After a 40 degree wash the washing had a brown sludge over it. This appears to have rinsed off in cold water. Has the machine now died or can it be saved?
SOURCE: Front Loading LG Washing Machine leaves smelly sludge in wash tub
This machine has a tub clean feature that you're supposed to run with bleach. I did this and it helped the smell s bit. Recently we had an error code and the repair man that came to fix it gave me some good tips. His experience has been that the smell is from too much soap causing build up in the seal and along the tub. His suggestion was to cut back on the amount of he detergent (he said a tablespoon is sufficient). His company recommends using a product called Whirlout (you can buy it at Home Depot). It was originally meant to clean scum out of hot tub jets. Apparently if you call LG they will recommend this product, but haven't bothered to suggest it in the owner's manual. I was told to put one to two capfuls directly into the tub (not the detergent bay) and run the tub clean cycle. I used it last night and it worked - no more musty, yucky smell!
SOURCE: Bosch Maxx WFL 2260
Hey check to see if you can move the drum by hand,, if you cant the the bearings on the drum have gone and it is seized ..
If you can turn it by hand then most likely it is the carbon brushes on the motor..
hope this helps
any questions dont hesitate to contact me im here to help....
SOURCE: My Bosch washing machine is leaving sludge like
Make sure the draw is 100% clean inside the draw compartment to if the draw is all clean next thing to cheak is the rubber door seal make sure it is clean all the way round next thing to cheak is the pump at the front of the machine pull down the cover and undo the the pump cover by tuning anti clock wise water will come out when you cheaked it is 100%clean put it back together if you get stuck read manual if all toughs things are clean or bean cleaned. do a 90 again with washer cleaning detergent with you can buy at the super market hope this helped.
Testimonial: "Great advice. I cleaned around the rubber door seal with a thin long handled brush. Worked a treat. No more stains on my laundry. Thank you! X"
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
SOURCE: Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Thanks Irene, but the seal is cleaned regularly.
