Question about Iomega (33090) 250 GB Hard Drive
Iomega 250GB external hard drive makes loud noise
The model is DHD250-U2, and I purchased it in March 2005. The noise is almost a grinding sound. I had a computer-wise friend look at it, and he thinks the fan needs to be replaced. Have you heard of this problem? How difficult would it be to replace the fan (the case is very unique and difficult to remove), and would it actually fix it (if it is truly is the fan)?
I've had it out of commission because the noise was so obnoxiously loud, but I need to use it regularly now.
Any ideas/suggestions?
5 Suggested Answers
  • 83 Answers
SOURCE: I have an Iomega 250gb external drive. The cable
Get new cable at bottom dollar.com swampratt200 !1 AAEEE!!!
Posted on Jul 21, 2009
cowboytech
  • 69 Answers
SOURCE: I have an Iomega terrabyte drive model MDHD10T-U2.
If it did this when you first got it, you should have returned it for a refund or exchange. That drive was bad out of the box.
Posted on Feb 13, 2010
ic0729
  • 212 Answers
SOURCE: solution CD for Iomega Network Hard drive 250Gb
You get the drivers at Iomega.com and look under support to get your drivers.
REMEMBER you need to install those drivers to ONE pc and then have all your computers networked to it thru your network neighborhood. Any other questions, please write back to me, ok?
Posted on Mar 16, 2010
  • 74 Answers
SOURCE: please send me manual of 250gb iomega portable
USB Desktop/External Hard Drive User's Manual: View Online [HTML] ' Download [295KB zipped HTML]
Quick Start Guide [PDF 564KB]
Posted on Dec 24, 2010
My Iomega HDD 80 GB not detected and become noisy, so pls help
-it sounds like your external drive had a head crash. The noise is normally grinding noise.
-if your data on the drive is priceless, you may need to consult recovery experts like http://www.drivesaversdatarecovery.com/.
Dec 18, 2010 | Iomega HDD External Desktop (32660) 80 GB...
REQUIRE WINDOWS 7 DRIVER FOR IOMEGA SILVER SERIES 250GB EXTERNAL HARD DISC DRIVE. THANK YOU
The external hard-drive is "plug-and-play", and Windows XP/Vista/7 all support "plug-and-play".
Thus, it should automatically be detected by Windows.
So, what's your "real" problem? Symptoms? Error-messages? What happens? What does not happen?
Nov 05, 2010 | Iomega Silver Series External 250GB...
Please send me manual of 250gb iomega portable
May 06, 2010 | Iomega 33089 250 GB Hard Drive
Iomega terrabyte drive MDHD10T-U2 does not mount, ticking noise
I followed richiegrier solution above - my drive began clicking and did not run. I determined both drives worked and that it was the power supply (apparantly I'm not the only one with this problem. I purchased a NexstarMX dual HDD enclosure. I opened it, flipped the switch up to the JBOD mode, and installedd my two drives. Initially the configuration recognized a single 900+ GB drive, which was empty. I used the safely remove hardware icon, powered down the unit, and switched the positions of the drives - VOILA!!! the computer recognized the drives and all the files are back online, precisely. A couple caveats - the drives when in JBOD mode are A and B, although there is no obvious way to tell them apart - Like a book, A appears to have the directory for the combined drive. When mounted in reverse, the computer did not read the directory, and assumed it was empty. When I reversed the drives, my drive came up, flawlessly with no input from me. THANK YOU. Do not format or create a new partition or you will lose data. I also purchased a 2 TB drive for back up, and will immediately begin a second copy of all the data on this drive so I do not have a disaster. Thanks again for saving me from disaster.
Dec 07, 2009 | Computers & Internet
My external hd makes a constant, loud noise
Back up your files and buy a replacement drive the grinding noise is the hard drive experiencing mechanical failure and may stop working soon.
Oct 08, 2009 | LaCie Computers & Internet
Defragmenting external drive
run the command prompt, by going to start run and entering "cmd" then enter "defrag" followed by the drive letter.  if this doesn't work, enter "defrag /?" with the space for more options
Jan 08, 2008 | Iomega (33090) 250 GB Hard Drive
Very noisy 'back-up' hard drive
Dear
Generally hdd is non-repairable. You must place the hdd in a fixed place. it will make ur hdd long-lasting.
Tapa
91-9830114059
Dec 10, 2007 | Computers & Internet
No Power to External Hard Drive
Do you have access to a multimeter or voltmeter? If you do you can check the voltage coming out of the adapter and make sure it matches what the power adapter says it is. If it doesn't, then it is the power adapter. If it does, then it is the drive or enclosure.
Jun 21, 2007 | Iomega (33090) 250 GB Hard Drive
Open Questions:
See all Iomega (33090) 250 GB Hard Drive Questions
Iomega (33090) 250 GB Hard Drive Logo
428 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
