Question about Lexmark X1270 All-In-One InkJet Printer
Printer won't unstall
My printer won't uninstall --it a -lexmark x1240 whe i try to unstall it it only goes half way . please help
  • 31 Answers
Ok this is a common problem - are you using XP? if so, then press F8 when booting up and select 'safe mode' once the machine has fully booted then try uninstalling the software from the machine.
if the problem persists - reinstall the software fully, then try removing it again as it can sometimes help.
cheers
Posted on Nov 19, 2008
Can not get the color to work in my lexmark x1240 printer to work? we tried to refill the old cartrage first but it leaked after a couple uses than we bought a new cartrage but it won't work.
Make sure that you are using genuine Lexmark cartridges and not refilled, re-manufactured or clone cartridges from the 3rd parties. Lexmark products work best with original supplies. If you are using genuine cartridges yet the problem persists, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 01, 2011 | Lexmark X1240 All-In-One InkJet Printer
I have tried to download the driver for my lexmark x1240 all-in-one printer to my dell windows 7 laptop and cannot download it without an error please help
Try this approach. First, uninstall the existing Lexmark X1240 printer driver from your pc.
  1. On your computer, go to Start.
  2. Go to Programs.
  3. Go to Lexmark X1200 Series folder.
  4. Go to Tools.
  5. Uninstall.
After the uninstall process, reboot your pc when prompted.
When your pc turns on, check your system if it's running on 32-bit or 64-bit. Go to Start > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below and download the file that corresponds to your system type:
- Lexmark X1240 Printer Driver for Windows 7 32-bit - Lexmark X1240 Printer Driver for Windows 7 64-bit
Execute the file. Simply follow the instructions on your computer screen to complete the installation.
I hope this helps.
Oct 27, 2011 | Lexmark X1270 All-In-One InkJet Printer
My lexmark x1240 all-in-one will not print. It saves XPS files and when I go to open them it will not open them. I have already installed the XPS reader. Also, when I try to scan, a box pops up saying...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/lgJCxt. Select your operating system, download and execute the file.
Try to scan again to verify that the problem is fixed.
If the problem continues, please contact Lexmark Technical Support for additional assistance.
Oct 11, 2011 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240: tried to uninstall and reinstall
Please make sure that the printer is actually VISTA compatible (it should say it on the box) If it is compatible then there is a good chance that the drivers need to be updated. (even if you just bought it) Your first option would be to download the driver directly from Lexmark.com (forget the CD that came with it) Your other option is to download the drivers for LEXMARK X1250 (I have tried this many times with other printers and they worked just fine) I have also used these two web sites to download the drivers for other printers and it seems to work ok so far. Here are the links to the X1250 http://driverzone.com/device.php?id=81664 http://www.siliconguide.com/drivers/device/112/ ...Best of luck to you, I hope I was able to help.
Apr 24, 2010 | Lexmark X1240 All-In-One InkJet Printer
I have a x1240 printer and would like to download
If you have Windows Vista here is the link:
http://www.siliconguide.com/drivers/device/115/
Also, please lt me know if you need the Windows XP drivers.
Dec 04, 2009 | Lexmark X1240 All-In-One InkJet Printer
How to install printer ?
Just go to Control Panel...........
Printers Folder...........
There u will see a Chk mark on Lexmark Fax X1240........
And u will see another icon which says Lexmark X1200 Series just right click on Lexmark X1200 Series not the Fax and Click on Set As Default Printer...............
After u do this U can go ahead Print............
Good Luck
Feb 16, 2009 | Lexmark X1240 All-In-One InkJet Printer
Driver CD
Here's the Lexmark drivers for the x1240:
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:568:0:0
I've heard of problems with this driver though, so if it doesn't work, uninstall it and use the XP one, although the bug may have been fixed by now.
Hope this helps
Chris (ziraffa)
Jan 04, 2009 | Lexmark X1240 All-In-One InkJet Printer
Uninstall lexmark printer
Click on Start>Printers and Faxes.
Look for your printer. Double click it.
Click Printer>Cancel All Documents.
That should remove all of them from que. Be patient. It may be slow.
After they are gone, try to remove the software.
Oct 17, 2008 | Lexmark X1240 All-In-One InkJet Printer
Print problems
Please uninstall the printer drivers using cd or from add remove programmes from control panel.
and then unplug the printer and restart the computer without printer plugged in
Then install the printer using the printer driver cd and when prompted connect the printer to the computer.
this should work if still doesnt work please get back to me.
Regards
Mohammed.
Dec 17, 2007 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
