Question about Belkin (F5D7010) 802.11a, 802.11g/b Wireless Adapter
Utility not displaying to select network
Purchased a used laptop and had to clean drive and reload operating system (Windows 2000 Professional). Before reload this card and it's utitlities worked perfectly. After reload downloaded drivers from Belkin website and installed. The installation didn't go well and contacted Belkin directly and received a CD with the drivers which I installed and that went well. The card works just fine. I can hook up to my neighbor's unsecured network no problem the system does this all by itself when I boot up. I cannot bring up the screen that will allow me to select the network I want to hook up to (like my own secured network). When I click on it the screen flashes for a moment and then disappears. It shows in task manager that it is running and so on, just no way to access it. Have already talked to Belkin 3rd level support and they are also stumped. It should also be noted that when trying to uninstall a C++ run time error occurs. Any ideas?
    President:
  • 2,961 Answers
I don't know what it is with Belkin and their drivers, I have the same problem with their USB adapter. It usually takes a couple of goes to get their utility to work. When you are installing it make sure Windows is installing it from your cd and not the generic one. If you cannot uninstall it; it has not installed itself correctly. If you are unable to remove it, search the Belkin folder and manually delete, then download this free excellent programme to remove all traces of Belkin then try again. http://www.filehippo.com/download_ccleaner/ If Windows 2000 driver doesn't work for you try Windows XP driver.
Posted on Dec 14, 2006
Factory reset acer aspire 5315 gone wrong
I think you need to reload windows with a operating system disk. Most times the Factory Recovery discs don't work.
Get a windows operating system disk and just reload windows. The disk must match the Certificate of Authentication (COA) sticker on the bottom of her laptop. In other words, don't use a Windows XP Home operating system disk if the COA sticker says Windows XP Professional or you'll never be able to activate windows.
May 06, 2012 | Acer Aspire 5315 Notebook
I need to know how to format the harddrive on my Inspiron 1525 laptop.
The fastest way to do it is by inserting the operating system install disk and select clean install and format the hard drive from there you don't have to install the operating system its a utility built in but if you format your hard drive it will erase windows or what operating system you use.
May 03, 2011 | Dell Inspiron 1525 Notebook
My acer laptop turns on, then tells me to contact the systems administrator. If I try to continue it shuts down. at one time I recall reading that the files have been currupied. is there anything I can...
It sounds like the Windows boot files have become corrupted. That could happen for several reasons, but if you're willing to just reformat/reload the operating system, we're only concerned with one of those reasons.
There are some viruses that can corrupt boot files. If that's what happened, then reformatting/reloading the OS will take care of it.
On the other hand, it could be that your hard drive may be failing. When you reformat/reload, the Windows system will tell you if it finds errors on the drive.
The following is from the Acer manual for your machine as to how to access the BIOS and enable a hard disk recovery:
To activate the BIOS utility, press during the POST; while the notebook PC
logo is being displayed.
Boot sequence
To set the boot sequence in the BIOS utility, activate the BIOS utility, then select
Boot from the categories listed at the top of the screen. [You should set the CD/DVD drive to be the first boot device, in case you need to reload from a DVD]
Enable disk-to-disk recovery
To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the and keys to set this
value to Enabled.
[End of manual quote]
If you're not able to restore from the hidden partition on the hard drive, which may happen if the drive is damaged, then you'll have to try to restore using a Windows DVD.
Hope that's helpful.
Jan 12, 2011 | Acer Aspire 3680 Laptop
My computer runs so slow and cant play my games on count of it. It needs cleaned up bad and i dont know how to do it. Please help me.
Backup all your files (E-mail, address book, music, license-keys for purchased software),
writing either to DVD-recordable disks, to an USB memory-stick, or to an external disk-drive.
Then, reinstall Windows, "wiping" everything from your disk-drive.
Run "Windows Update" (repeatedly) to get all the latest security-updates.
Reinstall anti-virus software.
Reload your files.
Reinstall the purchased software.
Reinstall the free software (Adobe Reader? WinAmp?).
Nov 13, 2010 | Microsoft Windows XP Professional for PC
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
Will not print correct as a network printer
1. Define your Star Micronics Printers device model TSP600
2. Define your operating system to install your Star Micronics Printers device
3. Search Printers driver category
4. Find Star Micronics Printers driver
5. Select Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
6. Download Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
7. Install Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
8. Restart or reboot your computer to finish your driver installation.
Download here:
http://www.opendrivers.com/driver/247183/star-micronics-tsp600-printer-network-setup-utility-ver.-2.0.1-windows-xp-2000-me-98-95-free-download.html
Aug 16, 2010 | Star Micronics TSP600 Thermal Printer
I have recently purchased the wire/wireless
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here
for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 05, 2010 | Edimax Computers & Internet
Trying to download Windows 2000 Registry Repair Utillity?
why are you using Windows XP boot disk instead of Windows 2000???
Nov 08, 2008 | Microsoft Windows 2000 Professional for PC
Cannot connect to my laptop with a built in wireless.
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Jul 13, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
How to change IRQ settings
In windows we dont have any in built utility but you can easily download some utility to change the IRQ number. Good luck
Sep 13, 2007 | IBM Think Centre A50 P4 (841923u) Network...
Belkin (F5D7010) 802.11a, 802.11g/b Wireless Adapter Logo
187 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
