Question about Sony DAV-S500 System
Can i use a scart lead
I have got a dav-s500 dvd player with amplifier but it didnt come with a scart lead can i use a scart lead or is there anything i can get so i can use a scart lead. my television doesnt have the 3 holes for the colored wires it onli has scart lead socket.
  • 10,594 Answers
You need Scart to RCA Cable to connect TV with DAV-S500 home theater system.
Thank you.
Posted on Nov 19, 2008
Tip
Sony DAV-C700, DAV-S400, DAV-S500, DAV-S800, CMT-S9D region free unlock code
Introduction
The DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the machine.
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Sony DAV-C700
 Sony DAV-S400
 Sony DAV-S500
 Sony DAV-S800
 Sony CMT-S9D
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD MOD Upgrade disables Macrovision to solve any problems.
User manual
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [ENTER] Default Default region code on the player
[1] [ENTER] Region 1
[2] [ENTER] Region 2
[3] [ENTER] Region 3
[4] [ENTER] Region 4
[5] [ENTER] Region 5
[6] [ENTER] Region 6
[7] [ENTER] Region 7
[8] [ENTER] Region 8
[Arrow down] [ENTER] Only play DVDs with the selected region; auto switching OFF
[Arrow up] [ENTER] Default Auto switching ON
[PREV I<<] [ENTER] Enable video interference impulses (Macrovision ON)
[NEXT >>I] [ENTER] Default Disable video interference impulses (Macrovision OFF)
[Arrow left] [ENTER] Enable user operation prohibitions* and access restrictions
[Arrow right] [ENTER] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
on Mar 02, 2010 | Electronics - Others
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Hope this info will help you.
Thanks.
Nov 29, 2009 | Sony DAV-S500 System
I want to connect an external DVD player (Samsung DVD-1080P9) to my Sony DAV-S500 system
yes u can connect an externel dvd player to your sony dav s 500...
you have
composite video input X 1 and
analog input X 1.
so you can connect the RC output pins of externel dvd player to the input of composite video and analog left and right audio inputs to the SONY DAV S500.
ANY QUIERIES MAIL TO ME
kanny_amancha@yahoo.com
kanny-sounds.blogspot.com
Jul 11, 2009 | Sony DAV-S500 System
How do I connect a new dvd player to Sony DAVS500?
If DAV-S500 have Input then hook new dvd player there and you can listen surround sound too.
Jan 02, 2009 | Sony DAV-S300 System
Movie playing black and white
the problem sounds like its with the s video connection, try using the composite video input
Mar 27, 2008 | Sony DAV-S500 System
Sony DAV S500
The protect indication is because of a fault detected in the amplifier section. If this appeared occasionally before and cleared itself, it suggests bad connections. If you know how to solder, open up the unit and resolder any connections that appear grainy or have rings. That may solve the problem.
Dan
Jan 24, 2008 | Sony DAV-S500 System
Is Sony DAV-S500 optical input compatible with optical output from Pioneer DVD player DV-566K?
I don't think this has an Optical but a Coaxial connection. You might try a coaxial audio cable not optical.
Dec 30, 2007 | Sony DAV-S500 System
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No sound through TV
In case you connect the System to a TV set using the Scart Connector, only the video signal is terminated, Audio is actually not wired inside the SB100 Scart connector.
Sound will only be amplified through the system itself (through the satelites and Sub) it can not be utilized as a stand-alone DVD player.
So after connecting your surround speakers the problem will be solved
Apr 30, 2007 | Sony DAV-SB100 System
Sony DAV-S500 System Logo
108 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
