Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
Whirlpool gold model # gu1500xtlbo
Green light flashing but will not run. Replaced the touch panel and same problem
SOURCE: whirlpool gold- quiet partner III
I had a similar problem. So I bought a new computer for it. It didn't fix the problem. It turned out to be the button pannel. With all of moisture surrounding it steam go into the buttons and caused all kinds of faulse info that the computer could not interpt. Had to buy new button pannel and problem was fixed.
Posted on Mar 29, 2008
SOURCE: I have a Whirlpool dishwasher
Have a look underneath dishwasher by removing front bottom access panel, the one touching the floor. Look for a round plastic disc about size of 4 jam lids together, centre front of dishwasher. Inside of it is a foam disc that will float up off the base of the dishwasher if water causes it to do so. This floating up will trip a switch. Clean base of dishwasher of water and maybe test the switch with multimeter. Reset fault by holding down start button.
Posted on Mar 08, 2009
SOURCE: Whirlpool Gold GS395LEG oven won't start
oven does not light up, no heat
Posted on Mar 11, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave runs, but not heating. Whirlpool Gold
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can download Whirlpool owner's manuals and installation instructions (very handy when removing the oven form the wall for parts replacement) here.
You can find helpful exploded view diagrams and order parts here.
Posted on Nov 25, 2009
  • 506 Answers
SOURCE: I have a Whirlpool Gold
Try pressing these keys in this order. You have about 6 seconds to finish this. Let me know if this works then we can go from there.
Hi-Temp Wash
Air Dry
Hi-Temp Wash
Air Dry
Posted on Feb 15, 2010
How do I reset a flashing green start button
Blinking start button usually means a bad door switch cannot reset the control does not see the door as closed
Aug 14, 2014 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpoool model du920pfgb3--touch pad is not responding and no lights or nothing are on??
Control panel. Try to push cancel button to see if it resets.if not google it and they will walk you through it.
Mar 28, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a Whirlpool Gold model number GU2400XTPS6 and the Hi-Limit light keeps flashing 7 times and nothing works
I have replaced the control board and put the dishwasher throught the diagnostics but it still isn't working properly... any suggestions?
Jan 20, 2013 | Whirlpool Dishwashers
The normal button keeps flashing on my gold series that is a few years old
You can try disconnecting the power for a few minutes and see if it clears, but I doubt this will help. You will likely need to replace the touch panel. If you can provide the model number and colr, I can get you the part information and availability.
Kelly
May 25, 2011 | Whirlpool Dishwashers
Ink ligth still flashes
is Just the ink light flashing? if so, you might have gotten something , ( body oil or something else) on one of the green with gold "dot" chips on the end of the cartridge. clean it with a pencil eraser or bette r yet alcohol and replace in printer- hopefully you haven't bent any of the "springy" wires that touch those green chips inside the printhead- then it's a trip to the repairman
May 29, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Some lights are flushing and the dishwasher does
If the clean light is flashing it is an indication of the water not heating up. I have attached a link to a sheet explaining what might be causing it and how to reset the control so you can use the dishwasher again.
Clean light flashing
If other lights than the clean light are flashing that is an indication there is a short circuit in the keypad control and that part would need replaced. Let me know if you need details on replacing that. If so I would need the complete model number from the tag on the dishwasher just inside the door.
May 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
E0 F2 Error on Whirlpool Gold Super Capacity 465 Oven
it's green and it is connected in the console area. the touch panel is what needs to be replaced take the back panel off sometimes if you get a pencil eraser and clean the end of the ribbon cabbel that helps but more than likley you need to replace the touch panel.
Jun 02, 2009 | Whirlpool GSW9800PW Washer
Whirlpool Gold electric range control panel not working
I live in a new 500 home subdivision. The contractor ordered all Whirlpool Gold products including Electric and Electric/Gas Ranges. Many of my neighbors' panels have gone out! I'm talking about epedemic trouble. My son has had his oven panel (separate from stovetop) fail within the first year. Thank God it was under warranty...this is not a cheap replacement (he had the sensor touch pad. I just had my oven pad fail. I tried to set the clock for Daylight Savings and found out half my panel is out! The fix is a replacement of the panel. Depending on which model (push or sensor) look to spend at least a couple of hundred bucks. We have the Whirlpool Gold microwave panel and so far so good. My neighbor and my son's both went out! They just tossed the two year old products and replaced them with another brand. Sorry to break you the news...class action anyone?
Mar 04, 2009 | Whirlpool GY396 Electric Kitchen Range
I have a Whirlpool dishwasher model ADP951. the green light is continually flashing and will not run, help with this would be most appreciated.
Apr 26, 2008 | Whirlpool Dishwashers
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
49 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
