Toshiba 37c60 tv
In response to your question it is the composite video inputs.
    Scholar:
  • 146 Answers
This is a uncommon problem. With the S-video working good and the composite not working, this means that the "comb filter" is bad. You may want to let a repair shop do it for you.
Posted on Nov 19, 2008
Where is the yellow video input?
The video input is Green. Then you use the red/white for audio. The TV has to be set for Composite Video input when using the green. If you use the Green/Blue/Red for video it is set for Component input.
Apr 18, 2014 | Toshiba 50L2300U 50" LED TV 1920x1080, 120...
I need a manual for an SD310VU MODEL it was given to us but we do not know what we need to hook it up to our TV. Can you help us Thank You
Toshiba has the manual for the SD-310VU at their site: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2841310&rpn=undefined&modelFilter=SD-310VU&selCategory=2797338&selFamily=2797344 .
You can connect the DVD player to your TV either with composite video (AV), S-video or component video cables. For the best signal output, get component video if your TV supports it. So the issue is what inputs do you have on the TV. For an older TV with only a coaxial antenna input, you would need an RF modulator for the composite video cable. (These are available at shops like RadioShack.)
Composite video cables usually have 3 RCA plugs on each end (yellow for video, red and white for audio). S-video uses a different plug and then the audio is carried on a different cable (usually red and white RCA plugs). Component video cables use three wires to carry the video (YPbPr - usually colored red, green and blue). As with S-video you use a second cable for the audio.
Purchase the cable(s) that will give the best signal with the inputs that your TV has and connect the video outputs from the DVD player to the matching input on the TV. Connect the audio out of the DVD player to either the TV's input or your sound system receiver, depending on the speakers you want to use.
I hope this helps.
Jun 16, 2011 | Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
I have a Sharp LC-32D40U LCD TV. All the inputs for Composite (Y,R,W) are bad and only the S-video input on Input 2 functions. ( I have not tested the HDMI inputs as I ahve not HDMI source). I was told...
Unplug S-Video cable from tv then tyr Composite video input as if S-Video jack is hooked, related composite video input will not work.
Let me know if you need further help.
Aug 17, 2010 | Sharp Televison & Video
How to I hook up my pc to a TV
Check your PC for "S-Video" output or for a "HDMI" or for a "composite-video" output.
Check the back of your TV for an available S-Video input, or for an available HDMI input, or for an available "composite-video" input.
Buy a cable to connect from your output to your input.
Jun 09, 2010 | Toshiba Satellite L505D Notebook
Toshiba sd-k970 dvd player sound but no video.
I presume that you've selected the correct inputs on the TV? Go for HDMI if you have it on your TV. If not use the yellow (composite) and ensure you have nothing in the S-Video (Toshs don't like using composite and S-video at the same time).
Aug 30, 2009 | Toshiba Televison & Video
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Poor picture
the composit video input
Nov 19, 2008 | Televison & Video
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
