F1 error code
This is unbelievable. This washer is 1.5 years old. I was told it was top of the line. I looked up to see what this error code is and I find out everyone is having the same problem. There has got to be something we can do. I have to Pause the washer and then start again. Sometime that works. Sometimes I have to switch it all the way to rinse and spin and go throught the motions there. I am calling tomorrow....... I have a Kenmore Elite Oasis and the F1 error code continues to happen 5 minutes after pushing start. Today, it happened before the spin cycle.
  • Anonymous Jan 10, 2009
    I have the same problem. My kenmore elite oasis is less than 2 years old and continues to get the F1 error. Sears has not been helpfu. Looking for a new machine, but don't want the same digital control board. Apparently, that's where the defect is. What other manufacturers use the same control panel?
  • denisehegs Jan 17, 2009
    FI error code....I've been getting this error code for about 2 weeks now and I have to stop the machine completely turn back on and hit drain and spin.....
  • 370 Answers
Call and complain a lot. There is a class action lawsuit agaisnt whirlpool (whirlpool made the oasis) for this problem. It is a faulty control board. Some people have gotten sears to pay for the repair. Try that. good luck!
Posted on Nov 19, 2008
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
I have a whirlpool duet 2 1/2 years old I t has started to make a loud buzzing hum sound (that sounds like old top loader mixing valve malfunction?) and has error code 5d what is this ?
Actually, your error code is "Sd" and indicates that the washer thinks that there are too many suds in the basket / drum.
Your buzzing sound is also likely to be the water inlet valves, common to top loaders as well, as the washer is adding additional water to rinse excessive suds out. Check your supply hoses for kinks, connections for scale buildup inside, as well as the screens on the inlet ports of the washer itself.
A kinked or restricted drain hose can also throw an Sd error code as well.
Jun 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Should we buy a cabrio?
Its recommended to buy whirlpool washing machine they are having the spares for their old model also when compared other brands
May 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code
This is from a service bulletin. This may be of interest to you. I agree with you that fancy doesn't necessarily mean better. Anyway, I sympathize and hope this helps. Best wishes.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 – CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
Aug 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F-1 Error on Whirlpool Cabrio Top load
Called 1-800-253-1301. Spoke to a woman named Valerie in customer service. She told me there was a quality issue associated with the F1 fault code and they would take care of the repair parts and labor at NO CHARGE!. My machine is 28 months old.
Apr 06, 2009 | Whirlpool WTW6400SW Cabrio Washer
F1 error code on cabrio washer
CALL 18002531301 AND TELL THEM YOU HAVE THE F 1 CODE PROBLEM. THEY HAVEN'T CALLED THIS A RECALL, BUT THEY ARE CALLING IT A CUSTOMER AWARENESS PROBLEM.
WHIRLPOOL IS SENDING TECHNICIANS OUT NEXT DAY FREE OF CHARGE.
T W
Feb 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code
replace control module under console
Nov 06, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Getting F02 error, machine stops part way in & beeps.
Thank you so much for posting your solution of the F02 error code. I was having the same problem and noticed that my clothes smelled like mold and I didn't understand why. Anyway, my husband "cleaned the filter". He found four socks.
Awhile back, I noticed that I was missing a lot of socks. One day I pulled the gray flap in the washer and found around 15 socks! I now check that flap after every wash.
Again, thanks for posting your solution. It was an easy fix and it saved us $$.
Oct 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer problems
Replace the computer yourself. takes 20 minutes very easy and part is about 150.00, I did mine.
Jun 10, 2006 | Kenmore Oasis HE 27062 Top Load Washer
Washing Machines Logo
290 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
