FixYa.com
Tags:
Dacor DMT2420 1200 Watts Microwave Oven
Cannot open the door Dacor Model DMO24S
posted by Horst on Dec 13, 2006
I know it is the Button assembly there is something lose inside, when I turn the control panel sideways something moves around (spring?) and when I careful put the control panel back I can open the door once, but then the loose part moves, and prevents the open button to move all the way to the back and the door wont open, Question?. How to remove the open button from the control panel and open it, or? Thanks
Comment by Horst, posted on Dec 15, 2006
Thanks for your help, one of the looking tabs broke off and got lodged behind the switch, this switch has 3 tabs, after removing the switch per you instruction and taking the loose part out the switch everything works fine thanks,
Horst
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 14, 2006
FixYa! (100)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2385 votes
You will need to remove the outer wrapper, then separate the control panel from the microwave by removing the screw and then lifting the panel up and away.
If you disconnect any wires, be sure to mark them, make a diagram or take photos first so you get them all back exactly where they were.
The attached photo shows the area where two locking tabs are located. They must be gently pushed in to allow the door open button and spring to be removed.
The door open button is part # 86778 (if your oven is black or stainless, part # 86778 if your color is arctic) and it can be obtained from a Dacor distributor such as http://www.apdepot.com
This should be the same as a Sharp model R330BK (black model) and you can order that door open button from Tritronics. It is part # JBTN-B088WRF0 and they are at http://www.wehaveparts.com
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE XL1800 1100 Watts Microwave Oven GE Advantium SCA1000H 900 Watts Convection / Microwave Oven GE Advantium SCA1001SS 900 Watts Convection / Microwave Oven GE JVM1340AW/BW/WW Microwave Oven GE JVM1350BW/WW/AW/SY Microwave Oven GE JVM1430 950 Watts Microwave Oven GE JVM1653 1000 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Microwave Ovens
What would cause the touch
What would cause the touch... Answer This...
Microwave Ovens
I HAVE A GE...
i have a ge... Answer This...
Microwave Ovens
The microwave is arcing and
The microwave is arcing and we... Answer This...
Microwave Ovens
I have moved and have
I have moved and have a... Answer This...
samsung microwave #DE6840744A
We are getting a message... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
