Question about Whirlpool Calypso GVW9959K Top Load Washer
Drainage The water is draining from the spout on the outside of tub all over the floor.
  • 15,935 Answers
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Tub spout diverter
Check the basement. There may be a valve (two valves) that someone partially closed in the past to limit how much water was used for a bath.
Dec 21, 2013 | Plumbing
Ge portable air model APH1GAAG1. Can't find a the water bucket. Has been at 83f for past 2 days. The spout in back leaks water. Home depot suggested I put the unit on small table and bucket...
Call GE customer support at 1-800-626-2005 or... go to this link:
and enter this model number APH10AA
The manual file is 1.28 mb.
This is straight from the manual page 6:
Drainage/Routine Maintenance
This air conditioner produces water during normal
operation. The unit should be drained if it is not
going to be run for an extended period of time.
The unit should also be drained prior to storage
at the end of the cooling season.
To drain the unit, follow the instructions below:
1. Unplug the power cord and roll the unit to a
drain or outside.
2. Pull out the drain cap and allow water
to drain from the unit.
3. Securely replace the drain cap.
Thanks for choosing FixYa,
Jul 21, 2011 | Heating & Cooling
I connected a hose extension to the continuous drain hose on the unit. I ran the hose into the tub, but water still goes in the tank. There is water in the hose too, but doesn't seem to drain in the...
Andre, the problem lies in the length of the hose (should be no longer than 5 feet) and trying to drain it into the bath tub. Your dehumidifier relies entirely on gravity to drain. It will not drain upward over the edge of the bath tub. Water gets trapped in the hose, because of this and creates a blockage. When that happens, water is diverted back to the tank.
For continuous darinage, it should be into a floor drain or a sump. So unless yo have one of the aforementioned, continuous drainage is not an option for you.
Hope this helped you understand how it works and what your options are.
Jul 20, 2011 | Danby DPAC7008 Air Conditioner
Dishwasher completes programme but does not pump water away
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
Feb 13, 2011 | Bosch Dishwashers
What does E7 mean, or what area needs repair when E7 code comes up on a Samsung wf306lawxaa ? It won't run, but it will drain and add water. The tub moves when pushed by hand, but I can hear change...
Hi, these error codes are to do with water supply and drain.Check the water supply has not been turned off or is not working for any other reason . Outside work can often disrupt water supplys! Blockages of the pump and filters need to be checked also is the drain pipe at the correct height (at least 18 inches/45cm from floor) and if pushed into a stand pipe , not pushed to far down (12 inches/30cm is usually suffice). If your drain attaches to the sink waste , check the nozzle is clear and drainage is good.
Take care
Jun 25, 2010 | Washing Machines
The last 3 times after using my top load Kenmore clothes washer, a mud spot (1/2" diameter) keeps reappearing in the bottom of the cylinder. Should I use draino to clean the drainage system or clean the...
DO NOT use Draino or any other drain clog removal chemicals to clean a washer. It could damage the tub seal, drain lines and/or pump & impeller. If you wish to clean the washer, you need to access the drain pump and remove the drain lines and flush them out. The following link explains how you can access and remove the pump:
I would recommend you UNPLUG the washer and take it to a location where you can flush water through it. Preferrably outside, or in a garage. If you lie the drain hose on the floor and fill the wash tub with a garden hose, simple gravity will flush water through the tub basin, drain pump and drain lines.
If you have any questions about these procedures, please post back and let me know. I hope you find this information helpful.
NOTE: The drain pump has only one moving part (the impeller). It is a common place for debris to collect. Remove the two drain hoses on the pump to inspect.
Jun 25, 2010 | Kenmore 22422 Top Load Washer
When I run water through this tub spout (diverter in down position) I still have water leaking from the showerhead. I have seen water from a tub spout when the shower is on, but not the other way around....
After you turn water off in about 30 secs pull the diverter up and leave for a few minutes This should allow the water left in shower piipe to drain out the spigot
Feb 17, 2010 | Speakman S-1555 Versatile Bath...
Dumps water on floor
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 26, 2009 | GE WJSR2070B Top Load Washer
Install bathtub without existing drain
it is generally not allowed under the water regs to discharge waste water into anything other than a drain.I would suggest you install a discharge pump, typically the saniflow type which will allow you to run the waste across the room and discharge the waste into the vanity basin drainage.Should you choose to install this be aware of the waste pipe configurations shown by the instructions
Mar 20, 2009 | Kohler Overture 5ft Vikrell Bath -...
Discharge hose does not fit onto laundry tub causing flooding.
Yes - they are sold at any hardware or appliance store. It is a drain tub clip.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 15, 2009 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
