Question about Whirlpool 71001872 CNTRL-ELEC
Dim numbers but oven seems to be working ok
The clock numbers are very dim but the oven(s) seem to be working OK. This unit was replaced once before about 5 years ago with the same symptoms. All the tech did was replace the module for $225.  I was reluctant to do that before because once I bought it I owned it.  Any ideas of a fix without spending min $140 for a new module?
  • Anonymous Nov 27, 2008
    Same story here. $175 for a new clock board 5 yrs ago. Now looking at the same problem once more.
    New Friend:
  • 5 Answers
A replacement clock unit is available but costs $150-200 and is rather simple to replace - I've replaced mine twice in the past 5 or so years.The original and replacement both began to dim at 3-4 years and eventually became so dim they were unreadable.
Someone here, I believe, suggested that one or more of the capacitors may have became defective due to the high temperatures above the oven. Replacements for the four suspect capacitors were very reasonably priced but it was difficult locating appropriate high-temprature capacitors.
The only trick to removing and replacing the clock unit is the ribbon connector on the clock circuit board. There are very small plastic ears or tabs at the extreme ends of the connector. Press toward the center of the connector and pull away from the board (about 1/8") to release the ribbon cable.
Replacing capacitors C3, 4, & 7 is straight forward EXCEPT the circuit traces are prone to pull from the board (use as little heat as possible, wick as much solder as possibe before trying to dislodge the capacitors, and watch polarity). C1 a BIG challenge since the solder side is under the display assembly. I used a VOM to locate alternate connecting points on the component side of the board and just let the leads support C1.
Total repair time was about 1-2 hours and savings around $150 - AND it now works perfectly.
Posted on Apr 30, 2009
  • Tom Bates Mar 22, 2011
    Capacitor/Value/Digi-Key part no: C1&4/470uF,35V/P13130-ND; C3/68uF,35V/P12926-ND;C7/
    22uF,50V/P13132-ND.
    Radial mount (axial might work) rated at 105 degrees Centigrade. The capacitor numbers
    are printed on the circuit board.
I have the same identical problem. I replaced the original unit in 2004 due to a failure of the display panel. Now in 2009 the replacement unit has become extremely dim, though the board functions normally. I will pull the unit this weekend and see if I can find the appropriate capacitors on the http://www.alliedelec.com/ website (that's Allied Radio for you old-timers...) Do you happen to have the capcitor values and temperature limits available for posting here? Thanks for the assistance with this annoying problem!
Posted on Jun 06, 2009
  • KL4E Jun 08, 2009
    Follow-up to my comment from yesterday: I have ordered a replacement unit from Appliance Zone for $114.47 - the cheapest price I could find on the Internet. Here is the link to the description of this part as follows:
    http://store.appliancezone.com/servlet/D...
    With shipping to Alaska for a reasonable $8.95 added in, the total cost works out to be $123.42 for this clock timer unit. I will install the new unit upon arrival and remove and replace the defective capactors from the old one. That way I will have a good spare in bench stock ready to go when the operational one goes belly-up. This procedure has more up-front cost, but a whole lot less heartburn from the rest of my family about the oven being out-of-service while I was waiting for replacement capacitors to be delivered to our location by express dogsled!
    Capacitor Value Digi-Key part no.
    C1, C4 470uF, 35V P13130-ND
    C3 68uF, 35V P12926-ND
    C7 22uF, 50V P13132-ND
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Fgmv174kfb dim display
The owner's manual (here) does not mention that as a feature, so I would assume the oven has a defect and would need to be returned to your dealer to be exchanged under warranty.
Oct 25, 2012 | Microwave Ovens
Just replaced ite control board on my microwave and got all my buttons to work, but now the clock display is dim in the middle only.
please follow the troubleshooting chart attached and proceed with common sense: God bless you
Jul 19, 2012 | Microwave Ovens
My Timex t600 clock radio too dim. Love it, but I'd like to see it at night... Brightness control is at maximum...
Hello
The backlight LED of your Timex clock has got weak. It should be replaced. But it is really a skilled work as, you have to disassemble the display unit. If you are aware in electronics and have skill to do this work, you can do it by yourself. Otherwise, it will be best to get it replaced by any experienced service technician. OK.
Nov 20, 2011 | Timex T433 Clock Radio
The digital control display is extremely dim
your model should be a jjw9527AAW.... usually when that clock assembly goes dim u must replace that clock ... for your model it is a part number #71003424.. that clock on sears.com is for sale at $186.06.. call around or shop around for a bettter price remeber shipping charges through sears though and prob take longer to get ahh nevermind ur call...ohh yea kill the power before servicing or call for service... hope this helps take care
Jan 28, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
F7 shows on display and display getting dimmer over months
Dim display is TOTALLY independent of F7 error.
The display will dim as the display board capacitors wear out - due to the heat. Replace the capacitors on the display board (see my other posts) and your be able to see the F7 error code as bright as can be!
Jul 16, 2009 | Thermador SC302T Electric Double Oven
Dim display.
The display sits on a circuit board. Pull the board out and replace capacitor C3. It is 68 micro farads. I used a 47 from Radio Shack and it works great. If you can find a 68, that would be ok too, of course!
Oct 12, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Dim Digital Display
Connie P, Unfortunately it is not possible to make the display brighter. The only solution is to replace the entire clock/timer. The price for the part is less then a hundred dollars and if you will give me the complete model number and a color, I can help you to find the best deal. Gendos...post back
Jan 06, 2007 | Frigidaire FEF326 Electric Kitchen Range
Whirlpool 71001872 CNTRL-ELEC Logo
733 people viewed this question
Top Whirlpool Hardware & Accessories Experts
Joseph Mueller
Joseph Mueller
Are you a Whirlpool Hardware and Accessory Expert? Answer questions, earn points and help others
