • 520 Answers
SOURCE: Sony STR-AV770 AM/FM Tuning
If your going to buy an antenna you could do some research at cccrane.com. They might be able to help you with the other problem too.
Posted on May 15, 2008
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
SOURCE: left channel is out sony STR-D511
Had the same problem but found simple solution. I just reconnected the speakers which were on "A" connections to the "B" set of connectors immediately below - problem solved!
Hope this works for you.
Stuart
Posted on Jan 22, 2009
How do I adjust the treble and bass on sony str-dh520?
See EQ Mode on page 59 of the owners manual to set the bass and treble for the front speakers, presumably for 2 channel mode. For multi-channel mode there are several pre-programmed audio modes listed starting on page 43 and music mode starting on page 44.
https://docs.sony.com/release/STRDH520.pdf
Mar 02, 2015 | Sony STR-DH520 A/V Receiver
Tune stations on the radio
Use this link to see how to set up and listen to AM/FM stations.
How to listen to FM and AM broadcasts
Dec 18, 2014 | Sony 7.2 Channel 4K Black A/V Receiver -...
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Mar 21, 2010 | Sony STR-DE675 Receiver
Input from IPOD - I want to play music from my IPOD through my Sony STR-DE1075. I have an IPOD line out adapter. cannot figure out which input I should be using.
Any input as AUX , DVD or Tape will work fine ..whichever you connect.and/or available...But please do not ever use the "Turntable" input...make sure volume of IPOD is half way open as listening earphones not max..good luck..
Jan 07, 2010 | Sony STR-DE1075 Receiver
Sony Receiver STR-DE305
It's very likely it is a fuse - does it work with any other speakers or headphones? Is there any reset on the back of the receiver? If not, unplug it, remove the cover and check the fuse(s).
Rate if this helps :)
Mar 04, 2009 | Sony STR-DE305 Receiver
Sound turns off for Sony STR-DE875 amp
If you do not here a click as soon as the power is turned on, (note you must be in a very quite environment no noise absolutely to hear this) then the amplifier has blown output transistors which are pushing DC current to the speakers.
Aug 31, 2007 | Sony STR-DE875 Receiver
Sony Receiver has little sound on radio stations
have you adjusted your sound settings while in listening to the radio mode?
Jul 30, 2007 | Sony STR-DE875 Receiver
SONY STR-DE305 FUSES
are these the speaker output fuses...if yes, they should be on back panel. if no, then are you also looking for board mounted fuses on the pc board?
Jun 01, 2007 | Sony STR-DE595 5-Channel Amplifier
83 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
