Dell Dimension 3000 PC Desktop Logo
Anonymous Posted on May 05, 2012
HOW DO I IDENTIFY TYPE & MODEL OF MOTHERBOARD FOR DELL DIMENSION 3000 TO UPGRADE CPU
DELL DIMENSION 3000 DESKTOP WITH CPU INTEL CELERON D 330 2.66 GHZ AND FSB 533 MHZ CHIPSET FOR MOTHERBOARD IS I BELIEVE INTEL 865 GV CAN YOU HELP
  • Anonymous May 07, 2012
    I HAVE IDENTIFIED E210882 DELL REV A01, BUT THAT STILL DOES NOT HELP WITH TRUE IDIENTIFICATION OF MOTHERBOARD
micky dee
Level 3:
  • Dell Master 3,015 Answers
  • Posted on Dec 12, 2015
micky dee
Dell Master
Level 3:
Answers
3015
Questions
0
Helped
1060298
Points
8762
Https://www.piriform.com/speccy/download
download the free software from piriform and run it
All the specifications of your machine will be displayed
Walter H Boehm
Level 3:
  • Dell Master 998 Answers
  • Posted on May 02, 2014
Walter H Boehm
Dell Master
Level 3:
Answers
998
Questions
0
Helped
340686
Points
2289
Are you kidding? That model is a boat anchor now!
5 Related Answers
Anonymous
  • 2229 Answers
  • Posted on Mar 11, 2009
SOURCE: i need a new processor and motherboard for a dell dimension 3000
As posted by Smithbrother, you can't just put any motherboard in a Dell--the case and motherboard are built for each other. You would be better off buying another computer. A new motherboard means a different processor (like you want). This means a different, higher speed memory.
You can have a system built by a local computer person or browse some of the sites (you can go to Dell for some real deals--as well as other company sites).
Any new system will not have "only pci slots." The new boards will have PCI-E slots for your video, but will also have some PCI slots for expansion.
Cost? That's hard to say. I have to do an estimate for each of my clients depending on just what they want.
Anonymous
  • 476 Answers
  • Posted on Apr 25, 2010
SOURCE: i was just wondering if there is any DUAL CORE CPU
you should check the mother board manufactuers site for the latest info on the motherboard
joecoolvette
joecoolvette
  • 5660 Answers
  • Posted on Apr 28, 2010
SOURCE: I have a dell dimension 4600i. I want to upgrade
The Dell N2828 motherboard is supposed to have the Intel 865PE motherboard chipset on it.
http://www.ascendtech.us/itemdesc.asp?ic=MB4DEL2Y832&eq=&Tp
Looking at the - List of Intel Chipsets - on Wikipedia, we can see that the maximum FSB supported is 800MHz,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
[Scroll down with your eyes to 865PE, then read across ]
Dell Support lists that the Dell Dimension 4600 series, can have either the Intel 845G motherboard chipset, or the Intel 845PE motherboard chipset.
As seen in the chart the Intel 865G motherboard chipset, also supports up to an 800MegaHertz Front Side Bus.
The processor socket is a Socket 478.
I see that Weirdstuff.com, (Surplus warehouse) has Pentium 4's available with an 800MHz FSB.
Looks like the best they have is a Pentium 4 at 2.60GHz, 512MB cache, 800MHz FSB for $18.95 (US. They're located in California)
Not advertising for them, just sharing,
http://www.weirdstuff.com/cgi-bin/category/CPU000
Scroll way down the list to the heading - Socket 423/478 (Pentium 4/Celeron), then go towards the last of the list.
[To expound:
The motherboard chipset is the Northbridge/Southbridge chipset.
Chip and Chipset are slang terms for I.C., or Integrated Circuit.
This motherboard diagram, may help explain how the motherboard chipset comes into play,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
You can also look up the terms listed, by typing them into the Wikipedia search box, then clicking on Search.
You may be interested in looking up;
1) Northbridge (computing)
2) Southbridge (computing)
3) Front Side Bus
4) Internal Bus
5) Super I/O
6) Comparison of Nvidia Chipsets
7) Comparison of AMD chipsets
8) SDRAM
9) PCI Local Bus
10) PCI Express
11) GPU
12) Comparison of AMD graphics processing units
13) Comparison of Nvidia graphics processing units
14) Intel GMA ]
Anything listed in blue, is a link to more information about it. Just left-click on it.
As you can see in the chart, the Northbridge chip handles the high speed processes of a computer.
Such as the Processor, Ram Memory, and high speed graphics.
AGP and PCI Express being high speed graphics. Any graphics card inserted into a PCI slot is Not high speed graphics.
The Southbridge chip handles the slower processes of a computer.
Anything to do with PCI, or Integrated Graphics, being two of the slower processes.
Therefore if you know what Northbridge chip you have on the motherboard, and what processor socket, you are pretty well on your way to know what processors your motherboard supports.
The Northbridge chip is under that 'meat cleaver' looking heatsink next to the processor socket.
If the heatsink were removed, and any thermal paste also removed, you would see - Intel 82865PE stamped on it.
Not a good idea to remove the heatsink, without having fresh thermal paste to replace the old thermal paste with, PLUS the top of the Northbridge chip, And the bottom of the heatsink needs to be THOROUGHLY cleaned Before applying new, fresh thermal paste.
The Southbridge chip has Intel ICH5, or ICH5R on it.
Anonymous
  • 32 Answers
  • Posted on Jul 12, 2010
SOURCE: upgrade from celeron to pentium 4 processor???
It is probable that you will be able to upgrade the CPU, but you may have to upgrade the BIOS. Check this links I've included with this post.
Walter H Boehm
  • 998 Answers
  • Posted on Aug 12, 2011
SOURCE: CPU Upgrading Question for Dell Inspiron 530s!
Here is a link for your computer's manual:
http://support.dell.com/support/edocs/systems/insp530s/en/OM/HTML/parts.htm#wp1578680
Follow the procedures outlined and be sure to clean the surface of the heat-sink (alcohol works) and reapply thermal grease compound to the surface of the new processor.
Cpu upgrade
You can try "support.dell.com".
5helpful
What Pentium 4 processor would be most appropriate upgrade for Dell Dimension 2400 Desktop,2.4 celeron?
Intel® Pentium® 4 that runs at 2.2 or 2.4 GHz internally and 400 MHz externally, or 2.266, 2.4, 2.53, 2.66, 2.8, or 3.06 GHz internally and 533 MHz externally.
Check this website: http://support.dell.com/support/edoc...m_en/specs.htm for more information.
What you need to remember is that your motherboard only supports northwood core cpus.
1helpful
I have an Intel D845HV motherboard running with a
In short, yes you can upgrade to a P4 cpu but from the compatibility chart at Intel support, it looks like the upper limit for this older board is the P4 2.6GHz.
Note: Even at that, running the P4 2.6 would require a BIOS upgrade to P12 or greater.
Luckily, the following link has the information you seek: (for BIOS info, click the "BIOS Version" link in the upper right corner of the compatibility table provided)
Intel D845HV CPU Compatibility
I hope this info is helpful!
I have an intel celeron 1.79 GHZ on my dimension 2350,what is the better processor for upgrade? and is there something else that i should change inside for the new processor?
you said that you want to upgrade ur 1.79ghz celeron cpu.
to upgrade a cpu just check that the packaging of the new cpu matches with the motherboard.
and also check that the motherboard supports the new cpu that you are installing. check this in the manufactures site.
4answers
I need a new processor and motherboard for a dell dimension 3000
By the time you spend all that money you could have bought you a new Intel 2.8Ghz dual core processor with 4GB of RAM..keep the one you have for stuff you want to experiment with and buy yourself a new computer
Looking to upgrade processor
your motherboard chipset is Intel 865GV and it supports Pentium 4
3answers
Should I get a new cpu for dell dimension 3000?
HII MARLBOROMANZ ,
YEAH THE PROCESSOR IS BIT SLOW FOR GAMES TO RUN PROPERLY.
I WOULD SUGGEST U TO BUY MOTHERBOARD THATS INTEL 965G AND CORE2DUO PROCESSOR.
U DONT NEED TO UPFRADE THE RAM AND VIDEO CARD U CAN USE THEM IN NEWLY UPGRADED MOTHERBOAD AND PROCESSOR.
I AM SURE U WILL ENJOY GAMES IF U UPGRADE ONLY OTHERBOARD AND PROCESSOR.REST ALL IS FINE.
Model number and socket type for my Dimension 3000
The specs say it's a 'Celeron D socket 478' 2.4gh processor. Try this website: http://www.pricewatch.com/cpu/
3helpful
4answers
Cpu upgrade dell dimension 5100
Hi, according to the Dell website you have a LGA775 socket on your motherboard. Therefore, you can only buy processors that fit into this socket. Here is a list of some offered by Intel that will work: Celeron D 325 2.53 GHz Celeron D 330 2.66 GHz Celeron D 335 2.8 GHz Celeron D 340 2.93 GHz Pentium4 520 2.8 GHz Pentium4 530 3.0 GHz Pentium4 540 3.2GHz Pentium4 550 3.4 GHz Pentium4 560 3.6 GHz Pentium4 570 3.8 GHz The processors that won't work are the ones that are not compatible with this socket. Everytime you look up a cpu it will tell you which socket it is designed for. To buy a cpu you will need to decide: The brand you want. The speed of the cpu that you want. Extras i.e. Hyperthreading, etc. How much you are willing to pay for it. Then you can narrow your search as you stick within your limits. Let me know if you have more questions. Good Luck
2answers
Upgrade
according to this cnet.com (http://reviews.cnet.com/desktops/dell-dimension-5100-pentium/4505-3118_7-31429803.html) the dual core is not an option. I'm not sure if that means that Dell doesn't offer an upgrade, or if it's not possible. First, open your tower and look over the Motherboard for the manufacturer and model. Once you have those, google them and look for the specs of what cpu's are supported by that motherboard. If you can and do decide to upgrade, check with the CPU manufacturer to see how strong of a power supply you need for the more powerful CPU. You're might be ok, but you might need to upgrade the PSU (Power supply) with the processor. From your description, I can't tell what motherboard is in your Dell. That will be the limiting factor. Get the motherboard specs and you'll know what you can do.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
