Question about Dell UltraSharp 1504FP 15" Flat Panel LCD Monitor
15'' 1504fp lcd screen's power button just keeps flashing
I have changed capacitors and even the pico fuse, but the monitor still won't work. it just has the flashing amber light. i usually can fix this problem but it is not working this time.
  • 4 Answers
SOURCE: blinking monitor power button and flashing image
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
Posted on Sep 12, 2008
mplacchetti
  • 3 Answers
SOURCE: LCD monitor no display - flashing power button
Hate to criticize and then not help out. I have this exact same problem with one of my E152 Dell Displays. I have read around and this whole line of displays seemed to have trouble. I found many issues like this and no solutions.
So, I like to tinker and tinker i did. I opened the case, removed the screen and went straight to the power supply board where I found two burned out capacitors.
RATED:
Value Voltage Diameter Height
1000uF 16v 10mm 16mm
Found a great source for replacement parts and instruction to replace the caps at BadCaps.net
Let you know how it goes.
Posted on Apr 29, 2009
babes_ganda0
  • 381 Answers
SOURCE: OSD Main Menu appears randomly and uncontrollably /flashing. Power Button does not always work. Need to keep clicking unti works.
hello..the problem is just sticky tack switch's so try to clean or re-align the frame/body of LCD..Thanks.Good Luck..^_^
Posted on May 11, 2009
tommya300
  • 724 Answers
SOURCE: blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Posted on Jul 27, 2009
  • 1684 Answers
SOURCE: Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
My Samsung SyncMaster 931BW monitor has been working fine for me. It was working fine last night turn it back on this morning and the screen is just black. Reset computer checked the cords and power outlet...
Try it with another PC to make sure is is not the PC video card problem, also chek the cable. If it still does not work, then you will have to open it up.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 05, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
My benq lcd fp767 have power but no display,,,i want have a troubleshooting guide about the lcd,,,pls help me
First check the vga cable, video cards of your pc.if all of these are ok open your LCD monitor check the power board for boated capacitor, open secondary pico fuse or fuseble resistor, replace it with the same value. The defective lcd panel can cause of dim dispaly but the power is ok.
Oct 03, 2010 | BenQ FP767-v2 - 17" LCD Monitor
Good Morning, My monitor keeps blinking and on the display you can see it keeps switching from analog to digital, i am using a dvi cable, and it is set to digital via the monitor, the weird thing is it...
My samsung monitor model 2233SW PLUS keeps flashing on and off and if i press the side button a menu type magic bright comes and shows whether to change in cinema ,custom ,text,internet mode etc,and when this option comes it doesn't flash and after 10sec this option goes off then again it keeps flashing in 5 sec. and the menu option doesn't come if by chance it comes than again for 2 to 3 min it stops flashing sometimes for 5 min .please help good-morning-monitor-keeps-blinking-orr1pjn3khwbyjvnsjgmppfg-5-0.jpg
Sep 03, 2010 | Samsung SyncMaster 213T 21.3" LCD Monitor
HP L1706 monitor - will not power on - green light keeps on flashing
I had the same problem and replaced 2 bulged capacitors, screen is working fine again! (1000µF 10V)
Jun 04, 2010 | HP L1706 17" LCD Monitor
No display on monitor; green switch keeps flashing
You may have shorted out transistors in the inverter circuits, common problem.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 28, 2010 | Dell E173FP 17" LCD Monitor
Screen won't turn on - power button continues to flash. Checked cords - unplugged plugged back in - blue light keeps flashing. Hit keys on keyboard and on mouse - nothing. Tried holding down power button...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 19, 2010 | LG W1934S-BN 19" Monitor
hello, my best guess is that the refresh rate is set for a crt monitor. hook your old one back up, if you can. and change it to 60 hertz or 70hertz. go 2 display properties then settings then advanced; then monitor. set the refresh rate as i said and turn off the computer, hook the new one back, and you should be good to go. good luck! and please rate this solution. if you need further assistance, reply
Apr 21, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Dell monitor 2005FPW keeps on flashing
I was having the same problem.
I solved it by replacing the two 47µF capacitors on the power supply/inverter board.
I actually removed all the capacitors (around 13) and all checked out fine except for the two 47µF.
I forgot to take pictures or even write down the capacitor label on the board.
They are located close to the logic board connector
Feb 05, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell UltraSharp 1504FP 15" Flat Panel LCD Monitor Logo
105 people viewed this question
Alun Cox
