Question about iRobot Roomba 4210 Bagless Robotic Vacuum
Brushes are clean, but Roomba stops and says clean brushes
My Roomba stops within a few minutes of starting it and when I press the button, it says "Remove and Clean Roomba's Brushes." I have removed the brushes and cleaned them thoroughly, but within a few minutes, it stops again and says the same thing.
  • 3 more comments
  • fudog7 Dec 23, 2008
    This worked! My Roomba would start up but move sluggishly and eventually stop. Looked up the error code of "uh oh + 1 beep" on the Roomba site and its the brushes error code. Clean those regularly so it was something internal. Followed this solution of getting into the gear box and cleaning it out and viola, Roomba is fixed! Tip is to work slowly and carefully and you are pretty much taking the entire thing apart. Thanks rlewis!
  • Anonymous Mar 28, 2009
    I had the same thing happen and did exactly what rlewis439 said and roomba is working just fine! Thank you!!!!!
  • Anonymous Mar 15, 2014
    roomba's side brush doesn't turn
  • Anonymous Mar 17, 2014
    I have replaced the whole brush unit and brushes still don't work. Any ideas.
  • Wendy Knowles
    Wendy Knowles Mar 29, 2014
    Fabulous! Thanks rlewis, mine is a slightly different model but followed essentially the same procedure. Accessing the gearbox was the trick, I could not believe the greasy gunk clogged up in there! Now GoodBird the Roomba (what can I say, my parrots named it) is working beautifully again, cleaning faster and better than ever, and no more ka-thunk ka-thunk sound as it cleans!
I decided to take it apart and see if I could fix it because even if something inside went "SPROING" and I couldn't get it back together, it wouldn't be any worse than it was already.
FIrst, remove the dust bin part and the brushes. Then, there are four screws on the bottom gray panel which have to be removed first in order to get to the gears which hold the brushes. I did not remove the little sweeper brush on the front, but I just slide it through the hole in the gray panel.
Then in order to get out the orange section which actually holds the brushes, there are four screws which must be removed. The orange section is attached to a blue section. This entire unit comes out by sliding it toward the area where the dust bin goes, being careful not to tear the light gray rubber gasket which covers the side.
Once that section is removed, there are two screws on each side. These screws hold the orange thing to the blue thing. Once the screws are removed, lift up only the side which has the white squares into which the brushes are inserted. These are actually the back side of little gears. There is a face plate on the outside of the orange part on this end. The other end contains a bunch of wires and I was careful not to disconnect any of them.
The face plate has six screws which must all be removed. Use caution when removing the face plate. Hold it up so that all of the stuff doesn't fall out. It has a bunch of gears, little brass looking fittings and grease. Take care to only remove the gears which have the squares which hold the brushes AND do it one at a time unless you like working jigsaw puzzles. I used tweezers and a pin to clean the "gunk" consisting of hair, fuzz, etc., out of the little gears.
Reverse the process to put it back together. Hazel, my little Roomba, played me a happy little song and immediately went back to work. She seems as good as new.
Posted on Nov 20, 2008
  • 1 more comment
  • kennydude Sep 06, 2010
    hey all,
    followed rlewis's thread on a 580 (?) roomba (costco roomba) - with the blue and green bottom, as opposed to the orange bottom. works like a charm, get some compressed air pull out each gear.
    - thank you -
    -kenny
  • my roomba Oct 03, 2010
    Thank you thank you! I even had fun taking the Roomba apart! Now that I followed the directions from rlewis 439, I think my Roomba is running even faster. Mine was blue/green and no orange, but it's all the same. I can't believe the gunk that was there. New carpet must do that faster than hardwoods and area rugs which I had run the machine on before.
  • mrnmrsdavenc
    mrnmrsdavenc Mar 22, 2013
    Thank you! I cleaned out the gears and housing and it works great. Running 30 minutes so far. Going to command it to dock in a moment. I made the mistake of cleaning the gear housing lid with out noticing the little plastic washers. I think I lost at least one maybe two. I believe these are made to seal out dust, dirt and hair. So I may have to do this again sooner than later but I know where to go and what to do now. Thank you again so much for this post.
I have the Pet Series so I don't know if this will help, but it instantly solved my problem. At one end of each of the brushes is a yellow hexagonal piece. Pull them off and you will probably see a bunch of hair/dust up in there by the metal pins. Clean it out, replace the yellow heads and put the brushes back in.
Customer support gave me this information. Good as new!
Posted on Aug 03, 2010
Did this but still same problem...any further ideas?
Posted on Jun 28, 2009
  • davidjmel Apr 15, 2011
    Have routinely cleaned pet hair out of bushings on ends of brushes (as suzaddison suggests), and have had to remove the rotating front brush to remove hair jamming it up too. First time I have had to disassemble the gearbox that runs the brushes as rlewis suggested above. Worked for me, but do note that you get the same message for all the above problems.
  • Dolores Ninerell
    Dolores Ninerell May 29, 2014
    I fixed our Roomba! It wasn't as hard to take apart as I thought. I was able to get most of the cage loose and then go in and clean it. I must have missed something the first time as it was still making a clunking sound and stopping. I found more gunk the second time and low and behold it is running fast and with much vigor like I haven't seen in some time. Roomba is back! My three year old is scared though...
Roomba 530 is clicking when running then stops
The battery is not charging and has died a noble death. Buy a new battery.
Nov 28, 2013 | iRobot Roomba 530 Robotic Vacuum
Took Roomba apart to clean and now the pick up brushes start and stop during cleaning. The vaccum is clean but will not constantly spin. Runs great but pick up brushes start and stop. Is there a number...
You can go to www.iRobot.com . This is the roomba website. You should be able to find replacement parts, customer support, videos or the Roomba product, and more.
When you cleaned your Roomba, did you also clean the wheel wells and outer most edges of the brush brush cartridges? There can be lint, threads, and at my house, cat hair, wrapped around the outermost edges of the brush cartridges.
I hope my suggestions help. If so, please contact Fixya and rate my solution.
Thanks and Good Luck!
Dec 02, 2010 | iRobot Roomba 530 Robotic Vacuum
Irobot stops after a few minutes and says plaes
soooo, what is not understood here ?
turn it over, open brushes cage, take each brush out and clean it.
In addition, also clean the sides from any dirt/hair that may stuck in its pivots.
good luck
Avi
Apr 07, 2010 | iRobot Roomba 560 Robotic Vacuum
I have cleaned & cleaned this thing! It runs for about 2 mins & stops, says "Clean Brushes"! and now it's very noticeable it's not picking up well... but is picking up a bit. I take the dust bin...
Ok, this is a "Brush Height Adjustment" issue. It will probably work great on a hard surface but on carpet the brushes bog. If you've taken the unit apart already...Sorry....do it again. When you do, you'll see a String which allows the brushes to "Float" on different surface heights. Loosen the screw a little and pull a bit more string through. Re Tighten the screw and put it together enough for a test run. Now reset the roomba.To reset the Roomba, power the Roomba on, and press the Spot, and Dock buttons together for at least 8 seconds. Until it plays a tune. The clock, and any schedule is erased at this time. Try running the Roomba with the dust bin removed to see the brushes spin easier.
Second method, is taking off the bottom cover, and removing the battery. While it's removed, and not plugged into the charger, press the clean button for at least 20 seconds. This will erase the memory. Replace battery, and cover. Run the Roomba to see if the brushes start to spin. You can also remove the brush housing by removing the 4 screws and reseating it, to see if it was a bad connection, since you have the bottom cover off.
Mar 26, 2010 | iRobot Roomba 560 Robotic Vacuum
Runs for awhile then says error 2 please remove and clean roomba's brushes i do then runs for awhile and says same thing no dirt on brushes?
I had the same problem. You must clean this parts and inside this parts:
Remove hair with cleaning tool
Remove Roomba's brush bearings
Clean Roomba's brush bearings with cleaning tool
Dec 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba keeps saying clean brushes yet are clean!
Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
Jan 30, 2009 | iRobot Roomba 530 Robotic Vacuum
"Please clean Roombas brushes"
Same thing happened to me. After "cleaning" the brushes and emptying the filter several times, I realized that the brushes were not properly secured. One of the yellow fasteners needed to be pushed closer to the middle nearer to the brushes. It was not secured properly. When I did this it fixed my problem.
Dec 20, 2008 | Roomba Robotic Floor Bagless Vacuum
Please clean Roomba s brushes warning will not stop after brushes have been cleaned Unit shuts off after one minute of cleaning
Clean the yellow brush bearings. Then run the Roomba without the dustbin, so that you can watch the brush while the unit is cleaning. Is it turning? If not, call customer support. 877-855-8593. Have your Roomba with you; they will want information from it. Good luck.
Dec 13, 2008 | iRobot Roomba 570 Robotic Vacuum
Problems with roomba 530
before taking apart your Roomba read this!!! First to see if it is a defect or really the brushes, take the brusehs out and run roomba with out them. If you still hear the clicking/ thumping then try taking it apart or call roomba. But if the clicking/ thumping goes away when the brushes are out you're in luck! Take the brushes. The brushes have little yellow nubs... those come out. pull them out, and you will see a lot of hair waiting for you. clean all of the hair out ( tweezers are wonderful for this). Once they are cleaned out put the yellow nubs back on. Put your brushes back in and you're Roomba will be back to business in no time!!!
Jun 06, 2008 | Roomba Robotic Floor Bagless Vacuum
iRobot Roomba 4210 Bagless Robotic Vacuum Logo
7,947 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
