Home | ASUS | P4PE Motherboard | Asus P4pE not booting.
ASUS P4PE Motherboard
Problem for ASUS P4PE Motherboard
By Bigbudda on Dec 13, 2006
Hi!
i have this really odd problem. my Computer is 2 year+ and have worked properly until now. when i came home sunday and turned my computer on. it just boot then died. Cpu, fan including Gfx fan just spinned a couple of turns then *blurp*
When i now tried boot the computer a couple of times. nothing happened. so i opened it up. unpluged all of teh devices /Gfx, ram, hdd, dvd / when i then tried to boot up again. it starts bu after 10s theres a VERY strange beep-call sounds like a police car!
i cnat do shit. i have read teh Bios manual over and over again.
what to do? :/
Comments:
Dec 14, 2006
- thank you for your quick Answer, really appreciated :)
well thing is. its like a loop with this beep-code and the manual says: "Hi Frequency beeps wheb the system is working = CPU Overheated: system running on a lower sequence.
or: "Long beeos in an endless loop RAM installed or detected"
i tried to unconnect the memory and beep was one single "note"
when i dont have anything connected and boot all fans and HDD boot but there is this "police-Car" beep *duu-duu-duu*
and i am a question mark.
regards
Same Problem
Mar 07, 2009
-   after flashing my bios (p4pe-x) from 1004 to 1007 computer won't start...
after turn on....1 long beep 2 short beep.....then 2 different tone of short beep again
I've tried to taking out the battery, and use the CLRTC to position 2-3 for 10sec and move back to position 1-2
nothing I do works....I'm fraustrated please help!!!
teknodogg@yahoo.com
aim popxpop
msn teknodogg
-   teknodogg
Nov 06, 2008
-   same-   Guest
Jan 18, 2008
-   Hi!
I have an Asrock M226a Motherboard and i have same problem. When i heave rebuild my computer in another hous and with a new vidoecard. I have reset te bios memory battery and after it i cant do enithing! no bip songs and no signal on monitor. pls contact my if you can help on my at cznorman@t-email.hu Thx so much!-   Guest
Solution #1
posted on Dec 14, 2006
Somewhat Helpful)
tomj23
Rank: Guru
Rating: 87%, 1813 votes
The beeps you hear are probably BIOS error beep codes. Through a series of long and short beeps the BIOS communicates what type of error is occurring during the initial stages of the start up process. If you can tell me the manufacturer and model number of the board AND the sequence and length of the beeps I can point you in the direction to go.
Was this helpful?
Yes
No
Solution #2
posted on Aug 12, 2007
Not Helpful)
CanDo
Rank: Wiz
Rating: 81%, 172 votes
Obviously you have a piece of hard ware gone out. Pull them one by one trying each time after removal until you find she runs fine again then replace the faulty hardware and you should be back on track.
Was this helpful?
Yes
No
Solution #3
posted on Apr 22, 2009
Not Rated)
halltech
Rank: Apprentice
Rating: 0%, 0 votes
I have the same issue with an ASUS P4PE-X. I could not come up with a better description of the sound than police car. Anyways, we had a damaged CPU (from over-heating). Replacing the CPU solved our problem, and the system POSTs fine now. A little late, sorry.
Was this helpful?
Yes
No
Popular Solutions for ASUS P4PE Motherboard
Questions and Unsolved Problems for ASUS P4PE Motherboard
Do you recommend ASUS P4PE Motherboard?
Answer
Answer
nesecito resetera la placa madre a7n266-vm
Answer
asrock wolfdale 1333-d667 display color bars or display disappears after boot or will work for a... (More)
Answer
had root canal saturday tooth chips sunday
Answer
buenas noches, temgo una board msi_k9mm_v_ le acabo de cambiar el hd tenia uno de 250 gg y se lo... (More)
Answer
I just bought a abit kn8 sli motherboard from an auction. I only have one video card so I need the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ASUS P4PE Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14773
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
