Rca projection tv
I had this fixed but 4 hours later it went out again I did buy 2 but would like to know what would cause it to go out so soon"
  • kputens Nov 20, 2008
    I replaced the convergence fuse per willtab's instructions.
    Genius:
  • 1,030 Answers
The fl231 fuse problem. sorry to hear it still bugging you. FIrst question DId you resolder the flyback connections. This is the main cause of the fuse blowing. IF you have soldered these connections then you might have other problems. The ribbon connectors between the power and main board. . Is the fuse still blown. in the hundreds of these repairs i have done. i have came across one time when the signal board was bad. very rare.
Posted on Nov 19, 2008
  • Willie Howell Nov 19, 2008
    so it did work for a short time? issure that the cables especally the ribbon cables have be firmly seated into the board connectors. there are some diodes adjacent to the fuse that might have some faulty connections. Otherwise something is shorting causeing this fuse to pop. As a tech i would take some readings to narrow it down,.
  • 734 Answers
What is the exact problem please describe in detail ?
  • futureloginn
    futureloginn Nov 20, 2008
    thats like to be a fuse problem.
  • futureloginn
    Describe your problem .
  • 541 Answers
Projection tv i had one and went it got to hot it just gos off so make sure nothing is blocking the air geting to it
  • Lee Reynolds
    Lee Reynolds Nov 19, 2008
    if you have only just had it fix you will have warranty on the repair so call them back
    Sergeant:
    Champion:
  • 435 Answers
Hi, Could you please tell us what was the fix and what did you buy?
Thanks
OmIm trying to figure out why my tv will not come on. I was watching it one night and it just went out . I did not think nothing else of it so . I left out the room about 30min later I started to smell...
First replace bulb to make sure it's not the bulb. If it's not the bulb it is most likely the light engine. My suggestion would be don't invest in the light engine. Goes for about $500 plus for a re-built one and warranty is only 3-6 months on it. I purchased one and it went again in 4 months.
Please don't invest in any more dlp tv's. I learned the hard way.
Jul 19, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
I have a 52'' HDTV Projection RCA tv and it went out no pic or sound so i UNPLUGGED and had to wait a month later which was today so I turned on and it had beautiful picture for about 20 min then it turned...
U have tools,can u do basic soldering,and understand basic electronic?Yes.Take ur tv aparts.Take out the DM power supply board check for dying,soon to be dead capacitors.These capacitors are alway bulges or puffing up on it tops.U replaced these dying capacitors,u will solved this power light blinking problems.Try website like Tvrepairworld.com might still sell those prepack capacitors repair kit for the RCA DLP tv DM power supply board.
Nov 17, 2010 | RCA HD52W56 52" Rear Projection HDTV
I have the Toshiba 61A61 TV. I am not sure what exactly happened, but when the TV was on, suddenly the picuter went black. I still receive the normal sound, but can't get any picture (totally black). I...
Check all connections?Unplug,replug the cable box about an hour later let it upgrade it software.The projection lamp has not been replaced in this tv the last 1 1/2 or 2 years?The tv been on and watches at lest 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Sep 03, 2010 | Toshiba 61A61 61" Rear Projection...
I got a 52 in rca hdtv projection tv and it went all 3d looking. is it able 2 be fixed or were they recaled i only have had it 2 yrs. this christmas would have been3 yrs
Ur convergence it dead,know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv repair kits.
Dec 12, 2009 | RCA HD52W59 HDTV Projection Television
R56WH78 RCA TV FlyBack
Resolder all the pinns on the FBT chances are FBT is Bad they go out alot Call UED for Parts 1-800-648-6657
Oct 19, 2009 | RCA R56WH76 Projection Television
Pop sound no pic sound ok . SHUT OFF HOUR LATER WORKING OK..THEN PIC WENT OFF STILL HAD SOUND...
no fix yet ...turned it back on an hour later and its been ok since...if any one knows whats up h
Jun 24, 2009 | RCA Televison & Video
FL231 Concergenc Fuse blowing
Check the ballast. Also make sure that it is plugged into a GROUNDED surge protector!
Jan 06, 2009 | RCA D52W23 52" HDTV CRT TV
TV won't come back on
That model has had some issues with a defective flyback. Thats quite possibly what the problem is. If you need more info let me know
May 16, 2008 | RCA D61W20 61" Rear Projection Television
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
Picture flickers, loses color, goes green, white, and negative, then TV turns off.
the unit has a bad color wheel.rca has seen this problem before.The color wheel has a bad bearing which over time can seize causing the single color you see.Keep on them they know it is defective
Mar 19, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
