Question about Whirlpool LER4634J Electric Dryer
Whirpool dryer weird vibrations, took it apart, checked belt and motor mount for looseness. All checked out good. Drum maybe loose?
    Genius:
  • 1,028 Answers
Ck blower for lint or debris causing it to run out of balance
Posted on Nov 20, 2008
Dryer turns on but drum will not spin
Sounds like the belt is bad or the motor needs to be replaced. Unplug unit. When you open it up get a block of wood (a piece of 2x4 works) if your units are stacked on top of each other, pull the dryer towards you approx 2inches. You are going to push on the top of the dryer and insert the board underneath the dryer. The reason you pulled the dryer forward was to keep the dryer from slipping backwards while working on it. Now check the two bottom corners on the front of they dryer.occasionally there are screws holding the kick plate. Take these off, pull out and down and look for broken belts. Be sure to vacuum any loose lint while you have the unit open. Good luck.
Jul 14, 2014 | Kenmore Elite HE4 Electric Dryer
Replacement igniting replacement
If you can hear motor running, it is possible the belt (from motor to drum) has broken or is slipping. If you cannot hear motor, it is likely an electrical problem; maybe safety start/stop switch in door, or wire connector has vibrated loose, or computer brain failure.
Dec 25, 2013 | Dryers
How do take my fisher and paykel AD55 clothes dryer apart to check the if the belt is loose or not, because sometimes to have to manually turn the drum in order for it to start spinning again. Heat and...
sounds like the maybe the drum roller or motor, here is a video. Hope it helps Tim:
http://www.appliancerepairlesson.com/2011/03/05/fisher-paykel-dryer-access-3/
Apr 15, 2011 | Fisher and Paykel DEGX1 Electric Dryer
The belt has come off the dryer and I can't figure out the configuration to put it back on, therefore the dryer wont turn
Some of the belts are counterintuitive to reinstall. although there are several different styles there are usually four - five components: Drum, belt, motor pulley and the spring pulley (sometimes there is a also a stationary pulley). Please double check but a lot of dryers have a diagram inside the dryer housing. If not, place the belt around the drum then the stationary pulley (if equipped) then the motor pulley and finally the spring pulley. Try to support the drum loosely if the spring pulley gives you a problem, on some models the motor mounts are adjustable, which you can use to reduce the strain. (You can always adjust it after the drum and pullies are secure) Hope this helps. Good Luck!
Douglas
Jan 28, 2011 | Dryers
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
My LG dryer does not spin...everything gets hot and works except either it spins VERy slowly or not at all
Open the back to get to the motor and check to see if the belt is loose on the motor pulley. Try to turn the empty drum by hand--does it seem bound up? Turn the motor pulley, does it seem hard to turn? Maybe the motor pulley is loose on the motor shaft. Run the dryer for a short time to watch the action of the drive belt.
Sep 27, 2009 | LG DLE0332 Gas Dryer
My kenmore gas dryer drum doesn't turn
Can you hear the motor running? If so, the drum drive belt has come apart (from the heat) and is lying loose. You will need to release the drum in order to get a new belt over it, then coupled and tensioned at the motor pulley.
Aug 25, 2009 | Dryers
Vibration on 2003 Altima 2.4
first check motor mounts ,them put in drive with the a/c on if you feel vibrates check the alternator some times have vibration and the mechanic made the mistake and change the pully.
CHECK THE ALTERNATOR
Jun 30, 2009 | 2003 Nissan Altima
Dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
May 28, 2009 | Kenmore Dryers
Drum doesn't turn in maytag neptune MDE9700AYW
Just remove the screws around the vent tube in the back and you can see the belt tensioner laying there on the floor of the dryer.
Most likely someone turned the drum the wrong direction and the belt came off.
The belt goes through the opening in the tensioner and under the idler pulley and then onto the motor drive pulley. Make sure to have the tensioner mounted into the floor first.
It just slides over into a slot and then over to the other side as tension is put on it.
Jan 13, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Whirlpool LER4634J Electric Dryer Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
