Question about RCA F27442 27" TV
RCA TV PROBLEM
I was washing tv when the tv go off. the tv give me a whinning sounds. no picture nothing. i removed the relay take it to electronic supply. i pushad a new one replaced it nothing. what should i do next.can someone. tell please
    Scholar:
  • 119 Answers
Check the horizontal o/p transistor I suspect it's shorted, find location Q14401, on the board it's marked as q401. it's located near the flyback on a heatsink. if it's bad the rca part number is 242224. good luck
Posted on Dec 13, 2006
When plugged in a chirppy high pitch whin sound comes from back of set
It sounds that the Flyback transformer has damaged. Contact any experienced service technician if you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center
Feb 07, 2013 | RCA F36650 36" TV
I have a 19 inch emerson lcd tv that has no picture and as u plug it in the tv makes a whinning sound but as soon as u unplug it the sound goes away
More than the tv power supply board have problems in this tv,don't know yet.But the whinning sound,the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.First must see how it turn out.
Dec 08, 2010 | Emerson LD195EM8 19 in. LCD TV
No picture but have sound
That click might have originated in 2 places: either it was the main relay disconnecting or it was the sound of a capacitor popping. Both are very severe problems - they signal that the power source of your tv has just failed.
Fixing it is a job for someone with electronics experience, if you're not one then call a repairman.
Jul 26, 2010 | RCA P42WHD33 42 in. Plasma HDTV
Tv won't start, no relay sound. need service
There are no service manuals for any lcd's. You have to trouble shoot them with electronic knowledge.
Oct 24, 2009 | RCA L26WD12 26 in. LCD TV
10-year-old 32" RCA PIP TV just blinked off one morning after about 30 minutes. It makes a continuous high pitch sound, and the on/off switch is completely unresponsive. I assume this is a picture tube and...
It's not the picture tube(especially if image was good b4 it went dead). The high pitch noise is the power supply whinning because it's shorted or overloaded. I just fixed one of these sets - replaced the horiz. o/p transistor and flyback estimate around $120.00-$160.00
Oct 24, 2009 | RCA F32650 32" TV
Loud whinning, high pitch noise coming from TV when turned on.
The color wheel is likely bad and needs to be replaced.
Check this link it is for a samsung TV but the same principals apply
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Oct 17, 2009 | RCA R52WM24 52" HDTV Projection Television
LG 32LX3DC TV sound stopped working
Hello cadillaczacc,
This could be you audio out put stage malfunctioning. As a test connect a head set to you RCA connectors for audio (Red and White RCA Audio out jacks) and see if there is sound (there should not be if the audio amp has malfunctioned). In addition check your setup menu to make sure the TV is not on mute mode. If the TV is not on mute and you do not hear sound from the headset connected to the audio out RCA jacks, then we can start looking at the possibility of an internal circuit problem.
I have the schematic so if you need help, and have a background in electronics, we can get this fixed. If you do not have a background in electronics I would suggest getting a qualified TV technician to fix this TV for you.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 08, 2009 | Sony KV-32FS13 TV
Rca hd52w59
ok does the set show a picture durring this whinning
i have ran into this problems .. sometimes it has to do with a coil that is oscillating...ll037 or ll029...the fix for this is simple if it is the problem. dampen the coil with silicon.
Mar 26, 2008 | RCA HD52W59 HDTV Projection Television
Sound and picture distorted only on lower channels
Bad tuner.......they are electronically divided in sections called
bandwidths, i.e. 2-6 , 7-13 so-on.........T.
Give accurate model # / service # for RCA part #............
Nov 06, 2007 | RCA F32450 32" TV
Tv problem
The F27442 uses the CTC203 series chassis and that symptom is very common. If the horizontal output is shorted you MUST resolder the coil in series with the base of that transistor and the pins of the small horizontal drive transformer. When they have been properly resoldered you can put in a new original horizontal output transistor. If the output transistor shorts out again then your flyback (high voltage) transformer is shorted and needs to be replaced.
Aug 08, 2007 | RCA F27442 27" TV
RCA F27442 27" TV Logo
46 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
