Question about Panasonic NN-S443WF / NN-S443BF 1200 Watts Microwave Oven
Micro Wave shuts down
My Panasonic Micro Wave, model NN S443WF, shuts down after 20-25 seconds no matter what time or cooking style is selected.
  • 3 more comments
  • kpp6 Nov 25, 2008
    Thanks for your help and the voltage warning.
  • ridanna Mar 11, 2009
    Model Panasonoc Inverter NN-S543BF runs 20 to 35 seconds then shuts off Do you have a solution
  • Anonymous Mar 17, 2014
    I need manual for Panasonic convection micro wave nn-cd987w. Manual lost. Is this possible
  • Anonymous Mar 24, 2014
    it is in an r/v
  • Anonymous Mar 26, 2014
    Product code.MS3949C.CSLQSAF
  • Panasonic Master
  • 9,098 Answers
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Nov 24, 2008
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
No mater time salected only cooks for 17 seconds
i think you have a problem with your magnetron or the inverterpcb if your unit has inverter inside writen on the front it could be an expensive repair please contact me to let me know iffell up to tackling this repair as it can be dangerous
Dec 09, 2012 | Panasonic NN-T888S Convection/Microwave...
Micro wave starts and runs for 2 seconds then shuts down
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
Aug 22, 2010 | Panasonic NN-H275 Microwave Oven
Model JVM1650WH02 will shut off about 2 seconds or less into cook time. everything else works such as light and clock and sometimes the wave will cook.
magnetron is leaking internally, do not use until magnetron is replaced. the mag creates interference with the control board and resets it
Feb 05, 2010 | GE JVM1650 1000 Watts Microwave Oven
Oven won't heat and shuts down after approx. 20 seconds
Dec 18, 2008 | Panasonic NN-S763BF Microwave Oven
Microwave shuts down after 5 seconds
chech the control panel and wiring and thermal sensors..
Sep 23, 2007 | Panasonic NN-H965 Microwave Oven
3 second cooking time
It's possible a sensor or thermistor got unplugged during your work and didn't get plugged back in. Otherwise, I would suspect the microprocessor got "glitched". If so, *maybe* unplugging the oven from the power line for a few minutes will reset it. Or maybe the unit has a reset button or another reset procedure (I doubt that, but check the manual). Sadly, another common cause for this is that the code in the microprocessor gets irretrievably corrupted. In such cases, we can replace micro if it is available. It it's no longer available, that would make the whole microwave a goner. Looks like both the micro (LSI display) and the whole control board for this model are available from Panasonic parts: http://www.pasc.panasonic.com/epartr
Sep 27, 2006 | Panasonic NN-S954WF Microwave Oven
Panasonic NN-S443WF / NN-S443BF 1200 Watts Microwave Oven Logo
636 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
