Question about Samsung TX-R3080 30" TV
TX-R3079WHX/XAA Blown fuse
Hello, My TX-R3079WHX/XAA was working fine and the only fuse I could find on the board had blown, It looks like the old car fuses. I source a replacement fuse; and the set worked for two weeks and blew it again. The set is plugged into a surge protector. I?m not scared to learn and fairly handy with electronic and soldiering, what should I look for that would cause this intermittent surge or failure? The set works fine unless the fuse is blown then nothing, its elevated out in the open and under a roof so I don?t believe water and excessive heat are an issue. Thanks!
  • Anonymous Nov 03, 2008
    2005 Tx-R3079WH. Turn it on and runs for 20 minutes then audio goes out, video goes out and set powers down. Trying to ascertrain if it is worth the expense to fix. Plus hard to find anyone to work on the old tube style tv.
Snakehead, Thanks for the suggestions; I'll check out the kit you mentioned. Since the TV?s death and the lack of warranty its become a hanger for my wife?s cloths. I will be happy to get it going again! - JT
Posted on Mar 22, 2007
    Genius:
  • 1,074 Answers
Greetings from belize make good checks in your power supply replace your voltage regulator it has an short which is activated after accumulating heat.change the horizontal transistor.and the bias diode the feeds to the B+ to the flyback.if that does not solve the problem replace the flyback.your problem is intermittent so you cannot check voltage just replace components matter of fact replace all the components in the power supply you can buy a kit from www.dalbani.com in miami florida.good luck.
Posted on Mar 21, 2007
There is no power samsung wa5451anw/xaa-0002
hum not good
sounds like something has fused and blown the mains
you need to look too a control board error for this ...
its a job for a tech,... for sure..
Mar 05, 2015 | Samsung WA5451ANW 4.7 Cu. Ft. White...
My hp plasma tv lost it's picture. Audio works fine. Work are some causes of this?
The T-con board, the board that sit right in the middle of the center LCD panel . That board is dying. try websites like shopjimmy.com, Ebay.com to buy a refurbish T-con board for replacement.
Thanks for using fixya
Aug 20, 2010 | HP PL4260N 42 in. Plasma HDTV
Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
May 15, 2010 | Onkyo TX-DS696 Receiver
No sound output
Check you audio in and out cables. . you may have them backwards.
Sep 25, 2009 | Onkyo TX-SR502 Receiver
If there was a fuse in my model (rca) lcd flatscreen where would it be .or what should i look for if my telelevision only 1year old just stops working?
hello there is a glass fuse on the power board if black it's blown if you put another 1 in and it blows again then you have got a dead short someware beware there might be solder in fuses these are called wickman fuses good
shaun
Sep 14, 2009 | Televison & Video
My monitor 940n samsung syncmaster gone in black...
I have just had this same problem. The problem mostlikely is a blown fuse on the inverter board. Mine was blown on the board and also a Capacitor (470nF/25V) was bad beside the Fuse.
I replaced both and monitor is working now again. After install the picture was a little grainy with little artifacts. In another post i found that the Power Supply board needs to be cleaned for unwanted residue. After that picture was fine again.
BEWARE that you need a soldering iron and a steady hand to replace these parts. If you are unfamiliar with soldering at all have an expert take a look at this. The Power boards uses 220v so DO NOT connect it to the Power when opened.
Starworx
Aug 10, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Onkyo tx-sr606b no power - blown fuse?
it either a bad fuse or your transformer that is blown
Jan 06, 2009 | Onkyo TX-SR606 Receiver
Problem after replacing blown fuse
My dear friend your audio amplifier IC are damaged and you need to replace him.
Oct 01, 2008 | Onkyo TX-SV727 Receiver
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Samsung TX-R3080 30" TV Logo
171 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
