Kenmore 63942 Dryer Logo
Posted on Nov 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not staying hot-Kemore 80 Series gas
I run my dryer and it will start out hot. After awhile the heat stops but, the dryer continues to run. I have changed both thermostats on the back and no luck.
Please help! My wife is sick of having to run the clothes in the dryer 5 times to dry them.
Anonymous
Level 3:
Genius:
  • Master 1,028 Answers
  • Posted on Nov 20, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1028
Questions
Helped
316764
Points
2631
Suspect coils bad on burner valve after heating up first time will sometimes fail on following fire ups
Kemore 80 series gas dryer runs but no heat. I have seen 3 differnt solutions, how do I know which one to do? The gas valve solenoid, the thermal fuse or the ignitor????
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
heatman101
My kemore 80 series gas dryer does spin but it heats up whats the problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 05, 2011 • Dryers
1helpful
2answers
My kenmore series 80 model # 110.74852400, takes forever to dry. the flame comes on, but doesn't seem to stay on for long. please help. thank you
my kenmore dryer ignites runs for awhile then wont reheat. let it sit for a few minutes and it will heat again for awhile
4helpful
1helpful
2answers
I have a kenmore 80 series gas dryer. it's not staying hot. sometimes it will and sometimes it doesnt. i replaced the ignitor on it and its still not working what do you think?
This is probably the gas valve not working right. I would replace it. The ignitor is working and turning on the valve but it doesn't stay on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 03, 2009 • Dryers
Kenmore 80 series runs but dont blow hot air
Check your heating element. #1 cause for no heat. Easy to replace and ea VERY easy to break. Just for your own well being also make sure that gas pressure us correct
1helpful
Maytag Gas Dryer SDG515DAWW - heating stopped
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 03, 2009 • Dryers
My Kenmore series 80 dryer quit heating. It was intermitent for a few days then quit. I checked the inspection window and didn't see any light. The gas it on and it seems like there is a "click" after I...
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse.6aed02c.jpg If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
