Question about Proview XL775I (Silver) 17 in. Flat Panel LCD Monitor
Blank Screen..Will not power off
The monitor started blanking out(black screen)for short periods while in screen saver and was slow to wake up. Then the blank/black time started to get longer before it would wake up. Now it will not show a picture at all. The green power light is on, but no picture and nothing happens when pushing the power button. I have tried the flash light...No picture visable. I thought it might be the cable but it woul still displa the menu..right? Any suggestions?
  • MIKE ECARS Dec 13, 2006
    here is pic
  • MIKE ECARS Dec 27, 2006
    Thank you for the response. I have hooked and rehooked this monitor to so many computers....not a card or cable problem. Any other ideas? help!
    Problem Solver:
  • 4 Answers
Have you checked your video source to ensure that this isn't a problem with your PC or whatever you're displaying on it? Try using a different display and see what happens. Try putting this LCD on a different PC and see what happens. If indeed it is this screen then it could be something as simple as a loose cable. Start simple and work from there.
Posted on Dec 27, 2006
  • Kevin Adams
    Kevin Adams Dec 28, 2006
    I think I might have misread your problem slightly. No OSD. What do you mean by trying a flash light? Try to shine it through the LCD to suppliment a failing backlight? I don't think that would work because there are two many layers of plastic, metal sheilding, and the backlight itself blocking the light from an external source. You'd have to break the monitor appart to try this. I don't have a clear cut solution for you. It could still be several different things (driver circuit for LCD, backlight, powersupply for the whole unit).
Samsung monitor goes blank after working perfectly for a period of time.
Have you checked monitor settings Carl? Some are set to sleep after a certain period of time. Mine was set to sleep after 1 hour (unknown to me) until I reset it. =)
Dec 06, 2015 | Samsung 933BW 19 inch Monitor
Computer powers on but screen goes off unexplainably while power still on.
Laptop computers have power saver features that will blank the screen after a period of no input. Default on these can be as short as one minute. Users can change these settings to avoid screen blanking, especially when doing thins like watching movies or streaming video. The power saver feature may be different, and thus the screen shut off timer may be different when the unit is plugged in.
Mar 12, 2015 | Toshiba Satellite M115-S1061 Notebook
Why is my pc monitor showing a blank screen after start up?
Sounds like the power supply in the monitor is gone. It's cheaper to replace than repa
Jul 29, 2014 | IBM ThinkVision Computers & Internet
Created a 300 picture slide show on my pc. the screen will go blank after 30 minutes and i have to hit the return key or touch the pad. Is this a sleep setting issue or kodak?
I suspect you have a screen saver set up that blanks the computer screen after 30 minutes.
If you are running Window XP, right-click your mouse on the desktop, choose Properties, from the Display Properties dialog, click the Screen Saver tab, then in the Wait box, increase the amount of time before the screen saver activates. Click the OK button when you are through.
Good luck,
-- SalParadise
Feb 28, 2011 | Cameras
The monitor goes blank after a few min, it comes
Are you sure that your computer isn't just going into power saving mode? Not sure what operating system you have but go into the screen savers tab or video properties and find out how your system is set up for power saving It may be starting before your screen saver does so the monitor would just go black.
Dec 18, 2009 | ViewSonic PF775 17" CRT Monitor
The monitor keeps going blank after a minute or so
hey right click on your desktop.go to properties.in the propertes menu go to screen saver tab.click on the screen saver tab.in the screen saver tab menu you will see a tab called power.click on the power tab.change your settings there for the monitor.let me know if it works.
Sep 09, 2009 | Proview PL713B 17" Flat Panel LCD Monitor
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
Periodically the page on screen goes blank
Windows inactivity for screen saver is set. If you want it to deactivate.
On Windows desktop screen, right click mouse a pop up box will show. Select "properties" or "personalize", go to screen saver. Uncheck the box with " on resume, display log on screen". And on screen saver box select NONE this will unhighlighted the inactivity time and the logon screen. Hit apply and then ok button.
This will deactivate the screen saver.
Mar 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Proview XL775I (Silver) 17 in. Flat Panel LCD Monitor Logo
132 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
