Question about Dryers
Dryer never shut off and now does not heat up
I ran the dryer the other day when i left for work which i do occasionally to save time. But the other day i did it and when i got home around 6pm the dryer was still running. the clothes were dry but they were not warm, just tumbling around. Now the dryer runs but does not heat up anymore.
  • njrulli Nov 19, 2008
    I have the exact same problem with my whirlpool electric dryer it is just shy of 2 years old. Before I went to bed at 10:30 I turned it on and when I woke up yesterday morning it was still running but only blowing cold air. It turns on and rotates but does not heat up......
  • 367 Answers
Your timer has gone out. (this is a very common problem) If you get me the model number i can get you a part number so you can order the part from sears.com
Posted on Nov 19, 2008
Vaillant boiler leaking only when heating switched off.
It would seem a joint has come a bit loose from the heating and cooling cycle. put a drip pan under the leaking area( the drips would evaporate quickly), then next time you shut it down go through all the joints in the area with wrenches to find the loose joint.
Oct 27, 2014 | Water Heaters
Bosch WTVC3300 dryer keeps tripping reset button
If it keeps reseting, check if the ventilation house is clean, also check if the dryer blower is clean in convention with the filter conductor.
Jan 14, 2014 | Bosch Dryers
I have a gas GE dryer DPGT750GCWW ;- it only heats occasionally. Sometimes it will work all day, other times it will heat one load and won't heat up for the next load. The vent has been cleaned...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | GE DBXR463GB Gas Dryer
Hotpoint nvl333gyoww gas dryer's timer stopped working and ran for an extended length of time (about a day). After looking over the dryer, i noticed that during the no heat cycle the timer would work. So...
the timer : if you use time dry the timer should always move and complete the cycle. if you use auto dry the timer uses a sensor to tell the timer to move. If your not getting any heat your sensor might not tell the timer to move.
So lets start with the no heat problem. First make sure your Vent is clear or just disconnect the vent and put a pair of womans stocking over the end to keep the dust down, This will ensure you do not have a blocked vent. ((( If you have a blocked vent on a gas dryer the safty sensor will shut off the gas valve and you will only get a little bit of heat))) Now try the dryer for small load, ((( if this solved your problem then you have a cloged vent )))
If this did not solve your problem then the coils on your gas valve in the dryer are probably bad.
Sep 02, 2010 | Hotpoint NVL333GY Gas Dryer
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
Dryer ran for hours and did not stop automatically, now runs but wont heat?
Good day,
If set to automatic and there is no heat it will run continually run without shutting off. You'll need to trouble shoot the heating problem.
A lot of the problems are due to limit fuses and limit thermostats located in the back. Beyond that you'll need to supply the model and whether its gas or electric.
May 14, 2010 | Kenmore 500 6952 Dryer
MAYTAG PYE3200AYW, WILL NOT RUN, PRIOR TIMER PROBLEM
When it ran all night was it heating then? Are any of the breakers tripped? Are the connections secure in the back? But I believe if the heat was working when it was running, the timer may be the problem and they are simple to replace and not that expensive. If this unit is older than 15 years, then it may be time for a new one. The parts and time wasted may be better spent on a new one.
Jan 14, 2009 | Maytag PYE2300AY Electric Dryer
My dryer ran all day long. The timer was still in the same position as when I left the house. The 'regular' heat is now not working either, air fluff only.
one of the fuses in your house's fuse box is blown check both fuses for continuity and replace the blown fuse you only have 115 v coming to the dryer which will run the motor but wont run the heat or the timer let me know how you make out and dont forget to rate this suggestion thanks
Aug 05, 2008 | Maytag Dryers
Heat to start, then no heat..
replace both coils on gas valve ..those are the blacks things with wires attached they are bad for not pulling valve oper=n after warm up
Jul 02, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
