Question about Freezers
Fridge freezer top half not freezing but bottom half is
  • 370 Answers
Check to see if the evaporator fan behind the freezer wall (remove wall) is running. If it isnt the air will not flow properly in the unit. Replace the fan motor and it will fix it.
Posted on Nov 20, 2008
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
The top half of the freezer is not freezing. The bottom half is.
you need to reprocess your freezer to clean up the stock up oil in the tube. causing not to circulate the freon gas. you need a white line technician to fix your problem.
Jun 16, 2010 | Freezers
Top half does not freeze
There is a fan behind the back wall of the freezer about 1/2 way up from the bottom, you should be able to hear this running when the freezer is on. If you do not hear this then you need a new evaporator fan motor.
If you hear the fan run then you most likely have a problem with the automatic defrost cycle that would most likely be the heat element that is located just below the coils inside the freezer behind the panel.
Apr 21, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Zanussi fridge freezer alarm keeps sounding
If the refrigerator and freezer are both working properly. Then the only problem would be the alarm, It's either the placement of the alarm thermometer or the alarm thermometer is stuck closed.
Mar 15, 2010 | Freezers
Upright freezer
If it has a fan in the freezer it need to be running to circulate the cold air.
If the coils are not icing up evenly from top to bottom you have a system low on freon.
The light frosting is normal.
A model number would really help to troubleshoot the problem.
Sep 19, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
The top half of the freezer does not work
I have a Scandinova chest freezer and the left hand side froze, but not the right side, because the compressor in the box under the right side of the freezer was getting so hot, a small amount of heat was conducting back through into the right side of the freezer and preventing anything on that side from freezing!
I solved this problem by running the compressor outside of the of the freezer box, by taking the air vent off, unbolting the compressor and then pulling out by about 20cm and running it from there.
Aug 22, 2009 | Freezers
My freezer is freezing at the bottom but is not at
Short on refrigerant would be a good starting point, pressure temp relationship should be tested by an opperative.
Jun 27, 2009 | Hoover 9.9 cu. ft. / 280 liter Upright...
Freezer only cools on the bottom half
check the seals on the fridge sounds like there might be a section not connecting with the fridge
Jun 07, 2009 | Freezers
Freezers Logo
187 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
