Question about NEC PlasmaSync 42MP3 42 in. Television
Cable tv image quality
I split the television cable coming into my house and now have poor image quality on those tv's.
    Problem Solver:
  • 11 Answers
I have six tvs in our house and i bought a 22 dollar six watt? amplifier from radio shack and stuck that in wherever convenient for you. now all channels are solid on all tvs.
Posted on Nov 30, 2008
Very poor picture quality on LG 42" SMART TV 18 months old
This is probably due to poor quality cable or connections from the aerial. Digital TV needs better quality in both (F connectors and quad shield cable) than analogue TV did.
If all that is good then you may need a better aerial or even a signal amp.
Apr 13, 2015 | LG Televison & Video
Poor viewing quality
By poor color quality, do you mean that if you turn the color control all the way down, the black and white picture is more like black and red, green or blue - or do you have a good black and white image? If the B&W image is good, and the TV is an old (8+ years) one, maybe the mirror inside the set needs a good cleaning - especially if there are smokers in the room. If you have a B&W picture that is tinted, then you may have to go into a service menu to adjust it back to a better picture. Hard to guess the problem without more specific description of symptoms.
Jul 17, 2012 | JVC HD-56G787 Television
Blu Ray showing "split screen/double
Did you check your settings on your tv and blu ray?
Jun 04, 2017 | Televison & Video
TV is brand new out of the box. Watching television last night and noticed horizontal green line "blips" flash periodically throughout the night. Why is a brand new television doing this? These...
It could be localised interference, try different modes. Maybe it is a poor quality connection on a cable?
If all else fails www.toshiba.com will get you to the technical team for assistance.
You could always take it back for an exchange of course.
Feb 04, 2011 | Toshiba 37E200U 37 in TV
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
Poor picture quality & audio reception
If the input to a HD tv is not in HD format the tv won't display an image very well. Be sure your input to the tv is compatible with the tv's technology for optimum performance quality Also re-check the input source (such as converter box, dvd player, etc..) and be sure you have the correct input/output ports connected properly. Try to reset all yout tv settings back to manufacturers defult specs. When an input signal is sent to the tv most modern tv's have software built in to select the proper format to display the input image. There may have been a mismatch communication error when your tv software tried to "handshake" with your converter box input signals from its firmware. So try a reset solution and re-connect the tv without the converter and see if that helps. If not e-mail me and I'll determine if the tv needs technical servicing.
Jan 03, 2009 | Proscan 26LA30Q 26 in. LCD Television
Red pixels on white images on screen
This sounds like the digital equivalent of 'snow,' a random noise that can come from poor signal quality or poor or not firmly attached cables. I'd try exchanging the cable that is now in place from whatever signal source you have (cable/cable box, satellite receiver, etc.) with another either new or temporarily borrowed one from another device.
If this doesn't help, consider the other modern devices you have in your home such as light dimmers, fluorescent bulbs, digital clocks, home theatre equipment, etc. Pull the plug on any of those, one at a time and observe the TV to see if any of them are affecting it. Those named items are common sources of high frequency noise that can contribute to the kind of problem you are having. They have gotten better but can still produce unwanted sources of interference signals.
Oct 25, 2008 | Vizio VX32L Television
Diagonal lines and ghost images
You may have a bad flyback transformer (high voltage trans former). The lines you're seeing are retrace lines caused by the picture tube screen set too high. This is often caused by the screen control opening up. This control is part of the flyback.
Stargazer
Dec 02, 2007 | Proscan PS32500 32" TV
HV-175 LCD
Picture quality problems (such as lines, fuzzy image, or wrong colors)
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Check the  display issue with  a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV , switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Try to Reset the TV ( LCD) quality options. Please look in to User Guide to make the TV to factory Defaults..
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV . If the image quality problems still exists across all types of signal sources, the TV should be serviced.
I hope that this should resolve the issue. However, if the issue still persists then please contact LCD manufacturer for further more on the issue.
Bye.
Oct 17, 2007 | Proview HV-177 17 in. HD-Ready LCD...
NEC PlasmaSync 42MP3 42 in. Television Logo
61 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
