Question about Toshiba 53HX71 53" Rear Projection HDTV-Ready Television
TV gets blurry and fuzzy after a few minutes and stays that way.
My 6 year old Toshiba 53HX71 rear projection TV shows a fuzzy picture a few minutes after turning it on. The shape of objects and their colors can be seen but very blurred. The sound is fine.
This problem does not happen every time though. Sometimes I turn on the set and it works fine. I've pretty much eliminated any cable connections as the propblem.
I don't really want to spend 2 or 3 hundred dollars (or more) to fix the problem. I would rather put that money towards a new LCD TV. However, if I can get away with an inexpensive fix, I will hold off another year or two before purchasing a new set. Any help would be appreciated.
techman
  • 3130 Answers
SOURCE: Toshiba 65hx81 65" Rear Projection tv. black & white color/green
Yep, your problem is a relatively easy one to repair if you know how to solder. You better repair it before it blows the fuse though. There are two capacitors in the main power supply that are coming loose and need to be re soldered. There is a Toshiba service bulletin about it. They are marked C809 and C810 on the main power supply board. Good Luck
Posted on Sep 05, 2007
MikeMaierTV
  • 206 Answers
SOURCE: Toshiba TV repair
You say it's a DLP yet the model number shows as a standard projection, anyway what you seem to have is a Hyper board problem, many shops can repair this Fragile board but it's not for the weekend tv tech to try to do
Posted on Feb 13, 2008
SOURCE: Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Posted on Apr 29, 2009
Sparko1
  • 167 Answers
SOURCE: 52 inch Toshiba rear projection no picture has sound
You have bad solder connections in the deflection circuit. Call a good TV tech unless you know what you are doing. You could get an electrical shock from a charged capacitor.
Posted on Jul 29, 2009
SD Tech
  • 14553 Answers
SOURCE: Panasonic PT-47WXC43G Red Color problem
This is a convergence problem; in the customer menu there is an option to adjust it----if red or blue will not move in some direction---one of the two convergence IC's is bad and both need to be replaced.
I have step by step instructions telling what you will need for this repair. They are in Microsoft word----let me know if you want them and I will email them to you. You can buy both chips for this set on Ebay for about 13 dollars plus shipping for a pair.
etower.766@netzero.net
I do this here for free so if this has helped you take a moment and give me a vote here.
SD TECH
Posted on Sep 03, 2009
Testimonial: "Thanks I appreciate the info. Very quick response."
My Toshiba 53HX71 takes about 20 minutes to "warm"
This is a symptom of poor solder connections inside the set. The set will continue to deteriorate until it won't turn on at all. This is essentially a labor only repair and should not be to expensive for any TV service shop. Once this has been repaired, the set should work for many years to come.
These poor connections are caused by the continual heat/cool cycles because of use and is normal.
Dan
Apr 09, 2011 | Toshiba 53HX71 53" Rear Projection...
Picture "pulsates", becomes small and fuzzy
Ur convergence is dead.Need to buy the convergence kit use it parts.U know how to solder right?Tries these websites Ebay.com,Tv Repair World.com,or Shopjimmy.com.
Sep 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
Lost picture
sounds like video card failure mode, 101..you a technically adroit person?
Apr 03, 2008 | Televison & Video
1/2 the screen is blurry
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 15, 2008 | Toshiba 53HX71 53" Rear Projection...
Toshiba TV repair
I have a Toshiba HD LCD tV, model 37AV50U. the screen is black. I still get audio and can change the channels but the screen stays black. It doesn't even show the menu box. Is this something I can fix myself?
Dec 23, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 50VS9UA
Can you assist us in an overbright picture tripping after a few seconds. Toshiba 50VS9UA. Sound Normal
Dec 12, 2007 | Toshiba 53HX71 53" Rear Projection...
53HX71 showing lots of green
im thinking blue lamp if whites look pink thats telling me theres not enough blue.
Dec 05, 2007 | Toshiba 53HX71 53" Rear Projection...
Video input
Needs Hyper board repair = replace bad caps
PCB not available to buy outright........................T.
Nov 10, 2007 | Toshiba 42H81 42" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 53HX71 53" Rear Projection HDTV-Ready Television Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
