Question about Samsung 4 Channel Dvr
No video message
I have had no progblem until the last time I erased the hard drive and not when I try to record it says "no video". Any ideas?
  • nancybea1 Nov 25, 2008
    I erased the hard drive on my shr 1040 and when I try to record I get a "no viedo" message. I am only connected to a monitor, nothing else so I don't need video but it won't record.
    Genius:
  • 1,011 Answers
Sir,
Check the video output mode. If DVR is set to CVBS mode, u can't see the image on VGA monitor. Mode changing by hidden key: Mode Key + CH 1
Refer to 6-12 point, 6-13 point of user manual...
For Manual
Thanks
Good Luck
Posted on Nov 25, 2008
    Scholar:
  • 181 Answers
Its feauters says as -----
No Operating System (OS) installation required.
No video capture card installation required.
No searching for video capture card drivers.
No mass storage (hard drive) installation required.
for the connections check out this link
Posted on Nov 22, 2008
    Sergeant:
  • 276 Answers
A ) Connect  directly to the sansung dvr.
B) Have your video source playing before you launch WinDVD Creator.
C ) Once WinDVD is running, if you get the error message "Please verify the video source is connected", click OK.
D) Click on the Settings Icon (small wrench) in the Capture window.
E) Select the Device Control Tab.
F) If you are using a composite video cable, set the Video Source to Composite. If you're using an S-Video cable, set Video Source to S-Video.
  • Samsung Master
  • 19,396 Answers
Check the cables at the back, let me know if the system is playing
  • Ginko
    Ginko Nov 22, 2008
    I don't think this has anything to do with erasing hard drive.
    Just check all cables, both on recorder and on camera side.
    Check the DVR input settings, try browsing channels until you can see the video.
My hdd dvd recorder will not record e51 , help
i think thats the code for the hard drive fail. if anything is recorded try to play it if will not play or it jumps about then the hard drive has failed and would need replacing.
Jun 29, 2017 | Toshiba Televison & Video
My recording studio is stuck on the project load screen
Your VS-2000 is showing symptoms of fragmentation--resulting in the unit freezing or failing to completely load. The only possible solution is formatting the hard drive. Formatting erases all data on the drive.
Note: If you have any files that you need to keep, you may contact our Roland Customer Support department (323-890-3740) to arrange a "Data Recovery" service. Our service technicians can attempt to recover any data that is in your hard drive. Customer Support is available M-F 8:30am-5:00pm Pacific time.
CAUTION!!! Formatting the hard drive erases ALL recordings and data on the drive. This includes any installed plug-ins as well. Be sure to back up all of your project data (recordings) and plug-ins to CD/DVD(s) before formatting the drive.
Unlocking the System:
1. With the VS-2000 powered off, press and hold the TRACK/STATUS button for track 4 and the FX 2 button.
2. With both buttons pressed, turn on the VS-2000's power. Continue holding the two buttons until the display has loaded completely. This can take several minutes.
3. Once the system has loaded completely, release the buttons.
Formatting the Hard Drive:
Note: The format steps below pertain to using the VS-2400's on-board LCD screen. If you're using an external VGA (video monitor), press and hold HOME and press F6 to switch to the on-board LCD.
1. Press SHIFT AND F1/PROJECT.
2. Use the CURSOR buttons to Select "IDE:0".
3. Press PAGE until "FmtDrv" is displayed above F2.
4. Press F2.
5. CURSOR to "Physical Format".
6. Turn the TIME/VALUE dial until "ON" is selected.
7. CURSOR to "Surface Scan".
8. Turn the TIME/VALUE dial until "On" is selected.
9. Press F5 (OK).
10. Press ENTER/YES twice.
Oct 13, 2011 | Roland Vs-2000CD Digital Studio...
The recorder dosent errs why
Hello you can erase the recorded messages one by one or all massages in folder at time
Note once a recording has been erased, you cannot retrieve it.
Erasing messages one by one
1 Press ERASE while playing back the massage you want to erase or press ERASE for more than 1 second during stop mode.
A beep will sound and the message number and "ERASE" will flash while the first and last 5 seconds of message is played back 10 times
2 Press ERASE while the message is being played back.
The message is erase and the remaining messages will be renumbered. (For example, if you erase Message 3. When erasing is completed, the unit will stop at beginning of the following message.)
Erasing all messages in a folder
1 Press FOLDER to select the folder you want to erase.
2 While pressing STOP, press ERASE for more than 1 second.
"ALL ERASE" will flash for 10 seconds
While the display is flashing, press ERASE.
Nov 16, 2010 | Sony ICD-B7 Digital Voice Recorder
Dvr will not record. i get the message, " hard drive full" is there a way to erase what is on the hard drive?
You can erase the contents of the drive or set the drive to overwrite when full. Erasing the drive is the equivalent of reformatting (you will not be able to recover the images easily).
To Erase/Format, enter the Menu system and select Hard Drive Setup (seventh line in the list). Press Enter, then go to HDD Format (fourth item in the list) and press Enter. Then enter your password (set up under System Setup) but the default password is 111111, if it is on. If you entered the correct password, the screen will flash HDD Formatted 3 times. Press Menu to exit the menu. (If the incorrect password was put in, Incorrect Password will flash.)
To overwrite, again go to Hard Drive Setup then select the first item, Drive Full. Press Enter to toggle Overwrite On or Off. You will be able to recover the images until they are overwritten.
I hope this helps.
Oct 13, 2010 | CSi Speco Speco Technologies DVR-4CF...
I can not put a desired event on recording thru"create timer"scre
aparfenov
The receiver hard drive is comparable to a computer hard drive. When a problem is detected with the hard drive, the receiver will give an error message stating a problem has been detected. Depending on the severity of the problem, sometimes it will show that unplugging the receiver for 1 minute will resolve the issue. Other times, a message will state that the hard drives needs to be reformatted, which will erase all content on the hard drive. It sounds like this is what happened to your recordings. If unplugging the receiver did not resolve the issue, we may need to replace the receiver. Please call 1-800-333-3474 and speak to a Technical Support agent.
Ray Calo
DISH Network
Apr 25, 2010 | DISH Network ViP622 DVR DTV Receiver /...
HDD error
I have a SONY RDR HX-750 video recorder, that as of late has frequent "dub error" incidents...this unit has had a lot of use since purchased. It has served me very well until now. I have erased several recordings (many hours), and optimised the hard drive in an effort to correct the problem...to no avail. The problem persists. I can therefore, ownly deduct that the dvd drive is very "dirty", and needs to be "cleaned" (HOW CAN I DO THIS?)...or there is something wrong with the hard drive? Can you please help? Many thanks for any help and your time and consideration. Have a very good day!
Feb 20, 2010 | Sony RDR-HX900 DVD Recorder
Hard drive erased
The proper operation of the 625 assuming one goes to bed before midnight will have the receiver updating at the preset time-usually 3AM after which the energy conserving portion of the receiver takes over turning both tuners off. Upon waking you will notice no lights on the receiver are illuminated and once the TV is on your have a screen saver image dancing across the screen. Once the select button is pressed the receiver will come out of sleep mode and the tuner you are using will illuminate on the receiver.
As for the increased recording time this was an update that was put out last year at about this same time for reasons that escape me at present. It is unusual that the hard drive reformatted and could be faulty. If you would go to the menu and press 6-1-3 this will bring you to the system info screen. Select details and scroll down until you see the value0 through value 9 and record these figures and let me know what they are and I will tell you definitively if your hard drive is corrupted, faulty or on the verge of a crash. Hope to hear from you soon and thanks for using Fix Ya.
Dec 28, 2008 | DISH Network DVR-625 DTV Receiver /...
Samsung 4 Channel Dvr Logo
75 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
