Question about Janome MC 4400 Computerized Sewing Machine
Machine stops ''for safety reasons''
I am trying to sew 5" squares together for a quilt using the special foot that makes a perfect 1/4" seam. I am using a straight stich (Memo 02) in which the needle is to the far left. Every so often (I never know when) the machine locks up and reads "Machine stopped for safety reasons".
I then have to re-thread the machine. When the machine stops, it jerks the thread out of the take-up lever.
SOURCE: My machine locked up
Have you ever oiled it?
Posted on Jan 09, 2008
  • 323 Answers
SOURCE: My JAnome sewing machine is 24 years old and has
Your machine has a timing problem and should be seen by a technician to repair it.It is possible that there is a loose part also.
Posted on Apr 30, 2009
SOURCE: quilting
Janome now has a darning foot ie it looks like an embroidery foot with a spring designed for the 1600 models. It is metal with a ring where the needle goes down through it. I removed the plastic lens inside the ring and this seems to have resolved the problem.
I usually pull my threads to the top so I can see where they are and not getting tangled underneath.
There are several good groups on Yahoo groups which offer support for starting out on quilting
Posted on Jun 05, 2009
SOURCE: 1471 Pfaff sewing machine will not reengage needle
I have a similar probllem except that I have the spring but am not too sure where it goes.
Posted on Aug 05, 2009
  • 1388 Answers
SOURCE: Is this machine a high or low shank?
High Shank Machines are all the Janome Embroidery models MC 8000, MC 9000, 10000, 10001, 11000, 200E, 300E, 350E....etc
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop.
Posted on Nov 12, 2009
Which presser foot is best to use for piecing quilt shop?
Probably the 1/4" quilting foot. It is designed so it's easier to sew a scant 1/4" seam by aligning the fabric edge to the foot's edge, which is what you need for piecing. Of course, to get it perfectly accurate, you may need to move the needle slightly or figure out where exactly 1/4" from the needle falls on your machine (important if you will be matching points in your piecing). Measuring 1/4" from the needle and then marking with a strip of painter's tape works for some.
3 Ways to Master the Perfect Quarter Inch Seam
Accurate Piecing Basics Quarter inch Seams WeAllSew
Nov 29, 2017 | Sewing Machines
What foot and setting do I need to sew strips of bias binding together.
If you are sewing bias strips end to end, any foot would work. A 1/4" seam allowance is probably fine. You'll probably just need to cut the ends @ 45 degree angles and match them up before stitching. Sewing them at 90 degree angles creates a big bulk of fabric whereas 45 degree angles spread the bulk out when applied to your cushion fabric.
Learn How to Join the Ends When Quilt Binding Tips from McCall Quilting
Mar 16, 2017 | Sewing Machines
I got a new Brother 1634D Serger and would like to make a quilt on it. How do you get a 1/4 inch seam? please help me
Don't expect a quilt to be as accurate from a serger as from a sewing machine. First, you probably want to focus a strip quilt where rows of strips are stitched together. If you do strips, you won't have to worry so much about maintaining an exact 1/4" seam. You can also vary the widths of strips in order to camouflage any seam variations. Avoid a pattern that requires points being aligned! Any seam width variances will not as obvious as an error (it is intensive getting an accurate 1/4" on a sewing machine--so-o-o-o much more difficult on a serger). There are usually seam width marks on a serger that you can follow as a guide, but straight line serging is very difficult to accomplish. You can always try marking a line on your serger using painter's tape.
FWIW, making a strip quilt on a serger is a fast way of finishing a quilt. I divide my quilt into 3 or 4 sections, like making it in thirds or fourths. That way, when the quilt begins to grow, you are not constantly grappling with flipping or turning the heavy and bulky fabric. Instead, do each section separately, then stitch the sections together to make the whole quilt.
Also, be sure to press all the seams of a strip quilt in the same direction.
Strip Quilt Patterns
4 Free Strip Quilt Patterns That Standout from the Crowd Fons Porter
How To Sew An Easy Strip Quilt
Make FAST Serger Strip Quilt with 1 4 square Triangles
Feb 27, 2017 | Brother Sewing Machines
What foot should i use for quilting. i have a brother vx-1435
Your best option will be a "walking" or "even feed" foot. Your Brother dealer should have them in stock.
Mar 02, 2015 | Brother Sewing Machines
While trying to free motion quilt on my juki TL-98Q, it becomes very hard to move the quilt whenever I come to a seam. I have already turned the pressure foot dial to the lightest setting. I simply
I have never used a machine to free motion quilt. That said, I have had issues sewing over thick seams. Since your machine runs smoothly otherwise... I think it is the thickness of the seamed area that is causing your problem. It may be too late but you could try trimming your seams so the layers fabric graduate to full thickness. Or you could use a chop stick or popcicle stick to press down on the thickness as you guide the machine over the seam. I also suggest that you Fan your seam allowances where your blocks come together. You can see how that is done here.
Mar 19, 2014 | Juki TL-98Q
Viking Husqvarna Sapphire 830. I am not able to get a true 1/4" seam using the clear 1/4" Piecing Foot with Guide. The needle space in this foot only allows for the needle to be in the center location. ...
Unfortunately, in reality, most 1/4" presser feet do not guarantee a perfect scant 1/4". There are multiple ideas for achieving a more accurate scant 1/4" seam.
This is the method I use. Use a quilting ruler and place it under the presser foot and then gently rotate the handwheel until the needle point rests exactly a scant 1/4" from the ruler edge. Then place a strip of painter's tape on the sewing surface adjacent to the edge of the ruler. Then use the painter's tape as your fabric guide.
Scant 1 4 seam allowance
How to sew scant 1 4 inch seam Kreations by Julz
What Is Scant
I have an old EuroPro Sewing Machine and lost the user manual years ago.I am trying to figure which accessories to use for quilting. Can you tell which accessory and where it goes and other recommendations...
Try this website, it has lots of good info on feet and where you would use them. This should help you identify the feet youve got. Many machines will have a zig zag foot with room for the needle to swing, a zipper foot, a blind hem foot and a buttonhole foot as a basic selection. There are lots of others too for specialised techniques such as rolled hem, overcasting or tuffting.
For Quilting though you actually can get away with just a straight stitch foot to piece the fabric and a walking foot if you are going to machine stitch the layers and batting together. This is a walking foot.
tally_girl_73.jpg Having a quarter inch foot is very handy to achieve perfect 1/4" seams for piecing.tally_girl_74.jpg
Lastly, if you want to try stippling or free motion quilting, you'll need a special foot, and it will probably look a little like this.
To purchase you could try
Sep 11, 2011 | Euro-Pro Sewing Machines
I'm trying to use the Janome 1600P DBX for quilting. A repair tech. went through the machine and cleaned, oiled and set the tensions. It looks like the tensions are set right but the thread breaks after...
I would try this -
Make sure you are not using quilting thread for hand stitching.
Thread the machine with the presser foot up.
If the machine is stitching seams without a problem and the breakage happens with thicker fabrics, it could be the presser foot is not down below where it is closing the tension to the setting of choice.
When the presser foot is up, the tension control opens. When the presser foot is down, the tension control closes to the setting you have chosen.
If this continues, call the dealer/tech and tell them the problem you are having.
Mar 06, 2010 | Sewing Machines
If you want to piece quilts, I recommend a 1/4" piecing foot. Husqvarna make several different types that may be used on the Rose.
If you want a dual feed or walking foot, check out the new Interchangeable Dual Feed foot.
You only use card with the Rose for embroidery, which you can do on a quilt, but not necessary.
Feb 04, 2010 | Husqvarna Sewing Machines
Sewing Machines Logo
41 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
